Best way to remove center caps?
Discussion in 'Wheels & Tires' started by ColtM4A1, May 25, 2021.
  1. May 25, 2021 at 12:42 PM
    ColtM4A1
    ColtM4A1 [OP] New Member
    2019 Gray 4Runner SR5
    None yet
    Good day!
    Hopefully a quick and easy question. What is the best way to remove the plastic center caps on a 2019 SR5? I want to paint them but avoid damage as I remove them from the wheels.
    Your time in this matter is greatly appreciated!
    Respectfully,
    Colt
  2. May 25, 2021 at 12:56 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Depends upon how the caps were designed(how much bite the caps have)? The safest way is to remove the wheel, then remove the cap.
  3. May 25, 2021 at 1:21 PM
    Tuco S.
    Tuco S. New Member
    If you can get some string or fishing line under opposite corners, they should pull straight out. They're just plastic. Or you can do like Moon Landing says and remove the wheel, then pop them out from the inside.
