Anybody care to guess on my dealer quote for maintenance?
Discussion in '5th Gen 4Runners (2010-2024)' started by Guppy1301, Jul 9, 2025.
  1. Jul 10, 2025 at 5:45 AM
    I just did my plugs, pcv, coolant, serpentine belt and trans fluid for under $250. The $129 for a pcv valve is insanity. It’s a $6 part and takes 5 minutes to change.
  2. Jul 10, 2025 at 5:52 AM
    Or he could cause leaks, excessive oil consumption and reduced MPG. A pcv valve is not a lifetime part.
  3. Jul 10, 2025 at 6:02 AM
    Did the dealer recommend changing the PCV or is that something you asked them to do?
    Also all of those quoted prices are insane. It’s all easy work. Break it up into smaller projects and do it yourself for a couple hundred bucks of parts and fluids.
  4. Jul 10, 2025 at 6:19 AM
    Guppy1301
    Guppy1301 [OP] New Member
    Silver 2019 TRD ORP
    Everything they quoted is what I asked for. I got these quotes because they called me telling me my 2019 4Runner might need service based on their records. I brought my 4Runner there once for a warranty claim. (Nut came off the rear garnish and rolling around in the hatch). I may be doing some work on a 2020 of a friend of mine and wanted to give her an idea of what the dealer would charge her. She has basically only had rotations and 10K oil changes by this same dealer. She's at 100K now and none of the above items have been done. (except oil changes). I've done all the above to my 4runner and other Toyotas.
    Jetbike007x10 and Saker like this.
  5. Jul 10, 2025 at 6:34 AM
    So the quote is in a low-cost state where the minimum wage is $7.25/hr?
  6. Jul 10, 2025 at 8:30 AM
    2019 TRDP w/Kangs brah!
    That just about never happens and you can clean it for free. It’s cheaper than getting another one even if it was free because of the fuel required to go get it and you should have brake clean already. Yes I know youtube authorized mechanics are pretty convincing.
  7. Jul 10, 2025 at 8:52 AM
    Didn’t the discussion on replacement of the 4runner PCV get beat to death in the other thread?
    We’re lucky. Other manufacturers design stuff meant to keep you coming into the dealer. Another thread brought up the BMW engine in the Grenadier that has the PCV system built into the valve cover. And it apparently fails regularly. And it throws codes that put you into limp mode when it does. Fixing it costs thousands in labor. Each time.
    5th gen owners on the other hand, have to decide if we should replace it for less than 10 bucks, or just leave it be. These are the good old days!
  8. Jul 10, 2025 at 10:27 AM
    LOL so you will clean a $6 part as opposed to replacing it? There is a rubber O-ring in there so yeah, you keep spraying brake cleaner in there. Clean a $6 part (OEM) $3.61 on Rock Auto. Freaking hysterical. I guess you could also technically clean spark plugs, air filters, etc.
    Also, that youtube video I referenced in previous posts about PCV, wasnt a youtube mechanic. He is a 4R owner and a master toyota technician. Educate yourself
  9. Jul 10, 2025 at 10:29 AM
    K.
  10. Jul 10, 2025 at 10:51 AM
    Wonder when Dealers will start using Affirm/Klarner to break down these service costs over 4 payments?
    whippersnapper02 likes this.
  11. Jul 10, 2025 at 10:57 AM
    Not related to this thread or Toyota at all, But the PCV being brought up made me think of this conversation I had with a neighbor regarding a recall he had mentioned during the 4th of July. Got me researching and I found the below for information purposes only.
    Subaru issued recalls for certain 2017-2019 Impreza and 2018-2019 Crosstrek models, as well as 2019 Ascent, Crosstrek, and Forester vehicles, due to a faulty Positive Crankcase Ventilation (PCV) valve. The PCV valve can separate, potentially allowing parts to enter the engine, which can lead to a loss of power while driving and increase the risk of a crash. Subaru will inspect and replace the PCV valve, and if necessary, the engine, free of charge.
    Details of the Recall:
    • Affected Models:
      • 2019 Crosstrek, Forester, and Ascent vehicles
      • 2017-2019 Impreza and 2018-2019 Crosstrek models
    • Defect:
      The PCV valve, made of aluminum, may crack and separate, potentially releasing debris into the engine.
    • Safety Risk:
      The separation can cause a loss of engine power while driving, increasing the risk of a crash.
    • Recall Actions:
      Subaru will inspect the PCV valve and replace it if needed. If debris has already entered the engine, Subaru may replace the short block engine.
    • Notification:
  12. Jul 10, 2025 at 11:08 AM
    Luckily we don’t have any of those issues to worry about.
  13. Jul 10, 2025 at 11:13 AM
    Makes me wanna research why/how a location was chosen that could potentially damage an engine by freaking coming apart. WTF
  14. Jul 10, 2025 at 11:20 AM
    Engineer 1: Ok putting the PCV here.
    Engineer 2: Yeah whatever.
    YT Certified Mechanic: CHANGE IT EVERY STARTUP OR ELSE!
    Turd Ferguson likes this.
  15. Jul 10, 2025 at 11:30 AM
    All the good engineers retired and they replaced them with recent graduates to save money?
  16. Jul 10, 2025 at 5:19 PM
    lol. Are you new to cars? You must be. PCV valves have been around for 50 years. Just stop, you sound stupid
  17. Jul 10, 2025 at 5:26 PM
    How did you get that from my response? I also quoted someone else. Who are you?
  18. Jul 10, 2025 at 5:27 PM
    Jetbike007x10
    Jetbike007x10 Started this right?
    Scott
    Lee county Florida
    4Runner TDRpro
    TRD hood with hood scoop.TRD lighted gril, fang lights, AVS lighted bug deflector , cold air intake, Body Armor rock sliders. Fuel Rebar rims 17” , Toyo Open Country ATIII 35x12.50r/17LT ,6” Fabtech lift with dirt logic 2.5 shocks with reservoirs,coilovers Dirt logic 2.5 rear shocks with coil overs Factor 55 adjustment control arms.Flow Master outlaw cat back exhaust.Cali raised premium root rack, Cali raised ladder,Cali raised 42” blue backed spot beam light bar. Body Armor high line hidden wench front bumper.Ridged 20”blue backed light bar. Cali raised hidden grill light bar bracket.30” ridged blue backed light bar.32” Cali raised blue backed light bar , 4 Runner lifestyle rear window molle panels, Rago fabrication upper molle shelf ,Ridged DDS pro ditch lights , Diode blue led replacement bulbs in all interior lights. Carbon fiber overlay on all trim inside and out,Cargo complete cover mats. Weather tech floor Matts , Morimoto Stealth Tail lights, morimoto 3rd brake light replacement weather tech side window rain covers.Full dash mounted Rago electronic plate.with Ram mounts for IPad,phone, and GPS.Chip it speed chip. Bluetooth speed chip full vehicle function monitor.Full Razor leather seat covers.Yoto gearshift knob.Morimoto under dash led floor lights.blue.
    700
  19. Jul 10, 2025 at 5:31 PM
    #49
    Jetbike007x10
    Scott
    Lee county Florida
    4Runner TDRpro
    Holy shit. Glad I bought that fluid transfer thing on line
  20. Jul 10, 2025 at 6:41 PM
    #50
    And somehow I’ve never had to change one on any vehicle I’ve owned. :notsure:
  21. Jul 10, 2025 at 7:22 PM
    #51
    fuggg thats insane!
    Guppy1301[QUOTED][OP] likes this.
  22. Jul 11, 2025 at 11:59 AM
    #52
    Engineer 1 fucked up with the PCV location on the 2GR-FKS
    Engineer 2 didn't notice, was too busy making sure the seatbelt buckle still worked...
  23. Jul 11, 2025 at 12:01 PM
    #53
    Well the entire engine is fubar.
  24. Jul 11, 2025 at 12:05 PM
    #54
    ^I'll take the forged crank, forged con rods, piston oil squirters, and 7200-rpm redline. Lack of smog pump is a plus too.
  25. Jul 11, 2025 at 1:34 PM
    #55
    My uncle has it in his RX. Just seems like it’s missing bottom end power.
  26. Jul 12, 2025 at 10:24 AM
    #56
    ^Yes, the 1GR sounds like it'll explode above 3k. The 2GR begins to wake up above 3k.
  27. Jul 12, 2025 at 10:33 AM
    #57
    The throttle is surprisingly touchy in that car too. Like they combined all the pedal pretenders set to their max. That’s not even in sport.
  28. Jul 12, 2025 at 11:45 AM
    #58
    CLL88
    CLL88 New Member
    Cheryl
    Central Illinois
    2022 Black 4Runner TRD Pro
    ...or maybe the women will realize they can do it themselves ;-) Just sayin'
  29. Jul 12, 2025 at 1:25 PM
    #59
    Guppy1301
    Silver 2019 TRD ORP
    Yep! Would be my kind of girl!
  30. Jul 14, 2025 at 5:34 PM
    #60
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    None of that seems to be a rip off. Maybe the coolant one is high? I don't know certainly have seen way worse.
