A/C “valve” or piston noise near glovebox
Discussion in '4th Gen 4Runners (2003-2009)' started by hotwheels22, Jul 7, 2018.
  1. Jul 7, 2018 at 9:06 PM
    hotwheels22
    hotwheels22 [OP] New Member
    hi all
    at one point i spend an hour or do researching an issue of a “valve” or piston noise coming from the glovebox area. but i can’t recall the term for the part that was acting up.
    the solution was to like turn the AC off then on or on low and then on. unfortunately i didn’t print it out and put it in the owner’s manual.
    anyone run across this or have a search term i could use to try to find the solution?
    THANKS
