Aftermarket Skids - KDSS and Diff Drop
Discussion in '5th Gen 4Runners (2010-2024)' started by LA260, Mar 27, 2021.
  1. Mar 27, 2021 at 1:04 PM
    LA260
    LA260 [OP] New Member
    I'm looking to get aftermarket skids just so that I don't have to deal with removing the skids to change the oil filter. It's a hassle specially with spacers that must be used with diff drop! Wondering which of the skid plates besides RCI will work with KDSS and diff drop 100%.
    Crossfit4Runner likes this.
  2. Mar 27, 2021 at 1:33 PM
    Mtbpsych
    Mtbpsych New Member
    Is this a KDSS only thing with needing spacers for the skid plate and/or diff drop?
  3. Mar 27, 2021 at 1:56 PM
    LA260
    AFAIK it's not KDSS only thing.
  4. Mar 27, 2021 at 2:01 PM
    Mtbpsych
    Mtbpsych New Member
    I have a diff drop and have never had to remove any kind of spacers? It takes like 2 minutes to undo the bolts for the skid plate to access the oil filter. Just trying to make sense of what you’re trying to accomplish. Do you have spacers on your skid plate?
    A&P and Thatbassguy like this.
  5. Mar 27, 2021 at 2:16 PM
    Some skids are not compatible with KDSS. As far as I know, most are compatible with diff drops. I think this question applies to anyone with KDSS and a diff drop.
    I have KDSS but no diff drop. I only lifted 2.3" so it wasn't necessary. I can tell you that the SOS skids I bought were NOT compatible with KDSS. this led to me having a custom front skid built, which actually ended up better overall for me.
    I believe RSG makes a KDSS skid, but can't confirm whether it's compatible with a diff drop. A few other manufacturers do as well. Your best bet is to confirm fitment with the manufacturer. I learned this the hard/expensive way.
  6. Mar 27, 2021 at 2:54 PM
    Mtbpsych
    Mtbpsych New Member
    Ahhhh thanks for clearing that up! What about OEM? It sounds like OP has an OEM skid and is trying to go aftermarket to make things easier?
  7. Mar 27, 2021 at 2:55 PM
    LA260
    Yes. I do have spacers on my skid plate. Without the spacers the skid cannot be installed. This is with Dobinson diff drop kit. Other kits may not need spacers I'm assuming.
    Yup. I'm trying to avoid getting a skid and finding out that it wont work with my setup. I just trust an actual owner vs what the manufacturer has to say as far as fitment goes. Learn that the hard way lol (not 4runner related but still)
  8. Mar 27, 2021 at 3:03 PM
    The OEM skids don't hold up well to regular use. :D after a few trips in some rocky trails, mine had definitely had enough.
    I wish I could be more help. But, I haven't really heard of any manufacturers saying things were compatible when the weren't.
    A&P and Mtbpsych[QUOTED] like this.
  9. Mar 27, 2021 at 3:38 PM
    Dark Knight
    Dark Knight Get off my lawn
    Victory4x4 skid was perfect for my kdss application.
  10. Mar 27, 2021 at 4:12 PM
    LA260
    Thanks. Do you also have a diff drop?
  11. Mar 27, 2021 at 4:46 PM
    Tuco S.
    Tuco S. New Member
  12. Mar 27, 2021 at 5:21 PM
    Dark Knight
    No but I have the treaty oak Offroad kdss spacers.
    victory4x4 was very responsive to questions I had. Give them a shout, I bet they can answer any questions quickly.
  13. Mar 29, 2021 at 7:08 AM
    Crossfit4Runner
    Crossfit4Runner New Member
    Saint Louis
    2018 TRD Off Road Permium
    To many to list
    I went with RCI non KDSS
  14. Mar 29, 2021 at 7:17 AM
    Do you have KDSS and a diff drop?
    That is what the OP is asking about; skids that are confirmed compatible with both KDSS and a diff drop.
    Mtbpsych likes this.
  15. Mar 29, 2021 at 7:31 AM
    Crossfit4Runner
    Saint Louis
    To many to list
    As stated non KDSS yes I do have a diff drop. RCI makes skids for both KDSS and non KDSS
  16. Mar 29, 2021 at 7:53 AM
    Right. But the OP is looking for confirmed fitment with KDSS and a diff drop. Just wanted to confirm.
  17. Mar 29, 2021 at 8:04 AM
    DRH
    DRH TRD Broverlander Extraordinaire
    Dave
    Santa Clarita, Ca
    2020 ORP
    The skids that leave the frame supports in place will work with a diff drop without spacers. If the skid requires the frame members to be omitted, spacers will be required to get the clearance.
  18. Mar 29, 2021 at 9:34 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    ^ I'd say that is too simple a generalization.
    The entire design of the skid plate must be taken into consideration.
    Once you start looking *really* closely at the various aftermarket skid plate designs, you'll notice that they all achieve what they want in different ways.
    OP just needs to start looking at skids and come up with some wants. Then confirm here or with manufacturer differential clearance. Since not all "diff drops" are equal, it may be a bit of a gamble in the end.
    There is a good thread on the other 4Runner forum that lists just about every skid available. There was another good thread here, a few weeks back, that also had a lot of good info.
    Can't help much off the top of my head because I'm non-KDSS, and as such, wasn't paying any attention to low-hanging KDSS compatible skids. :p For me (non-KDSS), the contenders were TRD Pro, M.O.R.E., HeftyFab, C4 Fabrication, and RCI.
  19. Mar 29, 2021 at 2:55 PM
    LA260
    Thanks for the suggestions. I like CBI and C4 and considering the insane shipping costs for CBI I like C4 a little more. Sent both emails re my question.
  20. Mar 29, 2021 at 7:52 PM
    Tuco S.
    Tuco S. New Member
    C4 is currently quoting a 15 week lead time, just fyi.
  21. Mar 29, 2021 at 8:34 PM
    DRH
    Dave
    Santa Clarita, Ca
    2020 ORP
    Whatever brand you go with be sure to do the lift first because it drops the clearance down. I have a few marks from misjudging the clearance loss before I could get the 3" lift done.
  22. Apr 27, 2021 at 9:11 AM
    LA260
    I'm most likely going to go with RSG. C4 doesn't even quote delivery dates anymore and CBI's shipping $$ is just crazy. Just need to find out if Fumoto valve can be accesses without removing the RSG Skid. The hole looks kinda small..
  23. Sep 6, 2021 at 7:05 PM
    HornedOwl
    HornedOwl New Member
    Washington State
    I have KDSS, diff drop and installed the RSG skid plate today. Fits great.
  24. Nov 23, 2021 at 7:57 AM
    El Tibu
    El Tibu New Member
    Angel
    Ottawa
    2018 Black TRD OFF ROAD
    Morimoto Elite H11 HID System 35W (6500K) Diode dynamics ss3 sport fog lights Diode dynamics sl1 (high beam - 9005) Pure 4runner - TRD 4Runner OFF ROAD Black-out Badge Coverlay Kit 2018+ MBRP PRO Series ( S5342304) Toyota 2.5" Cat Back Exhaust HID Kit led interior & exterior bulbs MESO Customs 4 puddle pods Gear America (2pk) D Ring Shackles Red Husky Cargo liner Weather tech 1st and 2nd row floor liners iJDMTOY Smoked Dark Lens 9-LED 3rd Brake Light Assy Vehicle OCD - Center Console Organizer JoyTutus Glove Box Organizer Compatible for 4Runner PCS Smoked Shell white Led Grille Lights Kit JDMCAR Center Console Organizer AVS 94242 Original Vent Visor Side Window Deflector Dark Smoke, 4-Piece Set LASFIT 921 912 T15 CANBUS Error Free LED Reverse Back Up Light Bulb LASFIT CANBUS Anti Hyper Flash 7443 7444 T20 Dual Color Switchback LED Amber Turn Signal Light Blinker Bulbs, White Daytime Running Parking Light LASFIT 7440 Anti Hyper Flash Canbus LED Turn Signal Light W21W WY21W Blinker Bulbs Treaty Oak Offroad recovery points RCI Rock sliders.
    Hi there , I have KDSS with an RSG skid plate, what I like to know is what brand of diff drop did you install? Also to all you out there who have an RSG skid plate a Fumoto oil drain valve can be installed and can be accessed without taking off the skid plate. There is a pre drilled hole in the plate where you can access the Fumoto valve.
    Thanks.
  25. Nov 23, 2021 at 11:54 AM
    HornedOwl
    Washington State
    Just a basic no name drop. I believe is something like this off Amazon-
    https://www.amazon.com/KSP-Machined...&hvlocphy=&hvtargid=pla-4584207577333600&th=1
    El Tibu[QUOTED] likes this.
  26. Nov 23, 2021 at 12:00 PM
    A diff drop is not needed ever.
  27. Nov 23, 2021 at 12:02 PM
    HornedOwl
    Washington State
    I put a 23" preload on my kings though
  28. Nov 23, 2021 at 12:07 PM
    The effect from a diff drop is minimal on the CVs and the drop rotates the diff down which pulls some lube away from the pinion bearing. If the front diff bearings are going to fail, they're going to fail. There's a thread now in T4R where it failed even after the ECGS bushing was installed
  29. Nov 23, 2021 at 12:49 PM
    I’ve compared my 4runner with a diff drop to a friends 4Runner with same lift height and no diff drop and there was a substantial difference in the cv angles. Her cv angles were much more pronounced.
  30. Nov 23, 2021 at 12:58 PM
    HornedOwl
    Washington State
    I was kidding by the way
    whippersnapper02 likes this.
