4WD Not Working, Plus Dash Light always on
Discussion in '4th Gen 4Runners (2003-2009)' started by AZ 4Runner, Sep 13, 2023.
  1. Sep 21, 2023 at 7:26 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    You’re very welcome. Here’s a screenshot from YT showing it, and this is a description someone posted on another forum: “Removed the glove box and lowered the lower panel which holds the 4wd module and another module.“ IIRC, the other module is for the TPMS (tire pressure monitoring).
    Hoping you find the solution at the module.
    Morris likes this.
  2. Sep 22, 2023 at 6:04 AM
    Libagui
    Libagui New Member
    Librado
    2006 Silver 4runner limited.
    First thing to check when dash light go crazy is the gas cap. Any scanner can find P0457.
    If that is not the issue, then most likely you have a bad actuator, it could be the front ADD, or the transfer case actuator. None of those are going to show in scanner, this is to be diagnosed by somebody with some knowledge of how this 4x4 work. I have repaired myself a couple.
    Morris likes this.
  3. Sep 22, 2023 at 3:13 PM
    Morris
    Morris New Member
    03 4runner
    Blue sky07
    I found my module. All I had to do was lower the panel under the glove box. The plugs and the pens in the module. All look good I’m gonna guess it’s the module
    I’ve tried changing the switch in neutral I’ve tried driving it forward, driving it backwards. None of that seems to help disengage it.
  4. Sep 22, 2023 at 3:30 PM
    Bluesky 07
    Russell
    Northern Georgia
    What a bummer. Had my fingers crossed that it would be something simple at the module. Seems unlikely to be a coincidence that there was work done down there and then the 4WD trouble started. I’m out of suggestions.
    Morris likes this.
  5. Sep 24, 2023 at 9:13 AM
    Morris
    Morris New Member
    03 4runner
    Blue sky 07
    that was my thoughts exactly, I’m wondering if for some reason maybe it shorted out when he either disconnected or reconnected it
    But I don’t know how to check a module, a new one is $500 so I’m wondering do I take a chance on buying a used one hoping that it’s good and see if that’s the problem
    thanks for all the help!!
  6. Sep 24, 2023 at 9:47 AM
    Bluesky 07
    Russell
    Northern Georgia
    it may take a day or two, but I have the service manual and will look to see if there’s anything about troubleshooting the four-wheel-drive and or the module.
    Morris[QUOTED] likes this.
  7. Sep 24, 2023 at 11:30 AM
    Morris
    Morris New Member
    03 4runner
    Blue sky 07
    When I’m sitting in the vehicle, and everything is quiet when I turn the transfer case switch going up from H2-H4 I hear the control module click when I go to L4
    It doesn’t click.
  8. Sep 25, 2023 at 7:13 PM
    Bluesky 07
    Russell
    Northern Georgia
    This is the first thing that came up when I searched the FSM for "4WD." Hope the mechanic followed it.
    This may be what the Car Care Nut talks about in his video on how 4WD works, where the actuator moves a bit but then the computer gets confused and doesn't know whether it's engaged or disengaged. He says what it takes to fix but I don't recall at the moment. I linked that video in post #3 of this thread. I attached a couple of diagnosis docs from the manual as well. Hope this helps.
  9. Sep 27, 2023 at 7:18 PM
    Libagui
    Libagui New Member
    Librado
    I hope this help you figure it out.
    Bluesky 07 likes this.
  10. Sep 28, 2023 at 10:59 AM
    Bluesky 07
    Russell
    Northern Georgia
    That doc is amazing, thanks for sharing it.
  11. Oct 2, 2023 at 12:41 AM
    Bluesky 07
    Russell
    Northern Georgia
    @Morris - have you had any luck with this?
  12. Oct 17, 2023 at 8:43 PM
    Morris
    Morris New Member
    03 4runner
    Blue sky 07
    I did not have any luck on my own. I took it to another mechanic he didn’t have any luck. I spoke to a mechanic in my hometown and he told me that when the module is disconnected a lot of times it Hass to be reprogrammed. I will be looking into this aspect tomorrow.
    I will update you as to how it goes. Thanks for all your help.
  13. Oct 18, 2023 at 4:44 AM
    Bluesky 07
    Russell
    Northern Georgia
    You’re very welcome. Hope it eventually works out. Something to keep in mind - people are often parting out 4th Gens on FB Marketplace and such. Maybe see if you can snag another module at a reasonable cost. To my knowledge, there’s nothing vehicle-specific to where another one wouldn’t be plug and play but confirm that before you lay out any money.
    I feel for you being stuck in a money pit with this thing.
  14. Oct 18, 2023 at 8:12 AM
    Morris
    Morris New Member
    03 4runner
    Blue sky 07
    I did look up and get another module for 40 bucks +22 shipping
    I’m gonna try that if not, I found a mechanic here in Kingston Springs that is pretty sure it just needs to be reprogrammed. He stated he has dealt with this issue before. I’m looking at about $300.
    Outside of this it really hasn’t been that bad. It’s been a very good very reliable vehicle. Thanks again and have a great day.!!!
  15. Oct 19, 2023 at 4:57 AM
    Bluesky 07
    Russell
    Northern Georgia
    Thanks for the update. Hope one or the other of those potential fixes solves the problem.
  16. Oct 22, 2023 at 7:17 PM
    Libagui
    Libagui New Member
    Librado
    That module is not reprogrammable.
  17. Oct 22, 2023 at 7:23 PM
    Libagui
    Libagui New Member
    Librado
    Most of the times this fault is due to internal A.D.D, or transfercase motor leads are corroded. Common fix is to pull them of and weld them, but you have to time everything for it to work again.
  18. Oct 28, 2023 at 11:19 PM
    Morris
    Morris New Member
    03 4runner
    Libugai
    Blue sky07
    so it turns out that it was the actuator
    I wound up taking it to a mechanic, here in Kingston Springs they contacted their guy for programming. He checked everything and said it didn’t need it so they started going through one step at a time checking each component.
    They’ve ordered the actuator. They’ll have it in one day next week and I will be good to go. Thank you guys for all your advice and help.
  19. Oct 29, 2023 at 6:42 AM
    #49
    Bluesky 07
    Russell
    Northern Georgia
    Fingers crossed that it’s solved once and for all.
  20. Nov 3, 2023 at 11:45 AM
    #50
    Morris
    Morris New Member
    03 4runner
    Blue sky 07
    So once this mechanic delved into it a little further, basically the two push rods that the actuator move into the transfer case, had to be unlodged.
    Check everything out. Test drove it. I’ve switched it into high four and low four a couple of times it’s going in and out as it should. Everything is functioning properly.
    Thanks for all your help and input
    MI-FL off roader likes this.
  21. Nov 3, 2023 at 12:52 PM
    #51
    Bluesky 07
    Russell
    Northern Georgia
    That’s great news. Glad it finally worked out. Be sure to work it through the 4WD modes about once a month. The manual says drive it in 4HI for ~10 miles and then briefly cycle through the modes. Directions should be on the back side of the sun visor.
  22. Nov 8, 2023 at 11:54 AM
    #52
    Morris
    Morris New Member
    03 4runner
    Blue sky 07
    Me too!!
    I will do that, I have the original manual as well. Thanks for the info!!!
