Best lift for 2018 Off Road w/ KDSS
Discussion in '5th Gen 4Runners (2010-2024)' started by Amamomenso, Aug 5, 2018.
  1. Aug 5, 2018 at 12:05 PM
    Amamomenso
    Amamomenso [OP] New Member
    2018 TRD Off Road w KDSS
    Hey hey! So I leveled my 2018 Off Road with KDSS because all of the shops around here and Toytec didn’t recommend a lift with the KDSS (at the time). Now I see they have an option for a lift with the KDSS. I’m guessing a few manufacturers have them available now. Basically, I want a 4” up to 6” lift for it and I’d like suggestions from anyone who has one. Also, with a 4” or 6” lift does it require any other mods, i.e. brake lines or any of that? I’m the (Maryland) area also and looking for a good shop that works on these. Thanks everyone!
  2. Aug 5, 2018 at 12:25 PM
    4X4Runner
    The left coast
    I had a 2010 Trail 4Runner with KDSS in 2010 with a 3” OME suspension lift and I’m not sure why they gave you that advice, but it’s flat out wrong.
    4”-6” is going to more than likely be a drop bracket lift which means cutting the cross number under the engine and a slew of other things and $$$.
    You could go with a nice 2”-3” suspension lift with upper control arms and a cab mount chop and be good.
    Personally, I’m not a fan of DB lifts because I don’t like the looks of them and the big ass vertical flat spot it creates under the engine.
    Daohaus, SlvrSlug and Bob like this.
  3. Aug 5, 2018 at 12:58 PM
    Amamomenso
    Oh my! I didn’t think it would entail quite that much. You’re right, I don’t want to spend a ton and definitely don’t want a vehicle with 5k miles to be cut and welded. 3” lift is starting to sound more realistic. Thanks for the info!
    jgcaps and Bob like this.
  4. Aug 7, 2018 at 12:50 AM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    Get PRO takeoffs. They're OEM, work great and you can find them cheap. Here's a brand new set for $750.
    Then you'll have a TRD Pro with KDSS for a lot cheaper than $10,000.
    Pro Setup
    Daohaus and Barcelona Trail like this.
  5. Aug 7, 2018 at 8:18 AM
    Amamomenso
  6. Aug 16, 2018 at 9:49 PM
    DesertCanyons
    DesertCanyons Professional Engineer, Civil/Structural
    Dave
    Pasadena, CA
    2015 MGM Trail Edition w/ KDSS, no sunroof
    ICON tubular Stage 7 lift (+2"), ICON Rebound wheels w/ Falken AT3W LT285/70R17 tires, Baja Rack flat utility rack and ladder, RCI skid plates, Domello rock sliders, Diff breather relocated, Baxter Performance remote oil filter, Weathertech floor mats, side exit exhaust, 2nd rear recovery point
    Almost any suspension system will fit KDSS. If you lift 2" to 3" you do need new UCAs for alignment. No body mount chop for me. That compromises the integrity of the cab in case of a side or corner frontal accident.
  7. Aug 24, 2018 at 2:31 PM
    thepman
    thepman New Member
    Paul
    Kern County California
    2018 4Runner TRD Premium
    Toytec Lift, SPC UCA's, Nitto Terra Ridge Grappler so far!
    I lifted my 2018 4Runner Off Road Premium with the Toytec system. I installed the lift myself with the help of a youtube video from Wonderlost Overland. They were very helpful! I have the KDSS system and it was no problem installing the lift. I had to disconnect the KDSS but with the help of some youtube videos, it was not a problem. I also replaced the UCA's. I had Nitto Terra Ridge Grappler 285-70-17 put on my stock wheels. Here are some pics.
  8. Sep 3, 2018 at 8:25 PM
    Daohaus
    Daohaus New Member
    Duan
    Eastvale CA
    2018 Black ORP 4Runner
    Rotiform SIX-OR | Toyo Open Country RT 285/70/17
    Like others have said, the shops you spoke to was ill informed. Go elsewhere to get work done if they're telling you that.
    I plan on doing a slightly higher "TRD Pro" style lift with Bilstein 6112 frt/ 5160 rear in the coming week and I'm equipped with KDSS
    doublewide likes this.
