Best air compressor? Thoughts?
Discussion in 'General 4Runner Talk' started by Maxwell008, Dec 5, 2024.
  1. Dec 5, 2024 at 7:21 PM
    Maxwell008
    Maxwell008 [OP] New Member
    Hey all,
    I am looking to invest in a quality air compressor. I am not looking to bust the bank, but also not looking to get the cheapest one out there. Maybe $300 or so? (I'm guessing....)
    Tire size is between 33 - 35 inches.
    Are there any recommendations...? (in order of importance)
    1) very reliable (especially in the back country if traveling alone)
    2) speedy
    3) easy to use
    Hoping I didn't open up a can or worms...
    Thanks!
  2. Dec 5, 2024 at 7:33 PM
    DesertSurfer
    I have a Vlair 88p off Amazon for around $76.00. Works well.
    Old goat, icebear and Shredder like this.
  3. Dec 5, 2024 at 7:39 PM
    ADV4RNR
    ADV4RNR New Member
    Bob
    2019 Off-Road Premium
    typical lift, tires, skid plates and rock sliders
    Stoney Ranger likes this.
  4. Dec 5, 2024 at 7:47 PM
    I have a Viair 300P and it's good for my 295's. You might want to step up to a bigger one for 35's, though.
  5. Dec 5, 2024 at 8:04 PM
    Viair 440P, just under $300: https://viaircorp.com/products/440p-portable
    ARB's CKMP12V2 is comparable in performance and reliability, but costs a lot more.
  6. Dec 5, 2024 at 8:09 PM
    I’m pretty happy with my Viair 450P. I’d go ARB dual for my next one.
    kmeeg likes this.
  7. Dec 5, 2024 at 8:15 PM
    The Viair model numbers (and prices) keep going up the longer the thread lasts. :D
    SlvrSlug and icebear like this.
  8. Dec 5, 2024 at 8:29 PM
    I have this one and it’s been great. I use the heck out of it. Bonus, it fits nicely in the rear sidewall pocket.
  9. Dec 5, 2024 at 8:34 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Look at your tire size and what you intend to air down to.
    XL or SL tires on mild dirt, snow, sand etc probably do not need very low pressure. LT for harder usage maybe 10-15 psi to 35-40 highway.
    You might air up all 4 before your pump gets hot.
    My Smitty Built M 2780, 2.54 cfm aired up my nephews 37x12 LT (Bronco) from 25 trail to 40 highway in about 2.5 min. Well within its run time. Cost about $150.
    Lots of online discussions for all brands & price points.
  10. Dec 5, 2024 at 8:46 PM
    Knarf
    Knarf New Member
    DFW
    2024 White SR5
  11. Dec 5, 2024 at 8:53 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Viair 400p for me. Use it with morflate to fill up two tires at once. No issue so far, it’s been working great
    Ripper238 likes this.
  12. Dec 5, 2024 at 9:09 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Viair 400P has served me well for 5 years
  13. Dec 5, 2024 at 9:20 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Viair. It's the winner.
  14. Dec 5, 2024 at 9:28 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
  15. Dec 5, 2024 at 9:29 PM
    Don’t overthink it.
  16. Dec 5, 2024 at 10:29 PM
    Maxwell008
    Wow! You guys are all awesome! Thank you for the quick response!
    Looks like VIAIR is the choice brand for most folks.
    I'm going to look into this brand.
    Thanks!
  17. Dec 5, 2024 at 11:04 PM
    donnermel
    donnermel New Member
    dita.yota
    Truckee/Tahoe
    ‘16 Trail Premium Super White w/ KDSS
    Dobinsons lift and UCA, RCI sliders and front engine skid, H9 bulb swap, Sprint Booster, KnN air filter, Canvasback covers, Raingler cargo net, AVS Window Shade deflectors, Heritage Grill with raptor lights Summer Wheels: Ryder RR03 matte gunmetal with Falken Wildpeaks 285/75/17 Winter Wheels: 18” KD Wheels with Blizzaks Rack is OEM - but changed to black with LFD crossbars Diode Dynamics Ss3 fogs
    Gotta throw in Morrflate! Set it, and go, plus the air chucks are so easy to use.
  18. Dec 6, 2024 at 5:46 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    A cheap used co2 tank, and 16 dollars to fill it every other summer. If all your going to use it for is airing tires back up from tooling around, and here there usage. Way faster than any pump on the market, WAY cheaper, more relialbe, and you can leave it if you want, stupid cheap to fill, safe, uses nothing off your rig electrical/alternator, takes up little space, and put/mount it anywhere. Works a treat. But, to each their own. I know having on board air is up there on the cool factor. For some anyway.
  19. Dec 6, 2024 at 7:39 AM
    Maxwell008
    hmmm...co2 tanks never crossed my mind. Interesting. I'll look into that as well. Good to have options! Thank you!
  20. Dec 6, 2024 at 7:56 AM
    Geeeze Louise
    Got knock? That should be an astronomical amount of bass in a 4R
    Thatbassguy and kolter45 like this.
  21. Dec 6, 2024 at 8:15 AM
    Not a recommendation. A question.
    After my trusty Craftsman <Slow> air compressor failed I bought this one from Amazon. Its very fast to air up. However the air seems to be very hot. Is it the same case with highend air compressors like ARB dual? Is the air much cooler after 10minutes of working?
  22. Dec 6, 2024 at 9:04 AM
    I have the Maxi-trac twin cylinder from NAPA. It's a beast, and was only 125-ish.
    It'll air a 265 up from 0 in about 2 minutes.
  23. Dec 6, 2024 at 9:32 AM
    The mechanical operation generates a lot of heat, I bet that's it. I have to be careful handling my 88P after airing up and it was the same with my much slower (and cheaper) Bon-aire compressor.
    Edit: Removed traces of unfinished post
    Thatbassguy and kmeeg[QUOTED] like this.
  24. Dec 6, 2024 at 10:13 AM
    SOSHeloPilot
    SOSHeloPilot New Member
    SouthEast USA & S.E. Asia
    2024 4Runner SR5
    Owned Many Toyotas - Past
  25. Dec 6, 2024 at 10:47 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I have the basic Viar and that thing is so slow for the 34s...
    I've really been considering getting onboard air with an ARB twin but every time I price out the compressor, the mount, a quad hose system and switch I talk myself out of it.
  26. Dec 6, 2024 at 12:15 PM
    TRDSD
    2019 TRD Off Road Premium
  27. Dec 6, 2024 at 12:44 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    I thinks it’s a neat idea, but takes up little spaceo_O, more than my compressor, which in its case can stack on something or get stuffed in a little hole.
  28. Dec 6, 2024 at 9:00 PM
    No. 440P is the highest CFM compressor ViAir offers. 450P is actually slower.
  29. Dec 6, 2024 at 9:04 PM
    The Napa compressor posted by Knarf is faster than the ARB twin. However, it doesn't satisfy 1) very reliable (especially in the back country if traveling alone)
    One way around this problem is to buy two of these: https://www.amazon.com/ALL-TOP-150Psi-Compressor-Portable-Heavy/dp/B08637KCWQ/ You can hook up both to the battery and inflate two tires at the same time. This negates the shrader valve bottleneck without needing a quad hose system, and provides redundancy if one compressor fails.
  30. Dec 24, 2024 at 12:26 PM
    Scarif_1
    Scarif_1 New Member
    Oakland
    2020 TRD ORP
    Viair 400p with the inflater gun has been fast and reliable on my 33” Toyos. $250 open box item on Amazon.
    Thatbassguy and Gorgester like this.
