Biggest Tire on a Stock Pro
Discussion in '5th Gen 4Runners (2010-2024)' started by 4wheelgreg, Jan 11, 2022.
  1. Jan 11, 2022 at 8:51 AM
    4wheelgreg
    4wheelgreg [OP] New Member
    Greg
    Bensalem Pa
    2022 4Runner TRD Pro
    I just picked up a 2022 Pro , whats the biggest / widest tire you can run on a Pro ?
    I would like 35’s maybe a 34” as we all know not all tires are created equal , I find Nitto Ridge grapplers to be the most accurate .
    I have 34’s on my 2020 LC 200 , with the land cruisers the biggest problem is the KDSS arm , glad the Pro’s did not uses the KDSS .
    I still have to find how modification friendly my dealer is , some how I got sucked into a platinum Toyota extended warranty , guy started out at 3k for 7yrs 100k miles and knew I was not buying one , he knew I have a many vehicles to drive and don’t put many miles , he came back with 1100 bucks for that warranty , that was pretty cheap for platinum 4yrs extra .
    Not sure if I’ll do anything but 35’s would be nice , any one running 35x12.50 ?
    Gnim559 likes this.
  2. Jan 11, 2022 at 9:16 AM
    Mtbpsych
    Mtbpsych New Member
    With lots of work you can fit 35’s on a stock pro.
    Bob and LandCruiser like this.
  3. Jan 11, 2022 at 9:19 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    That warranty gonna be pointless by the time you’re done making the mods to fit 35’s :D
    Toy4X4, 7385, Trail Runnah and 3 others like this.
  4. Jan 11, 2022 at 9:27 AM
    I thought 275/70R17 is the biggest you can fit to stock TRD Pro.
    With a spacer kit or suspension lift you can fit 285/70R17 or 255/80r17 right?
    35s need suspension lift + body lift + body mount chop right?
  5. Jan 11, 2022 at 9:31 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Get out your sawzall, bud.
  6. Jan 11, 2022 at 9:41 AM
    2019 TRDP w/Kangs brah!
    Get the hacksaw out.
    104556d1386611703-going-bigger-5th-gen-t_0ddcf42c6aae00e011783b6a0eb4f29559c8ad1e.png
  7. Jan 11, 2022 at 2:09 PM
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    I’d like to jump to 285s at some point. But only if minor tweaking is required.
    I think I’ve read the Pro already has had the fender liner mod done at the port. Is this correct?
    Is it possible to modify the front mud flaps to make them fit? I’d prefer to keep them.
    Sorry for the slight hijack.
  8. Jan 11, 2022 at 4:05 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Some brand tires will fit fine on a pro without mods. Most require a smidge of plastic modding
    they do not come with any mod to make bigger tires fit.
    You can try to use a heat gun but doubtful it will do much.
  9. Jan 11, 2022 at 4:10 PM
    18 trd off road
    18 trd off road New Member
    Joe
    21 trd pro lunar rock
    275/70/17 and they rub
    Haffnez and Thatbassguy like this.
  10. Jan 11, 2022 at 4:13 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Probably because your wheel offset is different than OEM
  11. Jan 11, 2022 at 4:16 PM
    Is that TRD Pro? (Sorry, I was curious missing roof rack, badges, does not seem to have that slight lift front with fox shocks)
    I know 2019 TRD Pro didn't have roof rack but that color is new. So wasn't sure if its TRD Pro.
    My TRD ORP with stock wheels did not rub with 275/70/17.
  12. Jan 11, 2022 at 4:22 PM
    If you want 35's without a lot of work you should have picked up a Bronco or a Wrangler, haha.
    However, if you did manage to fit the 34s or 35's on the 4Runner, you would probably want to regear the axles as well.
  13. Jan 11, 2022 at 4:26 PM
    It only cost $4000 for lift + tires + regear for Wrangler from factory. :D
    Just my lift cost me $4000..:facepalm:And Toyota Dealer crashed after a month..:frustrated:
  14. Jan 11, 2022 at 4:35 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    maybe for some cheap rough country 6” lift :D
    Thatbassguy and Mtbpsych like this.
  15. Jan 11, 2022 at 4:51 PM
    Tires - LT315/70R17C BFG KO2 Load C
    Lift - 1.5 lift with Fox shocks
    Gears - 4.56:1 (vs stock 3.73)
    Zgqx9AHPENu7niPQj5rUoSALh2XCgdekUvaFjPm5_413a3c239e6caec8f4b4276b3c62a3b6bb0ede2f.jpg
    Reldn, Thatbassguy and Trail Runnah like this.
  16. Jan 11, 2022 at 4:56 PM
    Pretty much a bargain when you think about it. Especially considering it's probably fully warrantied, and if financing you're spreading it out over five or six years.
    Room to grow too, because I think the 4.56 would probably be sufficient with 37 or 38's as well.
    (Clearly I'm the Jeep fanboy of the group haha)
  17. Jan 11, 2022 at 4:59 PM
    Same here..:D
  18. Jan 11, 2022 at 7:50 PM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    Look into a Westcott Designs pre-collar lift and you can fit 285 70 R17s on stock rims
    LandCruiser and Thatbassguy like this.
  19. Jan 11, 2022 at 8:35 PM
    Definitely the way to go if you want big tires!
    The guy at my off-road shop says 37's fit (a Jeep) with a 2" lift and some minor trimming.
    Regeared and 35" from factory is crazy cheap!
  20. Jan 11, 2022 at 11:21 PM
    suaveflooder
    suaveflooder New Member
    I would own a jeep in a second if they were more reliable. I want one so badly, but I drive around 3000 miles a month :facepalm::facepalm::facepalm:
  21. Jan 12, 2022 at 3:37 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Yeah, I don't recall where I saw that about the fender liner, but I remember thinking that is was odd because I have not seen that mentioned anywhere else. As much as I want the 285s (purely for visual appeal), I'll probably stick with stock size the first time around. Thx
    Exploring208 and Thatbassguy like this.
  22. Jan 12, 2022 at 11:32 AM
    TRDLE
    TRDLE New Member
    Duluth, MN
    '22 TRD Pro
    I've seen the same. There was a youtube video by one of the lift or tire companies or something. I know he said something about the Pro being able to fit a wider tire or something. I don't remember any details to make this post even a little bit helpful, but I can at least confirm you're not crazy.
  23. Jan 12, 2022 at 12:09 PM
    TRDLE
    TRDLE New Member
    Duluth, MN
    '22 TRD Pro
    Here it is. Westcott Designs. He says the fenders are trimmed on the Pro, not on the other trims.
    https://youtu.be/Yyt_0rptEPk
  24. Jan 12, 2022 at 1:19 PM
    Vic_
    Vic_
    White 4Runner
    Any 4Runner that comes with the TRD Pro rims from factory or put on at dealer has this "Bumper Cut". Coworker of mine has an sr5 with "blackout package" and her bumper has been trimmed to fit the TRD Pro rim. I am sure it is due to the offset of the wheel.
    Thatbassguy, TRDLE and SlvrSlug like this.
  25. Jan 12, 2022 at 1:57 PM
    fffffff
    fffffff New Member
    This is correct its due to Offset. I don't have a Pro, but I had 285s with off road wheels (+14 offset), no rubbing (2.5"f1.5"r suspension lift). Switched to wheels with -10 offset and had significant rubbing on the front bumper, fender, and mud flaps. Removed Mud Flaps, trimmed front bumper, pushed in fender line.
    Port instructions for TRD Pro fender mod.
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10162789-9999.pdf
    atk411 and MI-FL off roader like this.
  26. Jan 13, 2022 at 3:39 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Hmm, that very well could have been the source, because I have seen that video. Good find.
  27. Jan 13, 2022 at 3:42 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Hmm, so there is a good chance mine has had the trimming and fender liner mods done. So in theory, there's a chance only the front mud guards would need to be removed. I'd be okay with that in order to fit 285s, but I don't want to do any body-mount chopping.
    The plot "thicks"..........
    Haffnez likes this.
  28. Jan 13, 2022 at 5:42 PM
    18 trd off road
    Joe
    I took off the rack and badges once I got it home
  29. Jan 14, 2022 at 1:17 PM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Confirming my Pro had the front bumper trimmed.
