A/C drain rust issue from Tacomas also affecting 4Runners?
Discussion in '5th Gen 4Runners (2010-2024)' started by Liv2Ride, Apr 25, 2019.
  1. Apr 25, 2019 at 6:59 AM
    Liv2Ride
    Liv2Ride [OP] New Member
    ’19 MGM Limited
    Eibach Stage 2, JBA UCA’s, K02 - 265/70, Ark guards, Sony XAV9500ES
    Hello fellow 4Runnians. Returning to this tried and true vehicle after selling our '99 limited back in '08. Been in Toyota's since but not a truck platform.
    When looking for a replacement for our '09 Venza was thinking about a Tacoma but after extensive research sounds like quality control is on a downward trend and I really didn't "need" a truck and decided I really didn't want to give up interior space. Now we are proud owners of a '19 MGM Limited AWD...sorry no pics yet since picked up last night and was exhausted from starting the day at 0200. :yawn:
    Been tracking frame rust issues for Tacoma's and the T4R and was wondering if the A/C drain issue on the Tacoma affects the 5th gen. Those from the other side are likely quite familiar with this thread.
    https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/
    Thanks in advance.
  2. Apr 25, 2019 at 10:09 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Welcome! no clue on the rust.
  3. Apr 25, 2019 at 10:12 AM
    brownbear
    brownbear Relax
    Brian
    OB Fl
    2018 4Runner TRD OFF ROAD
    NFab side steps TRD matte blk wheels K&N airfilter, go rhino rear hitch step,
    Welcome from FL.
    ManBeast likes this.
  4. Apr 25, 2019 at 10:43 AM
    Toffees
    Toffees Stuff and things
    Micah
    LA
    16 LE
    Welcome. I’ve got a 16 LE like yours and am not aware of any AC drain rust issues. Just rust issues from salted roads
  5. Apr 25, 2019 at 12:12 PM
    welcome
  6. Apr 26, 2019 at 6:50 AM
    Liv2Ride
    ’19 MGM Limited
    Thank you for your replies, good to know it is not an issue.
    Thanks to the mods for changing the title of the thread. :thumbsup:
  7. Apr 26, 2019 at 9:24 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    when I do the oil changes and fluid checks grease drive shafts I use a cold galv paint on the frame welds that rust. then the next day apply rustoleum black performance paint . 2016 runner and all is looking good . the rusted welds do require some wire brush work and then the paint.
    on my 96 chev Impala the a/c drain hose was dumping the water on my O2 sensor pass side so I did do that mod to move the drain away from the O2 and frame area.. still have the car and no o2 sensor problems ..
    the old runners surely did have huge frame rust ..
  8. Apr 26, 2019 at 9:59 AM
    2016Pro
    Welcome, I live in Florida. Not familiar with rust.
    Grilla36 likes this.
  9. Apr 27, 2019 at 8:48 AM
    Liv2Ride
    ’19 MGM Limited
    Appreciate the reply. Yeah, saw some pretty bad frame rust on some T4Rs during my research. What cold galv paint are you using?
    Thanks for the welcome. Do you live in a coastal area or more inland?
  10. Apr 27, 2019 at 7:32 PM
    2016Pro
    In tampa about 30 minutes from the beach
  11. Apr 28, 2019 at 9:49 AM
    Liv2Ride
    ’19 MGM Limited
    I used to live a bit north of Tampa, it was home until '93. No rust concerns in that part of the country/state.
  12. Apr 29, 2019 at 7:18 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    2017 T4R Pro 040
    Is plasti-dip a mod?!
    I looked at this as a possible problem too, so I yanked off the heater hose I had put on my Tacoma and routed it on my 4runner. If there is an issue, mine is is good to go. The hose routs a little differently, but it works.
  13. May 14, 2019 at 5:18 PM
    ipnpulz
    ipnpulz New Member
    2023 TRDOR premium T4R
    I grew up in Tampa!
    Not much rust issues but that damn salt air corrosion will tear some stuff up....
    2016Pro likes this.
