Anyone lift for increased clearance but keep stock tires?
Discussion in 'General 4Runner Talk' started by Cpb2019, Jun 16, 2019.
  1. Jun 16, 2019 at 5:28 AM
    Cpb2019
    Cpb2019 [OP] New Member
    Chris
    2019 4Runner TRD Off-road
    I looks like most folks do a lift + larger diameter wheels/tires. If you have just lifted to gain another 2 inches or so of clearance and kept the stock size tires, I’d like to hear whether you were happy doing so and what setup you used.
    I find that there are times that a couple of inches of clearance would be meaningful, but I’d like to keep the stock tire size.
    Thanks,
    CPB
  2. Jun 16, 2019 at 6:21 AM
    Cpb2019
    Chris
    Yes, good point, thanks. I hadn’t thought of that. It’s mostly tree roots/branches that I’ve had an issue with and axle clearance would matter.
  3. Jun 16, 2019 at 7:06 AM
    What you would gain would be slightly improved approach, break-over, and departure angles. And, if you don't drop the front differential, you'll gain a bit in the middle up front. Whether any of that is enough to make it worthwhile is debatable.
    I'll stay tuned for more input. I plan on doing a slight lift and keeping the stock size tires as well. At least, until I change my mind again.
    :popcorn:
  4. Jun 16, 2019 at 7:20 AM
    You can go with a 275/70/17 without having to mod anything. If you go with a P-rated tire, it would be hard to distinguish much of a performance difference with the stock size, if that's a concern. Then again, depending on where you offroad, a C-rated tire may be a better fit durability wise.
    The 275 will give you a small amount of extra clearance and will fit the wheel well better with a lift (I think the stock tire size already looks too small for the vehicle even without a lift, but that's my opinion).
    Just some food for thought.
    SlvrSlug likes this.
  5. Jun 16, 2019 at 7:44 AM
    While I wouldn't mind larger tires, I think they look plenty big. That could be because I came from a Tacoma, though. The taco had smaller tires and a longer wheelbase.
    But, as you said, it's only a matter of opinion.
    I actually would like to go a size up for off road tires, but don't see a lot of options I like without going to 285's
  6. Jun 16, 2019 at 9:26 AM
    Cpb2019
    Chris
    Thanks for the thoughts/comments thus far. I’m trying to keep costs down and it is a daily driver, so I didn’t want to go full blown lift/tires etc. It is all a balance.
