5th Gen Brakes
Discussion in '5th Gen 4Runners (2010-2024)' started by SoCalSnowRunner, Mar 18, 2018.
  1. Mar 18, 2018 at 9:17 AM
    SoCalSnowRunner
    SoCalSnowRunner [OP] New Member
    Sean
    2016 White 4Runner Trail Premium
    Baja Rack, c4 Fab LoPro Bumper, Extreme Led lights
    So I have 35k on my 2016 5th Gen Tail and I have had nothing but problems with the brakes. I have complained to my dealer since 10k service that I get a pulsating when braking and it gets worse on long road trips (to the Mountains snowboarding). They said that they are getting hot and have a slight deform and as long as the return to normal when it cools I will be ok. Well my last service at 35k the dealer said that my front brakes are shot and the rotors would need to be turned and new pads. I got my car back and its a whole new car and the new breaks are amazing! Has anyone dealt with bad factory brakes?
  2. Mar 18, 2018 at 1:15 PM
    4X4Runner
    The left coast
    I think this is the first I’ve heard of it.
  3. Mar 21, 2018 at 11:10 AM
    SnowroxKT
    SnowroxKT New Member
    Alaska
    2018 T4R TRD Offroad
    2018 T4R Offroad SAS 1995 Tacoma
    Can't say I have.
  4. Mar 22, 2018 at 5:43 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I did a complete inspection on my 2016 in dec 2017.. had 10K miles on it .. I when rotating the tires @10K miles removed all the brake pads checked for caliper operation and lube of the cal pins .. all looked perfect I was very impressed with how toyota did the assembly work .. much better than GM vehicle ..
    So I will have to say you have a heavy foot on the brakes ... since they cut your rotors I will expect you to be bitching after a few K miles with rotor distortions and pedal vibs again... some areas people will drive too close to the vehicle in front and the distracted driving then a 10 car pile up due to driving @80MPH about 15 ft apart ..
    when going down the mountain down shift to reduce speed ..
    this is great for vehicle manufacturers ..
  5. May 17, 2018 at 10:16 AM
    jr15642
    jr15642 New Member
    Rick
    '12 4Runner SR5-P 4WD
    2012 with 135k...every time I hit the brakes, even softly i hear this little hissing sound, any ideas??
  6. May 17, 2018 at 10:58 AM
    P226Navy
    P226Navy 2016 T4R
    Vee
    South San Francisco
    2016 Toyota 4Runner
    Usually hissing sounds cause by worn out pads as per tire/wheel technicians but I maybe wrong with it too. I'm saving some mola and will upgrade breaks to TRD or Brembo or whatever is best for the bucks.
  7. May 17, 2018 at 3:43 PM
    jr15642
    jr15642 New Member
    Rick
    The hissing is coming from the pedal area, but I don't hear anything outside as with other vehicles when pads are low, is the pedal hissing a 4runner specific notification for low pads?
  8. May 17, 2018 at 6:48 PM
    j cat
    j cat New Member
    massachusetts
    I hope its not the BRAKE booster leaking expensive part.. if vehicle is stopped and the noise is occurring have the booster checked for leak..
    DIRTRCR13 and P226Navy like this.
  9. May 17, 2018 at 7:07 PM
    jr15642
    jr15642 New Member
    Rick
    Crap, this might be the case... Would it also make the noise if the vehicle was off??
  10. May 19, 2018 at 11:20 AM
    j cat
    j cat New Member
    massachusetts
    shutdown the engine key out then push on brake pedal , if it makes the sound most likely booster leak..brake pedal connects to booster under dash .
    go to dealership could be that sound it normal ... some vehicles do create a slight sound when depressing the BK pedal .. if the booster has a big leak then the brake pedal will be harder to push down .. small leak may not change this effort but if its somehow damaged the pedal will start to be harder to push down.
  11. May 19, 2018 at 9:06 PM
    jr15642
    jr15642 New Member
    Rick
    No issues with pedal pressure. Just to confirm, this is the same noise I'm getting: https://www.youtube.com/watch?v=JQBvV4KNh4k
    CO_Native and RUB1OFF like this.
  12. May 20, 2018 at 8:04 AM
    j cat
    j cat New Member
    massachusetts
    with your video that sounds like a scraping ... also if it was a vacuum booster leak that sound would go away after depressing the brake pedal a few times. engine off .. check the pedal arm and connections for any interference ..
    yes that is too loud ...
    jr15642[QUOTED] likes this.
  13. Jan 29, 2019 at 6:26 PM
    RUB1OFF
    RUB1OFF New Member
    Just replace brake master cylinder will solve the problem. I had 2016 4RUNNER SR5 only has 35miles on it, has same noise, dealer replaced cylinder, noise is gone. now I am driving 2017 TRD same issue.
  14. Feb 5, 2022 at 6:29 AM
    SYTY
    SYTY New Member
    THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
    My 21 TRD OR does the same thing thought it was a vacuum leak but it is more of a suction noise at the brake pedal boot in the fire wall. I am waiting for the weather to get better to look at it more no issue with brakes just that suction noise in footwell area, also first cold stop in the morning front brakes squeak louder than a garbage truck does.
  15. Feb 5, 2022 at 12:09 PM
    j cat
    j cat New Member
    massachusetts
    your brakes work correctly . so the brake boot probably was not setup correctly.under the dash brake pedal area .
  16. Feb 5, 2022 at 7:05 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Mine does the same sound. Took it to the dealer they said it was normal.
  17. Feb 5, 2022 at 7:30 PM
    I bought my 2013 with just under 80K miles on it. Per the Carfax, the brakes were done around 70K. Now at 132K, haven't touched the brakes, and haven't had any of these issues.
    I guess I'm easy on my brakes.
  18. Feb 6, 2022 at 3:24 AM
    Matt83
    Matt83 New Member
    Northeast
    My truck has made the same sound in the footwell since new. From the research I did, it is normal.
    K-Paul likes this.
  19. Feb 6, 2022 at 9:10 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    I intentionally try to drive it slow lol, not just saving brakes but trying to save some gas
