Another tire recommendation request thread
Discussion in 'Wheels & Tires' started by Montanawildlives, Mar 26, 2024.
  1. Mar 26, 2024 at 6:30 AM
    Montanawildlives
    Montanawildlives [OP] New Member
    I should be picking up my new 4R in the next couple of days and am thinking of asking my dealer to swap out the Dunlop Grandtrek AT20s with something else. My uninformed impression is that they are too much "highway" tires and counter to the advanced 4x4 system in my ORP.
    Now, most of my driving is highway or in town, maybe 80%, with 19% on good gravel roads. It is the last 1% that bothers me. Once a month or so, I find myself on a rough road, foot-deep ruts (which can mostly be avoided with careful tire placement), steep inclines, water over the road, etc.
    It would also be great to avoid having to swap out winter tires, so something that is snowflake rated would be great.
    I would probably need to choose between the tires that the dealership offers in-house. These would be:
    Dunlop AT20s
    Bridgestone Dueler H/T 684 II
    General Grabber HTS60
    Nitto Terragrappler G2
    Yokohama Geolander H/T G056
    Yokohama Geolander A/T G015
    Goodyear Wrangler Steadfast H/T
    Goodrich Trail Terrain T/A
    Yokohama Geolander X-AT
    Toyo Open Country A/T III
    Nitto Terra Grappler
    Bridgestone Alenza A/S Ultra
    Goodyear Wrangler Duratrac RT
    Michelin Defender LTX M/S2
    Firestone Winterforce 2 UV
    I was looking at Duratrac RTs, but saw that Goodyear recommends them for 70% off road and 30% on road. I think this is too far biased toward off road.
    BF Goodrich Trail Terrain T/As seem to be snowflake rated and maybe not as aggressive as Duratrac RTs?
    Or, given that 99% of my driving is highway/in town/easy gravel, should I just stick with the Dunlops and be a careful for that 1-2 hours a month when I might wish I had something more aggressive?
    Thanks for any advice.
  2. Mar 26, 2024 at 6:58 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    From that list, my choice would be Toyo ATIII
  3. Mar 26, 2024 at 7:05 AM
    2020 4Runner
    2020 4Runner New Member
    Fl
    +1. Toyo Open Country ATIII's.
    wax poetic, SlvrSlug and Curt73 like this.
  4. Mar 26, 2024 at 8:15 AM
    Montanawildlives
  5. Mar 26, 2024 at 8:41 AM
    wax poetic
    wax poetic New Member
    21 Super White TRD OR
    OEM+ Trail Edition rims w/ Toyo AT3 in stock size OEM Heritage Grill OEM Black Valences (f + r) Westcott Sliders/Modular Roof Rack Roam 95L case DIY sleeping platform
    I have the Toyo's and would recommend +2
  6. Mar 26, 2024 at 1:56 PM
    Montanawildlives
    That's Toyo ATiii = 3, every other tire in the world = 0
    Turns out that within 1000 miles, they will change them and give me $100 credit per tire. They are also running a buy 3 get 1 free sale, so even with their somewhat inflated prices it will cost around $500 to swap them out.
    Thanks.
  7. Mar 26, 2024 at 1:59 PM
    wax poetic
    Who's running that deal right now? I need a new set real soon
  8. Mar 26, 2024 at 2:02 PM
    Montanawildlives
    It's my Toyota dealership, Portland zone through the end of the month but nationwide in April (so I was told). Their prices do seem a bit higher per tire than other places, but with the 3/1 deal it works.
  9. Mar 26, 2024 at 2:32 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    KO2s
    Gstick likes this.
  10. Mar 26, 2024 at 2:48 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Directly from how many positive reviews I've read about on this website alone
    hossler1788 likes this.
  11. Mar 26, 2024 at 3:18 PM
    brodeyo
    brodeyo New Member
    Cincinnati, Ohio
    2024 Black TRD Pro
    RCI Skids Sliders, Wescott Designs Lift
    Just ordered toyos
  12. Mar 26, 2024 at 3:40 PM
    4Daughters
    4Daughters It’s how I know God has a sense of humor
    Ken
    Powder Springs, Ga
    2022 TRD ORP; Silver; too many port options...Ah well...
    TBD
    These two are on my short list for the April sale. Both have great reviews. Love the look of the Toyos. Cold truth is that I spend so much time on pavement. Would Toyos be a bad choice for 95% pavement?
  13. Mar 26, 2024 at 4:14 PM
    TrailSpecial22 New Member
    PA
    I only use Falken WP’s. All of my 4rnrs past and present only had Falkens and I’ve had zero complaints for the past 10+ years
  14. Mar 26, 2024 at 5:30 PM
    Montanawildlives
    Yes, this is the question!
    I was thinking that having too much all-terrain-iness on road is a minor inconvenience (noise, etc.), while having too little when you need it (even if it is 5% or 1% of the time) could be a serious issue.
    I do wonder if there is something that would be a bit less all-terrain-y though. Something that would give a bit of a boost off road but not sacrifice too much on road, for those of with 95% on/5% off kinds of ratios.
    4Daughters[QUOTED] likes this.
  15. Mar 26, 2024 at 6:53 PM
    Good thinking,
    With that on kind, give the General Grabber HTS60 in your list a look. Sounds like a off-road kinda looking highway terrain (H/T) could suite you best.
    Was was this close to buying 285/70 General Grabbers All Terrains before I bought Mickey Thompsons. They’ve had great feedback in Canada, long running, and made by Continental
  16. Mar 26, 2024 at 7:12 PM
    @Montanawildlives
    The mountain logo on the webpage ^ has a sun behind it, oops not winter rated.
    The Grabber APT have the 3-Peak Mountain Snowflake. Don’t see as many H/T with the snowflake, but plenty of lesser aggressive A/T’s have it
  17. Mar 26, 2024 at 7:20 PM
    4runningMan
    4runningMan New Member
    New Mexico
    I recently got the newest version of the MS2 and they’re fantastic. Great wet/snow traction. Quiet.
    The new version is an XL rated tire and they’ve beefed up the sidewalls. They are stiffer sidewalls than the old version. And the tread is almost a sticky rubber. They’re awesome tires. Balanced great.
  18. Mar 26, 2024 at 7:24 PM
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
    Great to hear! They get decent off road reviews also. Sort of a stealth AT?
  19. Mar 27, 2024 at 8:02 AM
    4runningMan
    New Mexico
    They feel far tougher to me than the Dueler HT’s. Comparison isn’t even close. Much stiffer sidewalls it seems.
  20. Mar 27, 2024 at 8:07 AM
    laxman09
    laxman09 New Member
    Mahoning Valley, OHIO
    Ill be getting the MT Baja Boss AT come this fall.
    djwantke likes this.
  21. Mar 27, 2024 at 8:41 AM
    Those tires aren't on the list but I'm sure OP thanks you very much. I mean it's not like he just said he does not want aggressive all terrains.
    As @glwood54 would say, this isn't helpful :p
    glwood54 likes this.
  22. Mar 27, 2024 at 9:06 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I vote for Michelin Defender LTX M/S2...these tires are excellent and they last a long time. My dad has them on his frontier and he has well over 70k miles on them. They're great for all weather conditions
    Since your not looking to go offroad much id say they be perfect.
  23. Mar 27, 2024 at 10:42 AM
    laxman09
    laxman09 New Member
    :sadviolin:
    djwantke[QUOTED] likes this.
  24. Mar 27, 2024 at 11:47 AM
    It’s comments like yours, on threads that I post and contributions I make to the community, that really tick me off.
    So you don’t read OP’s post, don’t read the comments, don’t read his comments to the comments, and you write: hey everyone guess what I’m thinking of buying one of the most aggressive all terrains you can buy, in a year, maybe.
    Plz respond
    lincmarkv likes this.
  25. Mar 27, 2024 at 12:23 PM
    4runningMan
    New Mexico
    I meant to say the new MS2 feel tougher than the Dueler AT (not HT)
    4Daughters likes this.
