5VZ burning lots of oil
Discussion in '3rd Gen 4Runners (1996-2002)' started by jcolby, Sep 4, 2024.
  1. Sep 4, 2024 at 2:29 PM
    jcolby
    jcolby [OP] New Member
    Jackson
    1999 limited 4Runner
    Recently bought the 4runner (has 200k miles) knowing it burns oil and am wondering if it could be anything besides the rings. I’m sure it doesn’t leak any oil anywhere. There is white smoke visible after startup but usually goes away within a minute, I see the most smoke after starting it following a long drive prior to turning it off. I know it doesn’t lose any coolant and the coolant isn’t discolored so I don’t think it’s a head gasket thing. The worst burning I’ve encountered is losing up to 1 quart of oil for about a 2 hour drive on the highway
  2. Sep 4, 2024 at 6:38 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    It could leak out the valve stem seals. Theoretically it could leak from the head gasket too, but that is unheard of in basically any engine.
    If it's burning oil it's also losing compression. What you can do to narrow it down to the rings is put a little oil in the cylinder before doing a compression test, if that improves compression drastically over a dry compression test you know the rings are bad. If not, then it's probably the valve seals. The rings responsible for compression aren't what holds the oil back (oil rings do that), but if one is worn the other one often is too.
    Check the spark plug too, if it's black you are burning oil, the exhaust will also smell too. White smoke is usually coolant, oil will be blue. If you let it keep burning oil, you'll also kill the converter too.
    That's an incredible amount of oil loss, that is beyond what I'd want even a 2 stroke to burn.
    Toy4X4 and negusm like this.
  3. Sep 4, 2024 at 6:45 PM
    God damn 1 qt for 2 hours?
    Previous owner got you with no lube on this one.
    This isn't something you are going to fix over the interweb.
  4. Sep 5, 2024 at 6:37 AM
    Yup, compression test time! Do it dry and wet and check the numbers. Also plugs will tell you a lot as mentioned.
    I'm half surprised you don't have a misfire code with that much oil consumption.
  5. Sep 6, 2024 at 8:51 PM
    jcolby
    Jackson
    I just checked the plugs and it doesn't look awesome, I can definitely smell the Burt oil, and there's oil on the threads. I'm going to compression test soon to see how bad it is.[​IMG]
  6. Sep 6, 2024 at 9:54 PM
    I wonder what you'll find. Is it one cylinder or across them all? If all the cylinders are bad, I'd love to know how many oil changes were missed in the old girl's life.
  7. Sep 29, 2024 at 7:19 PM
    jcolby
    Jackson
    Okay, sorry for a long time in between updates but as a rookie in compression testing, I think I got fine numbers that don't really indicate the rings to be the main problem. Some more clarification with the burning oil might help. The car never smokes while driving or in regular conditions, the only time it smokes is after I did a long drive the day before and let it sit overnight. Then when I go to start it there's a decent-sized white cloud, the smoking dissipates after just 3 or so minutes. I don't think it's possible for the white smoke to be coolant as the coolant level hasn't moved since buying the car. Any ideas based on this information?
  8. Sep 30, 2024 at 12:01 AM
    Trekker
    1997 3rz 5spd
    What are the numbers? The only way you'd lose that much oil and not detect loss of compression is it is either leaking outside the engine, or it is leaking through the valve seals.
    Check the sparkplugs, if it's black and oily the engine is burning oil.
    A common issue with the 5vz is cracked heads, but that normally starts at 250k+ miles
