Anyone run 1.5" Spidertraxx?
Discussion in '5th Gen 4Runners (2010-2024)' started by banxwondar, Jun 7, 2021.
  1. Jun 7, 2021 at 12:08 PM
    banxwondar
    banxwondar [OP] @t4r08
    San Jose,CA
    21trdp
    -King 2.5 w/ adjusters -Westcott sliders 0 degree, DOM, no kick, plates, TIG -1.25" Spidertraxx Spacers -305/70/17 Maxxis Razr -CVC tune -20% Ceramic all around - Total Chaos UCA, cam tab, lower link skid -Black Rhino sradium 17 x 9.5 -18 -Joes side load panel -prinsu non drill rack -gobi ladder -eimkeith PCK
    Looking to throw some spacers on until my current Terra Grapplers run its course and I'm able to move on to 285s. In the meantime, I was eyeing Spidertraxx, but was debating on 1.25" or 1.5". Any of you that are running either, can you post pics? TIA!
  2. Jun 7, 2021 at 12:10 PM
    Red_5
    Red_5 New Member
    I ran them on two different Wranglers with nary an issue. As long as they're hub-centric and aircraft grade aluminum, spacers are fine. And Spidertrax makes the best.
    banxwondar[OP] likes this.
  3. Jun 7, 2021 at 12:11 PM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    With 285's if you have the stock wheel you will rub with 285's
    Jynarik and LandCruiser like this.
  4. Jun 7, 2021 at 12:17 PM
    banxwondar
    San Jose,CA
    21trdp
    Yea I'm sure I would a bit. I run a 1" Cornfed lift up front, but sure I would have to do some slight fender liner mods
  5. Jun 7, 2021 at 12:19 PM
    DallasTRDPro
    Dallas
    I added 1.6" lift up front and rubbed pretty bad even with the mudflap gone which didn't matter since it was my bumper/fender liner that rubbed. Wasn't worth the rub so I removed them. 1.25" was bad 1.5" would be worse.
  6. Jun 7, 2021 at 12:26 PM
    banxwondar
    San Jose,CA
    21trdp
    oh wow. was that with 285s and the 1.25" spacers?
  7. Jun 7, 2021 at 12:28 PM
    DallasTRDPro
    Dallas
    Yes. Trimming is no big deal, but I wasn't in the mood that day so I removed them.
  8. Jun 7, 2021 at 1:00 PM
    What is the purpose of wheel spacers?
  9. Jun 7, 2021 at 1:34 PM
    Increased track width. With A-arm IFS you loose track width as you lift the vehicle. A wheel spacer (or lower offsets) will get you back to stock or allow you to increase track width.
    I have a 1.6" lift with 285's. Caster set at 3.6 degrees with the fender liner mod. I did not rub with a 1" spacer up front. Now I have a 1.5" spacer up front and have a very slight rub at full lock in reverse. I suspect I wound't rub at all with 1.25" spacers and my current set-up.......but I can't know until I try it.
    Here's a pic with the stock Offroad wheels and a 1.5" wheel spacer up front. The rear end has 1" wheel spacers. The rear is perfectly flush (to my eye) and the front pokes a little. With my 1.6" lift in front, I feel a 1.25" spacer would make the tires up front perfectly flush like the rear.
    Sorry I don't have a better pic of the fronts but this will give you a little bit of an idea on the stance:
  10. Jun 7, 2021 at 2:28 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    I’d get the 1.5”.
  11. Jun 7, 2021 at 2:31 PM
    Forgot to mention.......my Offroad wheels are a +15 offset. Your Pro wheels are a +4 offset.
    The same size spacer is going to make your tires poke out further than mine.
  12. Jun 7, 2021 at 2:39 PM
    Excellent explanation, thank you.
    I didn't even consider or know about the track width narrowing with an IFS with a lift.
    Makes sense to me.
    nimby[QUOTED] likes this.
  13. Jun 7, 2021 at 5:18 PM
    banxwondar
    San Jose,CA
    21trdp
    What’s the width on your wheels? Mine are pencils . Also, what made you run staggered spacers? Thanks! Rig looks so good
  14. Jun 7, 2021 at 6:23 PM
    Thank you!
    Staggered spacers are because of my lift height up front. As you lift the independent front suspension of our trucks, the tires get sucked in and the track width gets narrower. The higher you go, the narrower you get up to a point. So let's say I lift my truck 1.6" high and put 1.25" spacers on all around, the track width in the front would still be narrower than the rear because the lift in the front sucked the track width in. By having a larger wheel spacer up front, I'm trying to get roughly the same track width front and back.
    Good point about the wheel width. Forgot about that.
    My wheels are 7.5" wide and your are 7". So the difference in offset will be tempered some with your slightly narrower wheels.
    Hopefully @Jynarik can post some photos of his truck with Pro wheels and 1.25" wheel spacers. I think he recently added some aftermarket wheels, but maybe he has some older photos lying around he can share.
  15. Jun 7, 2021 at 6:51 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
  16. Jun 7, 2021 at 8:19 PM
    j4unner
    j4unner shootz brah..
    j4runner
    nCal
    21 SR5P
    i have a set of spider trax 1.25 for sale.. used for 3 days..
  17. Jun 7, 2021 at 8:59 PM
    BeavertonCommuter
    BeavertonCommuter New Member
    Just want to know how you got the grille Toyota that red color... Been wanting to make all the logos and letters red but that front grille is the only one Im not sure how to do it.
  18. Jun 7, 2021 at 9:28 PM
    banxwondar
    San Jose,CA
    21trdp
    That’s 1.25” all around?? That’s perfect!
    @nimby thanks for the breakdown!
    nimby likes this.
  19. Jun 8, 2021 at 5:39 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    https://tvdvinyldecals.com/?gclid=C...eHwQN2Z3-2K6wXLHKhj5rXMkNJUXId_RoCD2MQAvD_BwE
    they’ve been on for almost 2 years and still look new
    yessir
  20. Jun 11, 2021 at 7:51 AM
    banxwondar
    San Jose,CA
    21trdp
    Ended up with the 1.25”. I think this is how it should have came from the factory.
    LandCruiser and nimby like this.
  21. Jun 11, 2021 at 9:29 AM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    That does look good. Any issues rubbing at the front?
  22. Jun 11, 2021 at 9:39 AM
    banxwondar
    San Jose,CA
    21trdp
    I do get a bit on on full lock in reverse, and I'm lifted 1 inch up front. Little fender liner push back will fix it.
    nimby likes this.
  23. Jun 11, 2021 at 10:06 AM
    08TXRunner
    '20 SR5P
    I'd hoped to get aftermarket wheels (FN or SCS) to fix this issue, but with everything back ordered forever I may look at doing this. Had them on my '08 before buying a set of FN Six Shooters. I despise these TRD wheels on my '20.
  24. Jun 11, 2021 at 10:12 AM
    banxwondar
    San Jose,CA
    21trdp
    Yea for a TRD wheel you'd assume it would be 8" minimum. My moms 96 Tercel had a wider wheel lol. This is also temporary for me until these tires are done then I'll plan to upgrade. Those six shooters :yes:
  25. Jun 11, 2021 at 11:18 AM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    Unless your mom was running aftermarket dubs, those were 4.5 inch wheels.
  26. Jun 11, 2021 at 11:23 AM
    Looks good!
  27. Jun 11, 2021 at 11:23 AM
    I really hope she was.
    LandCruiser[QUOTED] likes this.
  28. Jun 11, 2021 at 11:47 AM
    banxwondar
    San Jose,CA
    21trdp
    LMAO. Moms had the OG spinners on a pistachio green Tercel.
    nimby and LandCruiser[QUOTED] like this.
  29. Jun 11, 2021 at 3:20 PM
    RR4Runner
    RR4Runner New Member
    Scott
    2019 White 4Runner
    Installed a roughcountry 2" front spacer and 1" rear spacer on cousin's TRDOR 4runner. Installed the 1.25" spidertraxx and had to do minor trimming on front bumper to remove rubbing with factory wheels/tires. Installed 275/70r17 a few months later, had to do additional trimming of front bumper and mud flaps but nothing crazy, def doable with a utility knife.
  30. Sep 29, 2021 at 9:13 AM
    littlemrnofear
    littlemrnofear New Member
    k
    Cavalry TRD Pro
    did they rub with the spacers BEFORE you put on the spidertraxx?? I wanted to put 285's with a 2" front and 1" rear on a pro with no trimming, I will forego the spidertraxx if that will be the issue? ty
