Aux fuse box DIY
Discussion in '5th Gen 4Runners (2010-2024)' started by Brother708, Apr 6, 2020.
  1. Apr 6, 2020 at 5:21 PM
    Brother708
    Brother708 [OP] New Member
    Austin
    Memphis
    2019 4Runner Off road premium
    *Kings Suspension* Gobi Rack*Shrockworks Bumpers & Sliders*ARB Compressor*Warn Winch* Baja Design lights*
    What are people doing for this to hook up all accessories?
  2. Apr 12, 2020 at 10:37 AM
    Brother708
    Austin
    Memphis
    Any insight?
  3. Apr 12, 2020 at 12:45 PM
    Agent_Outside
    Built 2011 T4R Limited
    Wvmoonshiner likes this.
  4. Apr 12, 2020 at 5:22 PM
    Brother708
    Austin
    Memphis
    Thanks for sharing! Obviously being a dual battery setup this has a lot of extra items. Is there something simple just if i want to add a few extra aux items onto the main (only) battery.
  5. Apr 12, 2020 at 5:42 PM
    Agent_Outside
    You can set the same type of fuse relay panel and set it up off a single battery. A lot of people go with Blue Sea fuse panels, I’m not a fan because they aren’t waterproof/sealed. Spod is another popular all in one easy option as well.
  6. Apr 13, 2020 at 9:52 AM
    PandaKyle
    PandaKyle New Member
    2019 Toyota 4Runner SR5
    What exactly are you looking to add? Normally I just run off the battery with an in-line fuse, or tap into the interior fuse box with a wiring harness (I call them tap fuses, not sure what the real name is). I have also used preexisting wires for power, such as my DRLs amber markers for my grill lights so they power on with the amber markers (it's not a light bar, they are small amber lights). It all depends on what you're adding, how much you're adding, and how you want to use them.
  7. Apr 13, 2020 at 11:18 AM
    Brother708
    Austin
    Memphis
    well eventually ill have:
    • compressor
    • roof spot lights
    • roof chase lights
    • roof camping lights
    • winch
    • CB system
    • etc.
    Rather then running the main power wire from every item to the single positive terminal on the battery id like to add a separate box that has one main positive post.. and one main negative post from the battery.. and then 10 or so individual +/- that I run off of that.. I assume that's what the marine fuse box mentioned above would be good for?
  8. Apr 13, 2020 at 11:23 AM
    PandaKyle
    Ah, yes. In that case I agree; it would be easier on you to add an auxiliary fuse block. I've been pondering this one here for a few months https://overlandequipped.com/produc...-for-5th-generation-toyota-4runners-2010-2017 for the mount
    https://www.bluesea.com/products/5026/ST_Blade_Fuse_Block_-_12_Circuits_with_Negative_Bus_and_Cover for the fuse block
    Please keep us updated on your progress
  9. Apr 13, 2020 at 11:48 AM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    I recently did this. Relays are fastened under the fuse box.
    My HID headlights are straight to battery with inline fuses. Other stuff goes to the fusebox. I put a breaker close to battery that is rated slightly lower than max rating of the fuse box as a sort of redundant safety (80A & 100A).
    CB is grounded to battery to reduce noise. All others grounded elsewhere. My relays are grounded behind fuse box instead of overcrowding the existing ground beside battery.
    I highly recommend the braided PET sleeves plus heat shrink at ends to help protect wires from abrasion.
    JRod0981 and 7385 like this.
  10. Apr 13, 2020 at 2:08 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I built my own from parts off of Amazon. I did this for my 3rd Gen 4Runner, Dodge Ram and now my 5th gen. It has been working well for me and far cheaper than other ones. If you want I can take pictures of the set up on my 4Runner.
    [​IMG]Untitled by redrunner87, on Flickr
    7385, totmacher and Fourtoad like this.
  11. Apr 13, 2020 at 7:21 PM
    nm_t4r
    nm_t4r New Member
    2018 Barcelona Red 4runner LE
  12. Apr 13, 2020 at 7:22 PM
    nm_t4r
    nm_t4r New Member
  13. Apr 30, 2020 at 7:52 AM
    Toydb
    Toydb New Member
    Just completed a fuse/relay block on my 18 Limited. Fabricated the panel from sheet metal (Home Depot) using a jig saw and vise to make the bends.
    • Circuit Breaker: Bussmann Series 100 amp 285 Series Panel Mount
    • Fuse Block: Blue Sea 5025 ST 5 Fuse BlockAuxilliary Fuse Box - Installed Closeup.jpg Auxilliary Fuse Box - Installed Wide View.jpg Auxilliary Fuse Box - Panel Bottom.jpg Auxilliary Fuse Box - Wiring Closeup.jpg
    • Terminal Block: Blue Sea Model 2406
    • Relays: Balkamp 40 amp 4 pin
    • Relay Connectors: Grote (NAPA) 5 pin (5th pin wire is not used but is capped and tucked away under the panel in case a 5 pin relay is needed down the road.)
    • Battery Cables and Lugs: 4 AWG and 1/4 inch BatteryCablesUSA
    • Socket Cap Screws and Nylon Nuts: Everbilt metric (Home Depot)
    So far have underhood light connected.
    https://www.4runners.com/threads/5th-gen-underhood-led-lights.11969/#post-127284
    Next up will add an Anytime front camera kit which is on backorder.
    Thanks to the many forum members who provided design ideas and installation tips! Hope this is helpful to you.
    7385 and doublewide like this.
  14. Sep 30, 2020 at 2:49 PM
    JRod0981
    JRod0981 New Member
    These are very cool setups. I plan to put together something like this for my 4runner with a 6 fuse circuit and adding only a compressor and light bar to start. How waterproof or water resistant are these setups in the engine bay for those messy adventures or when you go to clean/detail the engine bay? Any particular fuse box and such I should use that is better than others for that?
  15. Sep 30, 2020 at 4:59 PM
    Toydb
    Toydb New Member
    The Blue Seas Fuse Block and Bussmann Circuit Breakers are not waterproof but the manufacturers do consider them "Weatherproof" or "water resistant." Both of the items I used are widely used in marine applications. For example, the fuse block has stainless steel screws and the cover and the circuit breaker has robust seals. Honestly don't see them as anymore risk than the OEM underhood electrical and electronic components. No issue with road/off road spray or moisture and if I need to clean the engine I simply cover as with other electronic/computer components.
    JRod0981 likes this.
  16. Oct 1, 2020 at 8:05 AM
    totmacher
    Daniel
    West TN
    What he said.
    I just use gentle spray of water to rinse silt away but do not spray directly into fuse slots.
  17. Oct 16, 2020 at 1:08 PM
    JRod0981
    JRod0981 New Member
    Anyone have a good recommendation on a fuse box that can do a 40 AMP fuse? As I understand it, the ARB compressor (single or twin) comes with a 40 AMP fuse (2 fuses if twin), and I don't want to have that hanging off the battery. I want to put that into the auxiliary fuse box. Anyone done that? Or do these compressors just draw so much that it's recommended to keep them running directly off the batter?
  18. Oct 16, 2020 at 2:12 PM
    Agent_Outside
    Pretty much any fuse box can handle 40 amps. They will always say a max capacity for the panel, it’s rarely less than 100 amps. It doesn’t matter if it’s drawn directly off the battery or not, power is power. As long as the wire size is sufficient to carry the load over the distance you need without a big voltage drop you’re fine, fuse it as close to power source as possible and you’re good.
  19. Oct 16, 2020 at 2:17 PM
    JRod0981
    JRod0981 New Member
    I should have specified 40 amp per circuit? The Blue Sea fuse box which everyone seems to love, has a 30 AMP limit per circuit. The ARB compressor comes with 40 amp in line fuses. I plan to build the auxiliary fuse box right on top of the oem box so it's super close to the battery.
  20. Oct 16, 2020 at 2:43 PM
    Agent_Outside
    In that case just run them off circuit breakers.
  21. Oct 17, 2020 at 10:52 AM
    JRod0981
    JRod0981 New Member
    Not sure what you mean. Do you mean running the inline fuse off the circuit breaker? Or having a separate lower amperage circuit breaker for the compressor? My goal was to get rid of the inline fuses and h have everything within a fuse box after a main 80 AMP breaker.
