Aftermarket Wheels
Discussion in '5th Gen 4Runners (2010-2024)' started by Gmbler931, Feb 3, 2021.
  1. Feb 3, 2021 at 5:18 AM
    Gmbler931
    Gmbler931 [OP] New Member
    2011 4runner 4wd
    I currently have a set of xd 17" wheels on my 2011 4runner 4wd.
    The minus 12 offset is causing issues with proper torquing and fitment and I need to find something closer to factory specs. I despise the look of the TRD wheels and need a 17" or 18" black wheel that has worked for others without spacers or large lifts. My 4runner is leveled and I'm currently running a 265'-70'-17 tire. Any suggestions?
  2. Feb 3, 2021 at 7:06 AM
    Welcome to the forum, post up a pic. of your wheels so we can see what you got, thanks.
  3. Feb 3, 2021 at 8:02 AM
    Gmbler931
    2011 4runner 4wd
    Thanks for the welcome. I don't have a picture to post but my current wheels are the problem. Factory 4runner wheels have plus 12 offset and my current set have minus12 and are causing issues with mounting flush and getting the wheel properly torqued. I'm just looking for others who've used aftermarket wheels with no issues and what they recommend. I'm not opposed to factory wheels but the only ones I've seen in black are the TRD wheels which look terrible in my opinion.
  4. Feb 3, 2021 at 8:15 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Wheel offset has nothing to do with mounting and torquing, per se. The only way offset could affect mounting is if it was so high that the barrel of the wheel or tire was hitting your fender / suspension before the wheel could be mounted on the hub.
    Most likely, you have wheels that are not hub-centric, or you are trying to use lug nuts that are not compatible with the wheel.
    If the former, hub-centric rings will suffice. For the latter, new correct lugs.
  5. Feb 3, 2021 at 8:56 AM
    Gmbler931
    2011 4runner 4wd
    My mechanic says it's actually the center caps that XD said to cut notches in so it would fit over the hub. That worked but it caused the wheel not to mount completely flush as a result. I'm just looking for some suggestions for wheels others have used that don't require any modifications for a proper fit.
  6. Feb 3, 2021 at 9:41 AM
    https://www.blackrhinowheels.com/off-road-wheels.php
  7. Feb 3, 2021 at 9:46 AM
    catus
    catus New Member
    Centennial, CO
    2019 Tundra Double Cab TRD Limited
    No major mods yet
