5th gen OEM fit toggle/push/rocker switches
Discussion in 'Lighting' started by Kyblack76, Dec 2, 2018.
  1. Dec 2, 2018 at 8:41 PM
    Kyblack76
    Kyblack76 [OP] New Member
    Layton, Utah
    18 TRD O.R
    All,
    I'm looking for simple switches, that slide into our OEM locations. Dash, console, the like
    I don't want ones that have ZOMBIE lights, or any other stupid shit. I did see some on AIR ON BOARD. One has "this turns something on" or the like, that I giggle at. One that has "thermal fans" that ill use. I'm looking to switch my car amplifier on and off. If it had AMPLIFER on it. Cool. But I'm not seein it, and rather have silliness on it, I'd love a blank switch.
    Is there a place that just sales the switches that fit OEM cut outs? I cant find any. Am I blind?
    I'd appreciate the help.
    TIA
  2. Dec 2, 2018 at 11:46 PM
    Dark Knight
    Dark Knight Get off my lawn
  3. Dec 3, 2018 at 9:21 AM
    PrettyGoodSam
    PrettyGoodSam New Member
    Philadelphia
    2012 4Runner Trail
  4. Dec 3, 2018 at 11:11 AM
    gdvan01
    gdvan01 New Member
    George
    Midlothian, VA
    '17 EssAre5Pee - Barcelona Red
    Bilstein 5100's (fr-0) ~ Dobinson C59-302 front (2.5"), C59-505 rear (1.5") ~ JBA UCA's Cooper Discoverer A/T3's - LT265/70R17
  5. Jan 19, 2019 at 5:10 AM
    Chuck17
    Chuck17 New Member
    Andy
    Chicago
    2019 4runner trd offroad
    Hey quick question, does ur switch only light up when the bar is on? Mine seems to always be lit, any specific way u wired ut?
  6. Jan 19, 2019 at 6:21 AM
    eaglescout
    eaglescout 2018 SR5
    Middle Tennessee
    2018 Magnetic Gray Metallic SR5
    FN FX PRo Wheels Matte Dark Bronze. Nitto Ridge Grappler 285/70/17/load C 3" Dobinson Coil Lift Blackout Kit Raptor Style Grill LED C4 Fab Lo Pro Winch Bumper LFD Offroad Skid Plate Shrockworks Sliders Rago Molle Panels Extreme LED Ditch Lights Ecotechne Roof Rack Detours Offroad Swingout Tire Carrier
  7. Jan 19, 2019 at 9:05 AM
    Lifeline
    Lifeline New Member
    Chris
    Jacksonvile, Florida
    2019 Toyota 4Runner Off Road Premium
    Good videos, thank you. Planning on adding a few myself down the road.
    eaglescout likes this.
  8. Jan 20, 2019 at 11:41 AM
    gdvan01
    gdvan01 New Member
    George
    Midlothian, VA
    With the AOB switch and the Auxbeam wiring harness, this is how I initially had it wired (I used small wire nuts as a temp solution to test the connection prior to making final connection):
    AOB black to harness black
    AOB red to harness red
    AOB green to harness yellow
    As wired above, the switch light was on constantly. The folks at AOB suggested switching the red and yellow wires and now the switch is only lit when it is in use.
    Hope that helps...
    Dogmom45 and Kyblack76[OP] like this.
  9. Apr 6, 2020 at 11:13 AM
    Brother708
    Brother708 New Member
    Austin
    Memphis
    2019 4Runner Off road premium
    *Kings Suspension* Gobi Rack*Shrockworks Bumpers & Sliders*ARB Compressor*Warn Winch* Baja Design lights*
    do they have one that will match the OEM blue backlight?
  10. Apr 6, 2020 at 11:20 AM
    ForRun
    ForRun 4Runner
    2020 orp
    Air on board does. Stay away from ch 4x4. Mine would stick so I threw them out
    Brother708[QUOTED] likes this.
  11. Apr 6, 2020 at 3:28 PM
    Brother708
    Austin
    Memphis
    Good info! Thanks
  12. Apr 7, 2020 at 4:28 AM
    gdvan01
    gdvan01 New Member
    George
    Midlothian, VA
  13. Apr 7, 2020 at 4:51 AM
    Drababan
    Drababan New Member
    2020 4Runner TRD Pro (Pickle Rick)
  14. Oct 27, 2020 at 7:47 AM
    jbl912
    jbl912 New Member
    Any update on this? My oem style switch from mictunning is also sticking/not working properly. I ordered one from Caliraised to try it out.
  15. Oct 27, 2020 at 7:59 AM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    I bought my Bat Light switch from Air on board and have zero problems with it sticking over the last few months.
  16. Oct 27, 2020 at 9:34 AM
    jbl912
    jbl912 New Member
    Sounds good thanks guys. I will try to dremel the sides of my current switch, if It doesn't work, I'll try another brand.
    I also was not able to get the dimmer to work appropriately. I connected Red 2 to the green wire on the wiper heater switch, It dims but inverse of expected (brightest at the lowest dimmer setting). I will end up using a fuse tap to a switched driver side fuse.
  17. Feb 23, 2021 at 10:40 PM
    MedicineMan4040
    MedicineMan4040 New Member
    2021 4Runner Off-road Premium Bright White 3-2 Lift (dealer) BFG TA K02s
    Recently installed switches from Ch4x4. A mistake.
    Have just ordered from Air on Board, ditch, winch, light bar.
    Fingers crossed.
    2 of the 3 from Ch4x4 stuck.....
  18. Feb 24, 2021 at 6:42 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Thats what happened to mine, CH4x4 has issues
  19. Mar 6, 2021 at 1:18 PM
    can0nfan2379
    can0nfan2379 New Member
    Arid-zona
    2019 T4R ORP...2013 TRD OR DCSB Tacoma
    Just installed my compressor switch from Ch4x4 today - gets stuck in the ON position. Pretty disappointed since I paid for some custom text on this one......
  20. Mar 6, 2021 at 3:56 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Can’t believe they are still in business. They have been selling cheap junk for over a year that I know of
  21. Mar 6, 2021 at 5:13 PM
    MedicineMan4040
    My worst 'stick' via Ch4x4 was my ditch lights, arrrrrg, that can get me pulled over real quick.
    I had just a minute to solve the issue. Took a knife blade and pried it back out. Luckily it turned off.
    Still waiting for the replacements to get here but I've not been to that house in a while/might be sitting waiting on me.
    can0nfan2379[QUOTED] likes this.
  22. Mar 7, 2021 at 9:47 AM
    can0nfan2379
    Arid-zona
    I've been trying to get onto Air On Board's website to place an order but it seems like it's down or there is a glitch or something.
  23. Mar 7, 2021 at 9:48 AM
    can0nfan2379
    Arid-zona
    Yep.....$30 bucks for a custom switch that's now in the garbage can......
  24. Mar 8, 2021 at 3:49 PM
    ToyotaMacGyver
    ToyotaMacGyver At 88mph you’re going to see some serious sh...
    Justin
    Missouri
    2017 Super White TRD Pro
    Funny to read this thread. I bought 4 ch4x4 switches recently and worked on installing two this past weekend. I’ve decided they’re just not worth the hassle as getting them to function how I want is going to be a lot of work. They are cheaply made. They need modification to work properly. I’ve read it’s the 4 runner switch housing that needs some tabs shaved off to get them to engage correctly. I will have to check to verify. Mine currently act as momentary switches.
    Ordered an auxbeam switch controller and plan on using that for my switch lighting solution and see how that goes. If it works well maybe at some point I’ll upgrade to an sPod or SwitchPro system.
  25. Mar 9, 2021 at 4:40 AM
    can0nfan2379
    Arid-zona
    Air On Board must have had their IT department fix their website - it was back up yesterday so I ordered a switch from them - hopefully I won't be disappointed after the disaster that was CH4x4.
    As an aside, I emailed CH4x4 about my switch problem a few days ago - radio silence, no offer of support or to send out a replacement.
    Switch Master likes this.
  26. Apr 15, 2021 at 9:16 PM
    d4runr
    d4runr New Member
    2021 White 4Runner TRD OFP
    have you found a fix to this? lol, mine from CaliRaised are stuck haha.
  27. Apr 15, 2021 at 10:11 PM
    GrayGhost
    GrayGhost New Member
    Dave
    2020 orp - sold
    I had same issue with CH 4x4. They stuck and I was done. Bought air on board and troublefree for a year now
  28. Jan 19, 2022 at 12:34 PM
    Switch Master
    Switch Master New Member
    WILL
    2022 LIME RUSH 4RUNNER TRD PRO
    NONE AS OF TODAY
    Hello Dave
    FYI is not the switches any brand is the OEM Whole in must 4runner they have a tab inside that makes the switches stick or not operate correctly
    thank you
  29. Jan 19, 2022 at 5:30 PM
    GrayGhost
    Dave
    2020 orp - sold
    What your saying has zero to do with the original issue. CH 4x4 switch would hang up. Air on board did not so I'm not understanding what you say. for what its worth, many on the other forum had the same thing with that brand...its junk
    Switch Master[QUOTED] likes this.
  30. Jan 20, 2022 at 7:28 AM
    kwill
    kwill New Member
    I can't even understand what he is trying to say, but I have also had problems with CH4X4 switches.
