Adding 2-3 inches without a full lift kit?
Discussion in 'Suspension' started by PeteDay70, Jul 11, 2017.
  1. Jul 11, 2017 at 1:34 PM
    PeteDay70
    PeteDay70 [OP] New Member
    Pete
    Denver, CO
    1990 SR5 V6 4Runner
    Nothing yet.
    I'm buying a stock 1990 SR5 V6 this weekend and will be doing a light duty, easy trail build. There is a little bit of rear sag and I would like to run 31s. I'm looking for suggestions regarding lifting it, i.e. best practice for getting 2-3 inches without a full fledged lift kit.
  2. Jul 11, 2017 at 1:35 PM
    PeteDay70
    Pete
    Denver, CO
    1990 SR5 V6 4Runner
    Nothing yet.
    It has 225,000 on the chassis and the engine was replaced under recall at 125k.
  3. Jul 11, 2017 at 11:19 PM
    larramo
    larramo 3ed gen faithfully
    larry
    clearlake ca
    4 runner
    3" lift but mostly all stock not a scratch on it it is pristine condition amazing for being 19 years old.
    performance shocks should give you the lift you are looking for for the rear in the front plastic spacers over the coil springs should take care of the front but they only give 2 inches more clearance any more than that your ride will become stiff and wear out parts faster like u joints and ball joints just good quality ride lifting shocks should do the trick.larramo
  4. Jul 12, 2017 at 8:06 AM
    PeteDay70
    Pete
    Denver, CO
    1990 SR5 V6 4Runner
    Nothing yet.
    Thanks! I figured it would be that easy, still considering new springs all around, just for a refresh.
  5. Jul 12, 2017 at 8:14 AM
    larramo
    larry
    clearlake ca
    4 runner
    trd over size coil springs are the way to go a little pricey but its the right way to do it just be careful when swapping out the old ones if they let go it will rip your head off rent good quality spring suppressor good luck be safe. larry
  6. Sep 2, 2017 at 1:31 PM
    58jake
    58jake New Member
    1990 White 4Runner SR5
    Currently dead
    I think you are thinking about a 1996 and new 4runner. '90-'95 are torsion bar fronts.
    For a basic lift in the front get a ball joint spacer. Rears are just your typical coil spring. I understand stock coils from a FJ80 will give you roughly 3" of rear lift.
  7. Sep 3, 2017 at 5:52 AM
    larramo
    larry
    clearlake ca
    4 runner
    yes but i would not lift it any more than 3 inches and if you put 33s on it let me tell you from experience i did and instantly regretted it they tore up my ball joints and rubbed ageist inter fender walls and that was with a 3 inch lift and made so much noise on the road it was unbearable had to turn the stereo all the way up to drowned out the noise so you might want to think about 285/75/16 that is what i have and they are great. LARRY B.
  8. Sep 3, 2017 at 10:05 AM
    Tg7
    Tg7 New Member
    Ty
    Bend Oregon
    Red 1993 4runner
    2 inch OME lift on 33 inch bfg kos
    Toytech has a 2 inch kit for 1990-1995 4runners for 300. Then get some extended shocks. I'm installing the kit today haha!
  9. Sep 3, 2017 at 5:54 PM
    58jake
    58jake New Member
    Currently dead
    How about some before and after shots?
  10. Sep 4, 2017 at 12:29 AM
    Tg7
    Tg7 New Member
    Ty
    Bend Oregon
    Red 1993 4runner
    58jake likes this.
  11. Sep 4, 2017 at 12:30 AM
    Tg7
    Tg7 New Member
    Ty
    Bend Oregon
    Red 1993 4runner
    I can uplod some more pictures tomorrow of the exact measurements. I will add more pics when I get my 33s on too. Or I can pm you pictures and any information you want
  12. Sep 4, 2017 at 10:15 PM
    58jake
    58jake New Member
    Currently dead
    No need, I can visually see an improvement. My '90 is sitting stock right now on 31's, just wanted to see what the added 2" would do for it. I don't want to get too carried away, it will eventually get a solid front axle and either leaves or links.
    Thanks for sharing the pictures!
  13. Sep 4, 2017 at 11:45 PM
    Tg7
    Tg7 New Member
    Ty
    Bend Oregon
    Red 1993 4runner
    I'm gonna do 1 tons on my runner evenully. I just don't have the time or $ right now. I just did this as a small upgrade to get me by and since I got a good deal on 33s. Your welcome!
  14. Sep 5, 2017 at 12:18 PM
    58jake
    58jake New Member
    Currently dead
    Not to change the subject but, Tg7 what's the story on your ditch light brackets? Bought or did you fab them up yourself?
  15. Sep 5, 2017 at 5:07 PM
    Tg7
    Tg7 New Member
    Ty
    Bend Oregon
    Red 1993 4runner
    They are srq fabrications 3rd gen ditch light mounts. They fit 2nd gen runners as well with no mods. Great quality and super fast shipping
    58jake likes this.
  16. Sep 5, 2017 at 5:08 PM
    Tg7
    Tg7 New Member
    Ty
    Bend Oregon
    Red 1993 4runner
    Then I just have cheep pods until I upgrade to some nicer ones
