Alignment on '22 TRD off road
Discussion in 'Suspension' started by bbak11010, Feb 8, 2022.
  1. Feb 8, 2022 at 9:27 AM
    bbak11010
    bbak11010 [OP] New Member
    Hey all,
    Recently went into Firestone to get my alignment after lifting and new wheels. They said they don't have the spec sheets for the year '22 yet and not able to use the previous years spec sheet to do the alignment. They said Toyota usually takes about a year to release it.
    I haven't used other local shops for alignment but do you think there's a chance that smaller shops might get it before franchise stores? Has anyone done their alignment on the '22?
    Thanks in advance!
    Toy4X4 likes this.
  2. Feb 8, 2022 at 9:39 AM
    Thepremier141
    Thepremier141 Member
    Nate
    Northern California
    ‘22 SR5P
    I had one done at Big O tires on a '22 about 2 weeks ago.
  3. Feb 8, 2022 at 9:50 AM
    bbak11010
    Thanks! There's only one Big O tires where I'm at, but they're closed permanently. At least it gives me hope that the spec sheets are out there!
  4. Feb 8, 2022 at 10:06 AM
    Thepremier141
    Nate
    Northern California
    ‘22 SR5P
    I don't know if this is correct, but I would imagine it's the same specs as a '21. I know your Firestone said they can't use last years, but I suspect certain shops will.
  5. Feb 15, 2022 at 10:07 PM
    homesteader
    homesteader New Member
    2022 4Runner TRD OR lunar rock w/KDSS
    I’ll be doing an alignment soon after my lift. I talked to the mechanic of a small shop and he also said they may not have the specs for the 22. I’m hoping it will be the same as the 21’s. I can’t see how they would be different.
  6. Feb 16, 2022 at 1:42 AM
    bbak11010
    I got mine done from Les Schwab. They inly had '21 spec sheet but were able to do it.
  7. Feb 16, 2022 at 3:17 AM
    After lifting and such, you will want to add some extra caster so it will be a "modified spec.", so the '22 alignment specs are irrelevant, camber and toe in might be the same, but caster should be close to 4.0 on the positive, to add stability at highway speeds. The factory spec. can be improved upon in your situation.
