5100 front only - effect on ride?
Discussion in 'Suspension' started by Mike6.5x47, Jan 13, 2022.
  1. Jan 13, 2022 at 9:26 AM
    Mike6.5x47
    Mike6.5x47 [OP] New Member
    2024 4Runner Off-Road Premium - Starting OVER!
    Hi all - searching was inconclusive, so here I am:
    I'm considering doing a suspension upgrade to my 21' OffRoad. Sorry if these are "dumb questions", but I'm a computer geek, not so much of a wrench turner.
    I have already replaced tires and don't want increase lift - this is mostly an upgrade to stiffen the suspension and address the braking nose-dive. For the moment, we're most likely to be just driving on Forest Service roads, not doing what I'd consider "heavy off-roading". I've gotten a couple of quotes, but I'm not sure whether I should be doing just front suspension improvements, or whether I need to be doing front and rear at the same time.
    Also, assuming I do the 5100s just up front - if I decided to upgrade at a later date, would there be any issues with moving the 5100s out of the front and into the rear? - determined to not work as front are strut, and rear are shock - this is how you say "I know little about cars" without coming out and saying "I know little about cars" :D
    There's also a chance I may want to do a front bumper/winch setup at some point in the future - I understand that there's a necessity to improve the spring coils if you add greater weight - is there any potential issue with having medium duty springs on a rig that's still OEM weight? I presume that would make the ride significantly stiffer, perhaps uncomfortably so?
    Thanks in advance to those who share their experience and expertise...
  2. Jan 13, 2022 at 9:32 AM
    Dillusion New Member
    KYle
    Different part number for front and rear I believe.
    Going to sag if you add bumpers and keep OEM ratings.
  3. Jan 13, 2022 at 9:36 AM
    Mike6.5x47
    Thanks Dillusion :) I expected the sag with bumpers if I didn't replace the springs - the question was whether the ride gets "too stiff" if you have the heavier springs BEFORE you do the bumper?
  4. Jan 13, 2022 at 10:15 AM
    KYle
    Probably will be stiff. How stiff no idea I never planned for bumpers so I wouldn't know.
    Mike6.5x47[OP] likes this.
  5. Jan 13, 2022 at 10:37 AM
    I'm pretty sure you'd notice the difference. The front Bilsteins, if set @ .85 or 1.75, will help mitigate the bumper weight somewhat, depending on whether you are going to a wrap around full size or a smaller hybrid version.
  6. Jan 13, 2022 at 10:47 AM
    Mike6.5x47
    Probably hybrid, but who knows...thanks for the insights!
  7. Jan 14, 2022 at 7:12 AM
    Mike6.5x47
    found a good enough deal to just do the 5100s all the way around yesterday and they had the parts in their warehouse. It should be installed next week - I'll upgrade springs when we do the bumper :)
