5.7 Tundra V8 Swap
Discussion in '5th Gen 4Runners (2010-2024)' started by allthescottsweretaken, Mar 21, 2019.
  1. Mar 21, 2019 at 7:42 PM
    allthescottsweretaken [OP] New Member
    Scott
    16 Trail
    Not sure if this is remotely a possibility, couldn't find any threads on it. Has anyone done an engine swap on a 5th gen? $5000+ for a magnuson is some pretty cash considering what's available out there for crate motors. But more importantly, I'm wondering if the 5.7 from a tundra would fit in the front of a 4Runner. If it fits then there's maybe a way...
    DRobs, cjrunner and troprobped17 like this.
  2. Mar 21, 2019 at 8:05 PM
    WallyT4R
    WallyT4R New Member
    I highly doubt it will fit. That 5.7 is huge from side to side
    troprobped17 likes this.
  3. Mar 21, 2019 at 8:46 PM
    Huzer21
    Huzer21 New Member
    CO
    2011 GX 460
    4.6 seems like an easier option. I guess just getting a GX460 would be even easier.
    troprobped17 and WallyT4R like this.
  4. Mar 22, 2019 at 1:21 AM
    Charlievee
    Charlievee Not new member.
  5. Mar 22, 2019 at 1:28 AM
    Charlievee
    Have not seen much for performance mods out there. I would like to see more myself. Any built motors? Bore and stroke, cams? Considering the age of the platform you think there would be more.
  6. Mar 22, 2019 at 1:34 AM
    troprobped17
    troprobped17 New Member
    It’s a great idea if you’re mechanically inclined. I wouldn’t mess up a beautifully built 5th gen, though. I guess that if you’re able to find a 5th gen T4R that’s been totaled. But, the body is still good. You could probably do or attempt to do an engine swap. Maybe, do some body and frame modification and replace the tranny as well. It may just be possible.
    The costs associated with such a modification would be significantly high. You would have far exceeded the $6k for a Magnuson supercharger by then. It would, however, be very interesting to see the end results.
    WallyT4R likes this.
  7. Mar 22, 2019 at 4:53 AM
    Charlievee
    Cost is all relative, the cost of forced air In a 4runner is very expensive compared to the performance gains. Like everything else these days, you will most likely have to change out more then just the motor as everything is all connected with the electronics. There are companies out there that sell running drive traines on pallets that get pulled from wrecked vic's ( think hell cat, gt500). Granted these are for gear heads that want power.
    troprobped17[QUOTED] likes this.
  8. Mar 22, 2019 at 8:17 AM
    Large
    Large New Member
    Red
    Someone did an LS3 swap in to a 5th gen and actually got it running properly, only info I can find is on IG.
    Trail Runnah and troprobped17 like this.
  9. Mar 22, 2019 at 9:14 AM
    Huzer21
    Huzer21 New Member
    CO
    2011 GX 460
    The old adage is to figure $100 per 1hp. For the ~80HP gain of a S/C, that figure actually comes in a bit lower for the Magnuson, assuming a self install. Granted if you want the warranty that Magnuson supplies, you'll have to pay for the install, which then will probably put you closer to that $100/hp.
    SlvrSlug, 7385 and troprobped17 like this.
  10. Dec 18, 2021 at 6:13 AM
    MrSparkie
    MrSparkie New Member
    2022 4Runner
    Not yet
    I just spoke to someone who made the swap. Supercharged V8 from a Tundra... The drivetrain swap took about 2 weeks, but the wiring took him 3 months. (Splices were soldered and heat shrinked.)
    The main issue was different regions of manufacture, therefore, you're trying to merge two different versions of buss communication between the modules.
    Being a licensed electrician with experience on instruments, aircraft and more, this to me was an awesome accomplishment. My hat's off to anyone willing to take on a project such as this.
  11. Dec 18, 2021 at 5:07 PM
    You would think swapping in the lexus v8 from the 4runners brother would be easy. Does toyota sell crate engines?
  12. Dec 18, 2021 at 5:18 PM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I'm hoping we can swap in an electric motor when they force those useless things on us...
    There is a company doing Toyota diesel swaps on Tacos and 4Runners. For only $32,500!!!
    The vehicle is not included in that price.
    https://dieseltoys.com/4runner-diesel
    For you doomsday preppers - diesel stores better long term than gasoline. It's also not explosive like gasoline.
  13. Dec 18, 2021 at 9:19 PM
    Good luck, anything can become a reality with enough money.
    I’d rather squeeze one into a Camary and make it a sleeper.
  14. Dec 18, 2021 at 9:38 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    I can’t say I know enough about diesel but 165hp vs 270hp and yeah the torque is usually higher but 60 lb. Torque does not seem enough to justify the change so I would stick with the mag super charger and call it good.
  15. Dec 19, 2021 at 8:31 PM
    BionicRandy
    BionicRandy New Member
    Randy
    TX Hill Country
    Lots of goodies
    As soon as I read they were putting a twin turbo 3.5 in the Tundra I started thinking about that swap. Maybe by the time my 4.0 croaks there will be a few of those around. I have not seen one, but it SHOULD fit.
  16. Dec 19, 2021 at 9:13 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    RSG did it. Call them.
  17. Dec 20, 2021 at 12:50 PM
    Burnt Taco
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
    Current price for Magnuson roller rocker from RSG is $5995.00
    LandCruiser likes this.
  18. Dec 20, 2021 at 5:31 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
  19. Dec 20, 2021 at 6:12 PM
    BionicRandy
    Randy
    TX Hill Country
    Lots of goodies
    Wow what a truck. Those aired down 40”s have so much grip. I gotta stay off here or I’m gonna go broke.
  20. Dec 21, 2021 at 6:00 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
  21. Dec 21, 2021 at 9:56 PM
    Trail Addict
    Trail Addict Professional Driver on a Closed Course
    2022 4Runner TRD Pro
    I believe these should have had a V8 option or at least a V8 option on the top-tier TRD Off-Road and TRD Pro models.
    But if they did, no one would spend $20k more for a Lexus GX
    peter2772000 and roc like this.
  22. Dec 27, 2021 at 3:30 AM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Not sure I agree.
    The extra $$ for a GX includes all the accessories we mostly don't have in our 4Runners. I'd gladly spend $5k more for the option of a higher-hp/torque V8
    DIRTRCR13 likes this.
