Aftermarket ET Lug Nuts on Factory Spare Wheel
Discussion in 'Wheels & Tires' started by 1SilverRunner, Mar 18, 2024.
  1. Mar 18, 2024 at 11:52 AM
    1SilverRunner
    1SilverRunner [OP] Long time listener, first time caller
    Da Earf
    TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar *coming soon Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Rock Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken AT4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. MinWin End Caps Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Performance: Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Garmin Dash Cam Mini II with Dongar power solution Ram ball mount for Garmin In-Touch Mini II Scosche phone mount Misc: Ceramic Tint (Including windshield and sunroof) Cali Raised 27W Ditch Lights Midland MXT575 and Ghost Antenna AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    TLDR: Is it safe to use RRW's ET lug nuts on the factory spare wheel? My guess is no...
    The lug nuts I'm referring to are RRW's Hex closed end lug nuts (12x1.5 ET):
    https://www.relationsracewheels.com/collections/toyota-4runner/products/hex-closed-end-lug-nuts
    The reason I ask; Yesterday I was going down a muddy road and picked up a chunk of steel hidden in a puddle. Swapped to the spare in less than 15 minutes in the mud. When I was tightening my lugs I noticed there was very little surface contact between the lug nuts and the wheel itself. I was comfortable enough to limp the car home at low speeds.
    My intuition tells me I'll need to carry some factory lug nuts in the future.
    Looks like these lug nuts are specific to RRW's ET design. Can anyone confirm this?
    Here are some photos for reference.
    From 37 to 0 PSI in no time.
    3" gash in the tire.
    Bottle Jack Buddy allowed me to safely jack up the rig from the rear axle. If you're lifted, buy a bottle jack buddy. You can thank me later.
    Pizza cutter 255/80/17 installed with RRW lugs. Worked good enough to get me home.
    Felt secure enough. No vibrations. Still, this felt a little sketchy because of the minimal contact between the lugs and the wheel. I will add 6 factory lug nuts to my jack/ tool compartment asap.
    Feel free to tell me how stupid it was to drive home with this. Genuinely would like to know.
    PS: I did contact RRW to see what they would say about the compatibility here. I imagine it will take a while for them to write back and say "You shouldn't do this"
  2. Mar 18, 2024 at 11:55 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Falken Wildpeak 265/70R/17 load E
    Visually, they don't inspire confidence.
    1SilverRunner[OP] likes this.
  3. Mar 18, 2024 at 11:57 AM
    1SilverRunner
    Da Earf
    Agreed. Glad this happened close to home not in the middle of a proper trail in a different state!
    :rofl:
  4. Mar 18, 2024 at 1:10 PM
    1SilverRunner
    Da Earf
    Just picked up some Dorman m12-1.5 lug nuts. PN: 611-182.
    Swapping these out before I head to NTB.
    These will be staying in the rig from now on.
    3JOH22A likes this.
  5. Mar 18, 2024 at 2:48 PM
    1SilverRunner
    Da Earf
  6. Mar 19, 2024 at 11:44 AM
    1SilverRunner
    Da Earf
    An entire brake pad was pulled out of the tire^
    Went ahead and replaced both rear tires with new Nitto Ridge Grapplers. Sticking with 285/70/17s for now... Although I was tempted to use the opportunity to upgrade to 34s...:bored:
  7. Mar 19, 2024 at 11:52 AM
    1SilverRunner
    Da Earf
    RRW got back to me and said "They do not recommend this"
    Worked good enough to get me home... but I'll avoid this in the future.
    Stock style lugs will be in the glove box from now on.
    :tinfoilhat:
  8. Mar 19, 2024 at 12:51 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I keep 6 factory lugs (for the spare) with my jack. I went through the same thing your going through before.
  9. Mar 19, 2024 at 1:50 PM
    backpacker
    2023 TRD ORP
    I almost commented on that. WTF was a brake pad doing sticking up in the bottom of a puddle?
  10. Mar 19, 2024 at 2:00 PM
    1SilverRunner
    Da Earf
    Right? I'm just that lucky I guess :facepalm:
  11. Mar 21, 2024 at 11:39 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    I mentioned this to Dustin at FN Wheels and he agreed with carrying factory lugs in case the spare was needed
    Probably fell off a Jeep...
