5th Gen Anti-lock Braking Issue on Ice and snow
Discussion in '5th Gen 4Runners (2010-2024)' started by DBNightshade, Mar 1, 2024.
  1. Mar 3, 2025 at 12:08 PM
    #61
    My whole point about high-idle, thick trans fluid, is that the engine rpm is driving the wheels at the slow speeds this is occuring. No engine braking available…
    MooreKen likes this.
  2. Mar 3, 2025 at 12:24 PM
    #62
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Depends. Going from high speed with low/no RPM dropping a gear will slow you. At a high RMP (Or 4L) you will will keep going, even with some break pressure will feel weird since its not stopping as easily/normally.
  3. Mar 3, 2025 at 10:18 PM
    #63
    MooreKen
    MooreKen 2023 TRD PRO “Solar Octane”
    I honestly think you nailed it. It did move forward like it was at “high idle”. This is very good to know.
  4. Mar 7, 2025 at 2:41 AM
    #64
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    You have to hold the button about 4 seconds to turn skid and Trac off. Pushing the button turns off skid control up to about 30mph and it shuts off. Holding 4 seconds turns skid and Trac off, but you have to reapply every key turn. It will keep trying to go straight on snow and ice if you don't. Mine goes great after that.
  5. Mar 7, 2025 at 2:49 AM
    #65
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Hold Trac button 4 seconds before moving and I use my electronic manual shift to upshift and downshift for braking.
  6. Mar 9, 2025 at 1:48 PM
    #66
    golfpilot
    golfpilot New Member
    David
    Switzerland
    2019 TRD Off Road Premium
    That must be a normal Toyota thing ;) but definitely not funny with the weight of these cars.
    Staying on the brakes is a mistake here, and also too much engine braking can be bad.
    Try to get those wheels turning to keep control.
    (Prado at 6:35)
    https://youtu.be/oCf7ywAslUk?t=396
    I've already seen a prado driving downhill on the mountain road here in icy conditions. He only stayed on the road by accelerating slightly so that the wheels turned and he could correct/counter-steer, otherwise he might have crashed down the hill.
    Stay safe or leave the Toyota at home for once (in such conditions).
    Greetings from almost spring then winter.
    David
  7. Mar 9, 2025 at 3:48 PM
    #67
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    Sounds like many folks need to learn the proper way to drive in snow/ice conditions.
    Schlappesepple likes this.
  8. Mar 10, 2025 at 7:59 AM
    #68
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    This is quite clearly an ice + tire + a little driver skill problem. I don't think the rubber cares what kind of badge you have when friction takes the day off.
    Also, there goes the "locked wheels would have been better" argument.
