'94 4runner 3.4 Swap Project - NC - $4k OBO
Discussion in '4Runners For Sale' started by 1302rs, Jun 20, 2018.
  1. Jun 20, 2018 at 7:10 PM
    1302rs
    1302rs [OP] New Member
    MAKE AN OFFER- MOVING TO MICHIGAN IN JULY NEED TO SELL ASAP!
    **project not running**
    1994 4runner 5 speed SR5. I have a 5vzfe from a 98 T100 with new Victor Reinz head gaskets, valve cover gaskets, and cam seals installed- and a new timing belt, water pump, rollers, etc that have not yet been installed (all OEM parts). I have an engine harness from a manual trans 98' 4runner, as well as the ToyOnlySwaps conversion harness. The only thing needed is a 98 5vz MT computer, part number 89661-3D360. I also have a YotaShop conversion exhaust crossover. Original manual trans, new heavy duty Marlin Crawler clutch, pressure plate, and new bearings. The frame is from a donor truck, and has zero rust. I painted it and rebuilt everything on it with high quality parts- 2" Toytec suspension lift, 1" body lift to clear the 5VZfe, Old Man Emu heavy rear springs, front and rear shocks and steering damper. New bearings and seals everywhere, new rotors, new calipers and rear brake cylinders, I installed Aisin manual locking hubs and replaced the ADD halfshaft with an older one-piece unit. This truck came from the factory with 4.56 gears. Evergreen pearl. Tan interior. SR5 wheels and 31 in AT tires with lots of tread. Body has some rust in the rear rockers. I have the body (white) from the donor truck that has good front and rear fenders, doors, glass, sunroof, all very straight and no rust. It also has the tire carrier for the rear tailgate. $4000 for everything, I've got a lot more than that in it but am moving and will not have time or space for it. Buyer will need to pick up from 28782. Thanks!
  2. Jun 23, 2018 at 3:02 PM
    Bob
    Bob Member Staff Member
    Bob
    You are currently located where??
  3. Jun 24, 2018 at 7:50 PM
    1302rs
    I am in western NC, Tryon. 28782
