4WD not working in my 97 4Runner limited
Discussion in '3rd Gen 4Runners (1996-2002)' started by ktm250, Nov 4, 2017.
  1. Nov 4, 2017 at 7:07 PM
    ktm250
    ktm250 [OP] New Member
    Hey everyone, I know there is a number of posts about this issue, but i'm a little confused on how everything works and all the abbreviated stuff like the solenoids and what not, so I'll just explain the problem. 4wd was working and then all of a sudden I turned it on and it didnt work. When i press the button I can hear something sounding like something is trying to engage. I havent seen the inside of the transfer case before or know exactly how everything locks together for the front wheels to engage, so bare with me. I thought maybe just the light wasnt coming on, but I gunned it on a gravel road to test and its definitely 2wd.
    Tomorrow I will switch the solenoid hoses to see if it works, but from the sound that Im hearing, i have a feeling its a transfer case problem.
    Any advice is appreciated! thanks
  2. Nov 5, 2017 at 3:05 PM
    ktm250
    Update** I switched the vacuum lines on each solenoid and then it seemed to work. The light came on when i press the 4wd button. didnt get a chance to turn in tight circles on pavement to see if it was actually working. Does this mean it's a bad solenoid?
  3. Nov 7, 2017 at 8:00 AM
    Caltech90
    Caltech90 New Member
    '03 Limited 4.7 4WD
    So you switched the hoses and the non-working solenoid worked?
  4. Nov 7, 2017 at 12:35 PM
    ktm250
    No I’m not saying the non working solenoid worked. I’m saying I used the other solenoid to trick it.
    Caltech90 likes this.
  5. Jun 12, 2018 at 6:55 PM
    sillysilly
    sillysilly New Member
    98 4Runner Limited
    Did you swap the hoses, electrical, or both to do this test?
