Adding Kings And Icon
Discussion in 'Suspension' started by Braves95, Apr 26, 2019.
  1. Apr 26, 2019 at 2:37 AM
    Braves95
    Braves95 [OP] New Member
    David
    2019 Nightshade Special Edition MGM
    None Yet!!
    Adding Kings front and rear w/ click adjusters. Adding the Icon 52700 springs in the rear.
    My question is if the Icons state it's a 2 inch lift, does that mean if I want the runner to be level I need to set the kings to 2.5 inches? Or am I'm not thinking right?
  2. Apr 26, 2019 at 3:22 AM
    Agent_Outside
    Built 2011 T4R Limited
    if you lift both 2” it will sit the same as it did when stock, just higher.
    SlvrSlug likes this.
  3. Apr 26, 2019 at 3:34 PM
    About 3" to front will be needed to be level with the 2" in the rear.
  4. May 8, 2019 at 8:14 AM
    antwan_TLR
    antwan_TLR New Member
    Your front is 20 inches and the rear is 22 inches at stock height from the center of the wheel hub to the edge of the fender. So a 3/2 lift will set it at 23 inches and 24 inches in the back with rack in the rear which is recommended.
    nimby likes this.
  5. May 8, 2019 at 8:49 AM
    I had my Kings set for 2.5” in the front, and used OME 2” longer springs in the rear. I like the rear just a bit higher. From center of wheel to fender i have 22.5” front, 24.75” rear95F70084-A588-407D-8F40-184279CA45DA.jpg
    jgcaps, WallyT4R, nimby and 1 other person like this.
  6. May 8, 2019 at 8:54 AM
    Braves95
    David
    None Yet!!
    Wow. I like the stance. How many threads are showing to get the ride height?
  7. May 8, 2019 at 8:55 AM
    Braves95
    David
    None Yet!!
    And what size tires you got. I have the stock 20's
  8. May 8, 2019 at 1:30 PM
    285/70/17 Wildpeak M/Ts i have 6 threads showing
    nimby likes this.
  9. May 8, 2019 at 1:55 PM
    Braves95
    David
    None Yet!!
    And that's giving u 2.5 lift in the front?
  10. May 8, 2019 at 1:56 PM
    Braves95
    David
    None Yet!!
    Also does the 4runner have the taco lean?
  11. May 8, 2019 at 2:43 PM
    yes
  12. May 8, 2019 at 3:18 PM
    Yes.
    Braves95[QUOTED][OP] likes this.
  13. May 8, 2019 at 6:23 PM
    Braves95
    David
    None Yet!!
    Great! Thanks for the info.
  14. May 22, 2019 at 2:55 PM
    Heather4Runner
    Heather4Runner New Member
    Heather
    2019 4Runner TRD-off road
    Can you list a total of everything you got for your kit?
    I got a quote for :
    Total Chaos Front UCA
    King Shocks Rear Shocks remote reservoir w/ adjuster
    Toytec rear 2" lift springs superflex
    King Shocks Front Coilover with 700 lb springs remote reservoir w/adjuster
  15. Sep 21, 2020 at 6:24 PM
    willch
    willch New Member
    will
    700lb is heavvvy on the front coils unless you plan on adding a shit ton of weight
    AccuTune Offroad likes this.
