Anyone installed a driver side grab handle?
Discussion in 'General 4Runner Talk' started by PennRunner, Nov 16, 2023.
  1. Nov 16, 2023 at 7:12 AM
    PennRunner
    PennRunner [OP] New Member
    Brian
    2023 4Runner
    I think one of the biggest omissions in my 2023 TRD-Offroad is the driver side grab handle. How much did they save? $10? I see third party grab handles sold but I am looking for anyone who has actually installed one. Videos show you have to remove trim pieces, which I think is unavoidable. I am always weary of that because every time I have removed plastic pieces, they have never gone back together exactly like before. How does the handle get attached to the A-pillar considering that the factory didn't make the attachment spots?
  2. Nov 16, 2023 at 7:33 AM
    ^Upper hole has an existing bracket on 2014-current models. For the lower hole, you put in a rivnut and install with long spacer and long screw.
    I didn't like the small size of the included screw, so I opened up the hole on the A-pillar, installed a bigger M6 rivnut, drilled out the long spacer, and put in a long M6 bolt.
    The replacement A-pillar plastic fits well enough.
  3. Nov 16, 2023 at 7:51 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Yes I did the one from a engineer for Boeing sells on my 2018
    . I just ordered KTJO4x4. delivery scheduled for 20-N0v-23. I believe that uses the smaller screw that 3JOH22a is talking about. I'm not too worried about the screw that comes W/kit. I read that they re engineered the trim piece to alleviate the "stress" marks from the original, so I feel if there is/was an issues W/smaller screw they would've changed that too? :notsure: This kit is WAY quicker & easier then the other one, more $$ because you get a NEW trim piece, Rivnut tool included. No cutting, drilling. Even the salesman when he was appraising my 2018 said "wow, I never noticed that the 4Runner doesn't have this & can't believe Toyota doesn't do this" I know tomorrow will be 2 weeks tomorrow since I bought it & when I drive it(very little since work from home now) I can't believe how much it looks like it's just not right!:facepalm::D
  4. Nov 16, 2023 at 8:31 AM
    PennRunner
    Brian
    2023 4Runner
    Would the dealer be willing to install it?
  5. Nov 16, 2023 at 8:47 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    I doubt it due to liability worries. If you buy the KTJO4x4 kit it's literally 15 min start to finish. Remove top bolt, pull off trim, install rivnut, install new trim start top bolt & bottom, then just tighten evenly. done.
    RusPro17 likes this.
  6. Nov 16, 2023 at 9:38 AM
    PennRunner
    Brian
    2023 4Runner
    I'll do it when the newness has worn off!
  7. Nov 16, 2023 at 1:07 PM
    batman900
    batman900 New Member
    2023 TRD-ORP
    I want one of the KTJO4x4 kits but they've been sold out on grey....
  8. Nov 16, 2023 at 2:51 PM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    I saw that BUT click on pg & it's cheaper then the Brown one. At least that's what I found????
  9. Nov 16, 2023 at 3:38 PM
    batman900
    2023 TRD-ORP
    What is pg ?
  10. Nov 16, 2023 at 3:40 PM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Page, Yet it's way more easier then what i did via the Boeing engineer , his was way cheaper. BUT way MORE work. I like what I've seen from this kit, we'll see ,eh!?!
    batman900 likes this.
  11. Nov 16, 2023 at 3:42 PM
    batman900
    2023 TRD-ORP
    Ohhhhhhh the clearance handle, I just noticed that! Good price, I hope it isn't too blemished, I'll probably try it out. Really want the handle.
    LCJ77 likes this.
  12. Nov 16, 2023 at 3:45 PM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Yeah after doing the other mod < 2 weeks driving & I hate NOT seeing that dam handle!!:censored::censored::censored::censored: For Toyota for NOT making that standard ,Eh?!! Cheers My Friend!
  13. Nov 20, 2023 at 9:34 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Just received the KTJ04X4 D/S grab handle kit. I did not see a blemish on trim or handle!:yes:
  14. Nov 20, 2023 at 9:39 AM
    PennRunner
    Brian
    2023 4Runner
    Please report back on how the installation goes.I am always weary of pulling off trim pieces because they never go back the same way.
  15. Nov 20, 2023 at 9:41 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    I did it on my 2018. It was much more work then this kit, no issues with that install.
  16. Nov 21, 2023 at 7:08 AM
    Watch the "Vikings Garage" channel on YouTube, he's going to be dropping a video on this soon.
    Quadjeeper likes this.
  17. Nov 21, 2023 at 7:13 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    The nice thing about this kit is you can see on the new trim where the tabs are to release the current one W/plastic tool they supplied too. I have a whole kit of rim tools but this one will work!
    The pictures are from the previous 4Runner. The kit trim has both upper & Lower built in backing
    djwantke likes this.
  18. Nov 25, 2023 at 9:10 AM
    For your anxiety, Honda Accord cabin filter replacement:
  19. Nov 25, 2023 at 4:57 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    These guys have posted good info for you, and most ppl figure out how to purchase "Jason's bracket" for the lower bolt. I didn't use Jason.
    I did a diy install thread on this subject long time ago, somewhat cheaper and did used an OEM FJ handle from dealership cuz it has greater hand clearance (but if you swap the whole driver pillar trim to match the curved passenger side, then 4R handle is OK). The thing is still going just as strong as day 1
    https://www.4runners.com/threads/5th-gen-driver-pillar-fj-oem-oh-shit-handle.26151/
  20. Nov 30, 2023 at 3:38 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I did the KTJO kit combined with the Jason bracket. I'm very happy with the result. It's rock solid and indistinguishable from OEM.
