Aftermarket radiator question
Discussion in '2nd Gen 4Runners (1990-1995)' started by Hooligan80, Nov 19, 2021.
  1. Nov 19, 2021 at 7:55 PM
    Hooligan80
    Hooligan80 [OP] New Member
    95 4runner 22re
    I have a 95 4 runner 22re was wanting to go with a new aluminum radiator and electric fan. Anyone have any recommendations on what radiator fits and electric fan setup
  2. Nov 20, 2021 at 7:03 AM
    Ahdofu
    Ahdofu New Member
    Matt
    I have used Champion products (championradiators.com) albeit w/o an electric fan.
  3. Dec 4, 2021 at 4:50 AM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    G-Plus 2 row core radiator with 16" Zirgo S-blade fan. Derale thermal switch kit is threaded into 90° brass bung fitting and is supplied with a relay to power the fan. Acrylic panel was later switched out to aluminum due to cracking. Shroud was made from some aluminum U channel. The only adjustment needed was to hog out the through holes to get the radiator to sit a little lower down so the cap and bonnet would clear. With the OEM clutch fan removed from the dummy shaft this fits like it was OEM. Fan cycles perfectly with traffic and when running in sand dunes or while doing 4 low range trail runs.
