5th Gen Maintenance Maps + Torque Specs and Part Numbers!
Discussion in '5th Gen 4Runners (2010-2024)' started by qc.runner, Mar 31, 2023.
  1. Mar 31, 2023 at 5:39 PM
    qc.runner
    qc.runner [OP] New Member
    2021 Xpel Stealth Magnetic Gray Metallic 4Runner SR5 Premium
    Prinsu Full Roof Rack Baja Designs Light Bars, Ditch, Chase KC Rock Lights Black Rhino Abrams Fox Mid Travel 2.5 DSC Suspension Kit (Tundra Rear) S&B Cold Air Intake JLT Oil Separator ARB Dual Air Comp SD Offroad Mount Tray Switch Pros OEM Audio Plus Full Audio System Taco Vinyl TRD Pro Grille Level 3 Autoworks Xpel Stealth PPF Super Springs Bump Stops Dobinsons Springs Front Diff Drop Meso Customs Interior Trim Expedition Essentials Dash Mount Anytime Backup Camera Front Cam Cplay2air Wireless CarPlay Running4Tacos Accessories and Gear Throttle Grenade 4x4 Throttle Controller AJT Designs Accessories
    Linked below are maintenance maps for the 5th Gen 4Runner. The maps detail the maintenance scheduled 0-100K, 100K-200K, & 200K-300K miles. These maps are to be an ongoing project that the community can use and improve upon, so any suggestions will be taken to consideration.
    *Huge thanks to Soft Taco (Tyler) on Tacoma World, lots of inspiration on this and his go ahead to take what he created for the Tacoma and run with it for the 4R! I was jealous of this project he did and wanted the 4R community to have something like this as well. If you have a Tacoma, checkout the maintenance maps here: https://www.tacomaworld.com/threads/3rd-gen-maintenance-maps-get-300k-miles.789809/
    PDF Version
    0-100K Maintenance Map
    100K-200K Maintenance Map
    200K-300K Maintenance Map
    Torque Specs
    PNG Version
    Torque Specs
    Preview:
  2. Mar 31, 2023 at 5:46 PM
    So what band oil?.......
    J/K
    Thatbassguy and qc.runner[OP] like this.
  3. Apr 1, 2023 at 7:34 AM
    jth
    jth trdle
    Saint Paul, MN
    2020 Army Green 4Runner TRD Pro
    These look awesome, thanks for putting in the work. Will be printing and posting in the garage!
    Yotaholic and qc.runner[OP] like this.
  4. Apr 1, 2023 at 8:28 AM
    qc.runner
    Absolutely!
    Yotaholic likes this.
  5. Apr 1, 2023 at 8:29 AM
    qc.runner
    I mean... I use Costco oil...;););)
  6. Apr 4, 2023 at 7:52 AM
    Lou
    Lou New Member
    2021 TRD Off Road Premium
    Somebody needs to pin this. Awesome work! I downloaded all of yours and the ones for our Tacoma too.
  7. Apr 4, 2023 at 8:33 AM
    Branden967
    Branden967 New Member
    6400' in CA
    2023 TRDOR Premium
    Kings Suspension SCS 17X9 -10 OS Ridge Grapplers If its chrome....black it out.
    Awesome thanks, posting it on the garage wall...
    qc.runner[OP] likes this.
  8. Apr 4, 2023 at 9:46 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I like the visuals. But what’s your source for this? They seem to be based on the Maintenance/Warranty manual, but with some “enhancements”.
    The 60K interval lists a spark plug change, but that’s too soon, the manual says 120K.
    You show transmission fluid changes at 60K for severe and 100K for normal. Then at 120K for severe. That’s too soon. The Toyota schedule establishes a normal interval then halves it for items it considers severe. Your chart would require the user to realize to ignore the “normal” 100K trans service if they were following the “severe” interval.
    Anyway, good job with this project. You might want to compare the chart vs the Toyota manual again to catch anything else.
    One more thing, it may make more sense to organize it for a 120K range like the manual does. And maybe add notes that describe the enhanced additions, like I noticed the power steering change.
    :thumbsup:
  9. Apr 4, 2023 at 10:04 AM
    Interested where you sourced torque values, since it could have values for other bigger maintainance jobs or other common work, like suspension mods etc. Seems like anytime I start something, I’m trying to figure out torque values when my hands are greasy and I’m already tired, so it just ends up set by feel.
  10. Apr 4, 2023 at 10:12 AM
    NorthernSailor
    NorthernSailor New Member
    Alberta
    2023 Black 40th Anniversary
    Elka 2.0's up front, Sherpa rack, WeBoost Overland cellular booster, Nokian Outpost rubber
    I literally created an account on here to give qc.runner a like for this
  11. Apr 4, 2023 at 11:03 AM
    steelevo
    Utah
    Thank you for the work that you put into this!
  12. Apr 4, 2023 at 12:26 PM
    qc.runner
    Honestly a big push for the Torque map was so that I didn't have to research mid project, ha! But I have this pinned and constantly refer back to it, Trail4R did a great write up on suspension torque. Most others were sourced by crosschecking different forums to Toyota. Glad you find it helpful! (https://trail4runner.com/2020/06/17/5th-gen-4runner-torque-specs/)
    Spare Parts likes this.
  13. Apr 4, 2023 at 12:37 PM
    qc.runner
    Thanks for the feedback, always welcome here! A lot of independence research went in and most of the charts are intended to be adapted to your drive style and the intervals that make the most sense for your rig. The overland community might follow a more severe interval, than folks who don't necessarily take their 4R's off-road. So the thought is if you are following severe, you skip normal, and vice versa.
    In terms of the spark plugs, most "long-life" plugs manufactures state a huge change window from 60,000 - 150,000 miles. I guess I am just cautiously optimistic and like wrenching that I'd rather service on the low end... rather the high. Probably why I change my oil every 5K miles even though I realize that I could do 10K pretty easily HA!
    For me I printed and laminated the map so I can write on it with a sharpie, when I do severe interval change like transmission my intentions is to mark off the normal service when I mark off the severe so that way I skip it when that mileage comes around :) But definitely a good idea to do a little write up of additions, that maybe the next version!
  14. Apr 4, 2023 at 5:48 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Personally I would have liked a different color or a different symbol (i.e. triangle) for everything that is in the scheduled maintenance from Toyota vs your recommendation.
    i will print this and highlight the ones from Toyota so I can see the difference.
    regardless of this, amazing work it looks great and it’s very easy to read. Thanks a million times for this!
  15. Apr 4, 2023 at 6:04 PM
    qc.runner
    That is honestly a brilliant idea!
  16. Apr 12, 2023 at 2:07 AM
    redneck pilot
    redneck pilot New Member
    DFW
    2023 4Runner TRD ORP
    Mods, can we make this thread a sticky?
    Stoney Ranger, qc.runner[OP] and Lou like this.
  17. Apr 13, 2023 at 5:55 AM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Good work. You might want to update your wheel nut torques. My '22 4Runner manual states the torque is 76 ft lbs for aluminum rims and 83 ft lbs. for steel rims. Not a huge difference but I have seen wheel studs break when overtightened and doing some hard 4 wheeling.
    wht_rnr21 likes this.
  18. Apr 13, 2023 at 7:50 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @Redwood yes sir, good to point out, says the same in my 2016 manual. However, I've had mechanics and 4Runner fabrication specialists tell me 76lb is too low even for aluminum!? Lol
  19. Apr 13, 2023 at 7:59 AM
    Nice job, good addition to the manual. Thanks:hattip:
  20. Apr 21, 2023 at 3:34 PM
    harsh
    harsh New Member
    Harsh
    2016 Limited 4Runner
    Wow, thank you, will be going on garage wall.
  21. Jun 26, 2023 at 7:35 AM
    BallisticCoeff
    BallisticCoeff New Member
    Dave
    2015 SR5P
    None... yet
    First of all, this is super great. I got my FJ up to 286k miles before trading it in. My 4Runner has 156k now and I love doing my own work.
    secondly, I posted these in the 5th gen 4Runner maintenance group of fb regarding spark plugs like others here, but also on torque values.
    One guy said the front and rear brakes are not the same torque. The front has no banjo bolt and if I remember correctly the rear caliper mounting bolts only get torqued to 75ft lbs.
    here is my contribution of torque specs!
  22. Jun 26, 2023 at 7:40 AM
    krashDH
    krashDH New Member
    2016 SR5, 4WD
    I posted this at the beginning of the month on another thread because the spec chart in the thread posted was incorrect (brakes).
    https://www.4runners.com/threads/to...sfer-case-fill-drain-bolts.32140/#post-460691
  23. Aug 20, 2023 at 9:42 AM
    RCJAY272
    RCJAY272 New Member
    ROB
    2017 t4r sr5
    3'' LIFT, 285/70/17 Falkens, Warn winch, Sliders,
    Thank you for bringing this all together
  24. Aug 20, 2023 at 3:52 PM
    BeavertonCommuter
    BeavertonCommuter New Member
    Thanks for this great resource! Im looking at the 15k driveshaft greasing? Something I can do on my own?
  25. Aug 20, 2023 at 3:59 PM
    Brodie
    Brodie New Member
    Richmond, Va
    2021 Grey 4Runner SR5
    Since I only drive about 5k a year I have to do more on a time vs mileage basis. It gets a little confusing.
  26. Aug 20, 2023 at 4:30 PM
    Texas4Runner
    Texas4Runner New Member
    Dallas/Fort Worth Texas
    2023 4Runner ORP+ CSM and Ice Cap
    Good job....Thanks for all your efforts!!!!:101010:
  27. Jan 20, 2024 at 9:56 AM
    wht_rnr21
    wht_rnr21 New Member
    2021 4runner TRD PRO
    @qc.runner - This is fantastic! Thank you for putting this together for us. I printed and laminated it so that I can check things on it with a dry/erase marker.:cheers:
    Along with what @Redwood mentioned about lug nut TQs, spare tire stowing chain tightening TQ is 34.4ft.lbf (in case any one is wondering)
  28. Jul 21, 2024 at 11:05 PM
    mopudding
    mopudding New Member
    Chris
    Burnaby, BC Canada
    2018 4Runner Limited
    @qc.runner - AMAZING work!
    The documentation, booklets, and Toyota Canada website do not offer a table with recommended maintenance intervals - it's weird.
    Any chance you can either share the file for me to convert values into kms instead of miles for us Canadians?
  29. Jul 31, 2024 at 12:45 PM
    WolvesT4R
    WolvesT4R New Member
    Los Angeles, CA
    @qc.runner - Thank you for this! Was looking for something like this since moving from my ex-taco to the T4R!
  30. Oct 5, 2024 at 5:14 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Tagged
