Audio stopped working today
Discussion in '5th Gen 4Runners (2010-2024)' started by AdelaOnyx, May 31, 2024.
  1. May 31, 2024 at 6:44 PM
    AdelaOnyx
    AdelaOnyx [OP] New Member
    Tampa Bay
    2021 Nightshade Limited 4Runner
    Stealth tail lights
    Have the 4runner nightshade limited with the premium sound. Driving home today the audio just stopped working mid song. It's happened before and just turning the car off an back on worked to fix it. However this time, the volume knob moves but doesn't register any volume change. Spotify shows the song is playing but no sound at all. Any thoughts? I checked the audio fuse and it looks fine. I've held the volume button to reset it but still no luck.
    Help please I need my music!
  2. May 31, 2024 at 6:45 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Remove the negative battery terminal for 10 mins and re connect. See if it solves this.
  3. May 31, 2024 at 6:45 PM
    Is it just Spotify? What happens if you turn on the actual radio and tune into an FM station?
  4. May 31, 2024 at 6:47 PM
    crob42
    crob42 New Member
    Los Angeles
    21 Limited
    Xreas delete. Bilstein 5160/6112 285 Toyos. BMC. Prinsu
    I can’t be of help here to solve it, but my 21 limited does this sometimes to. Mostly on startup. The only remedy is turn if car and restart. Happens about once every few months, more in the winter.
  5. May 31, 2024 at 7:37 PM
    AdelaOnyx
    Tampa Bay
    Stealth tail lights
    Am/Fm, Bluetooth, none of it has audio
  6. May 31, 2024 at 7:38 PM
    AdelaOnyx
    Tampa Bay
    Stealth tail lights
    I will try this in the morning first thing! Hopefully it'll fix the issue
  7. May 31, 2024 at 7:40 PM
    AdelaOnyx
    Tampa Bay
    Stealth tail lights
    I've had a similar issue a couple times now but it's only my Bluetooth that won't have sound when that one happens. I can use am/fm without issue, and the volume knob still registers. This is a bit more of an issue as I have zero audio all around.
  8. May 31, 2024 at 11:12 PM
    Sounds like a hardware glitch from the newer head units. Warranty
  9. Jun 1, 2024 at 8:01 AM
    AdelaOnyx
    Tampa Bay
    Stealth tail lights
    This did not work unfortunately. Guess I'll be calling the dealership.
  10. Jun 1, 2024 at 8:11 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    I had that issue on my 2021 Taco but it would always come back on if I restarted the truck.
    After much aggravation with it, a tech savvy friend determined that it was caused by the Bluetooth of my older phone. It seems the vehicle Bluetooth was trying to accept a nonexistent call from my phone and muted the radio. I was due for a phone upgrade anyway. That solved my issue.
  11. Jun 11, 2024 at 7:28 AM
    AdelaOnyx
    Tampa Bay
    Stealth tail lights
    Update - car has been at the service center for the last 3.5 days - finally getting "somewhere" after them being unable to diagnose the issue.
    Their most recent update - and I have a question I'd rather ask normal people than dealership people that just want my money.
    "Good morning, they did reply and unfortunately the amplifier would fall under the optional high tech and is a non covered component. I would have to order the amplifier and I won’t receive an ETA until after we order. Total investment would be $1800 for everything before any coupons. Let me know if I can get this ordered for you or if you have any questions. Thank you again and apologies for the not so good news."
    I've been looking at getting a separate amplifier and sub anyway, would that replace whatever amplifier is stock in car and I could just not worry about replacing it through the dealership?
  12. Jun 11, 2024 at 10:09 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Factory installed and they are not covering it under warranty? Did you do something to cause it to not work?
  13. Jun 11, 2024 at 10:35 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I would push the issue with the dealer, write a letter to the CEO.
    But i'm all for upgrading, however you should upgrade the head unit, amp and speakers.
  14. Jun 11, 2024 at 11:40 AM
    AdelaOnyx
    Tampa Bay
    Stealth tail lights
    Contemplating it. I'm so frustrated they said the warranty doesn't cover optional high tech components. It's the stock radio setup from what I gather and can tell. (bought it used with 32k miles) It is a premium audio package though so I'm not sure if that makes a difference.
  15. Jun 11, 2024 at 11:41 AM
    AdelaOnyx
    Tampa Bay
    Stealth tail lights
    Nope, as my other response said, it's the premium audio package and the warranty doesn't cover "optional high tech components". I had my music about half way up and it just randomly stopped. They say it's the amplifier that's popping a code.
  16. Jun 11, 2024 at 11:42 AM
    Ripper238
    2019 TRD OR
    It shouldn't make a difference being a premium package. But buying used may.
    I spent a lot of $$$$ on my upgraded stereo, so expect that if you want to do it right.
  17. Nov 29, 2024 at 5:10 AM
    fokai671
    fokai671 New Member
    al
    2017 black 4runner
    3inch lift
    hey man was wondering if u ever solved the problem to the no audio issue?
  18. Jun 16, 2025 at 12:56 PM
    crob42
    crob42 New Member
    Los Angeles
    21 Limited
    Follow up to my issue.. my audio went out again (no sound, volume control does not show up on the screen) but this time for days.. and I was prepping to go to the dealer.. so I unplugged my Anytime backup camera from the head unit so the dealer wouldn't be lazy and just claim the issues was my fault.. well .. after re-assembling the dash it worked.. and has for 1 month straight.. That's not long enough for sure know what happened.. it could have just been the act of pulling the head unit out.. but.. it sure feels like it may have been related to the connectors/harness coming with the aftermarket front camera. I'll never know unless i put it back in and see if the issue comes back.. . .but I have no appetite for that just yet..
  19. Jun 16, 2025 at 1:07 PM
    Oh,you have an aftermarket part attached to your radio. See, you never told us that in your initial post. If you did you would have gotten different feedback.
    The Anytime Cameras are good, but the wiring harnesses have caused issues for others in the past. I don’t know if the wires themselves are (were) bad or if the adapter/connector was bad. I would swap out the wiring harnesses to see if that resolves the issue for good.
    ….and next time man, be more forthcoming! :)
  20. Jun 16, 2025 at 1:27 PM
    crob42
    crob42 New Member
    Los Angeles
    21 Limited
    I was sure I had this issue prior to the camera.. but now i'm not sure at all
  21. Jun 16, 2025 at 3:18 PM
    Dontcha hate that? You feel SO confident that you did or said something, then someone questions if you did it (or said it) and then you lose all your confidence.
  22. Jun 16, 2025 at 3:28 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    That’s insane. Not surprising, especially regarding warranties and the fine print.
    The dealer said “sorry for the not so good news”..dude the bill is 1800 to maybe fix is an almost new not amazing sound system, I’d be so frustrated (I’m in the audio business tho). Good to know Toyota sells a premium audio option it doesn’t stand behind, that’s greasy. Makes me wonder what other tech on these 2020+ runners falls under “optional high tech component” lol
    Goodluck!
  23. Jun 16, 2025 at 6:53 PM
    Its all crap digital sound anyways. Its not "stereo". I dont even get radio stations here. Well a couple but its just commercials and nothing worth listening to. Switch to a cassette player?
