A/C Compressor ??
Discussion in '1st Gen 4Runners (1984-1989)' started by Martinjrherrera, May 14, 2019.
  1. May 14, 2019 at 11:12 AM
    Martinjrherrera
    Martinjrherrera [OP] New Member
    Martin
    1986 4runner SR5
    I have a 86 And need to get a/c running. I want to replace to newer freon what all needs to be done to get a/c converted to R134A??
    my compressor seems to went bad and will need to replace as well.
  2. May 14, 2019 at 11:46 AM
    yotagreg8888
    yotagreg8888 New Member
    Greg
    1985 SR5
    OME lift other wise 100 percent stock
    I did my 85 about 8 years ago, had it done with the old freon and it cost me $2300.00, Just a heads up, You will likely need more than a compressor.
  3. May 14, 2019 at 11:51 AM
    Martinjrherrera
    Martin
    1986 4runner SR5
    So you did a full conversion??
  4. May 14, 2019 at 12:01 PM
    yotagreg8888
    Greg
    1985 SR5
    No conversion, just had it restored to working condition, I wanted to convert but the mechanic said it won't blow as cold.
  5. May 16, 2019 at 4:57 AM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    87 4Runner SAS and other stuffs, 07 Tacoma
    Things and stuff and such
    You will need to change the oil in the compressor, the seals, and replace the receiver/drier. You will need retrofit valves for the ports. IIRC you can only charge to 80% with R134a before the seals will blow, so it will not blow as cold when stopped and idling.
    Martinjrherrera[OP] likes this.
  6. May 16, 2019 at 6:34 AM
    Martinjrherrera
    Martin
    1986 4runner SR5
    is there a way I can swap out the whole system and upgrade it to blow ice cold?
  7. Jul 12, 2019 at 8:31 AM
    Mannyac123
    Mannyac123 New Member
    1986 4runner
    mine was converted before i purchased it. It blows pretty cold. Not as powerful as a 2019 or anything, but it's getting me through a houston summer...
  8. Jul 4, 2021 at 5:46 PM
    22 yoga chuck
    22 yoga chuck New Member
    Did my 1985 last year. Total $940 out of pocket, however my compressor was good and I had accumulator already. Putting evap in dash sucked. If I had to do it again I would definitely pay someone.
  9. Jul 4, 2021 at 5:49 PM
    22 yoga chuck
    Oh yeah, and replace ALL the o rings whether they look ok or not. My coolant leaked out 2 times on me because I didn't put in new $.80 o rings
  10. Jul 4, 2021 at 5:51 PM
    22 yoga chuck
    I agree with everyone else replies, it for not blow as cold now as it used to
