4runner Trd off road premium with KDSS and lift?
Discussion in '5th Gen 4Runners (2010-2024)' started by titan34, Jul 21, 2021.
  1. Jul 21, 2021 at 6:41 PM
    titan34
    titan34 [OP] New Member
    Hawaii
    Hi
    I’m looking to order my 22 t4r trd off road premium with Kdss soon. I’m looking to moderate lift it to fit 275 or 285 tires and was told 2inch or 2.5 is the most you can lift on a kdss but not sure how true that is. When is the control arms needed? Around 2.5 to 3inch? I would like to see what suspension lifts you running.
    I was looking at bilstein 5100 with stock springs and what height will I need 1inch rear springs in the rear?
  2. Jul 21, 2021 at 6:46 PM
    saltyfrank
    saltyfrank New Member
    Future 21 ORP
  3. Jul 21, 2021 at 7:15 PM
    Rock-N-Roll
    Rock-N-Roll TRD Amateur
    2021 T4R ORP w/ KDSS
    I just lifted my 21 ORP with KDSS using a Toytec aluma boss 2.5. I don't have the before and after measurements but I have 285/70R17s on it. Seems to be good.
  4. Jul 21, 2021 at 7:19 PM
    titan34
    Hawaii
    It’s looks nice! What size rims you running?
  5. Jul 21, 2021 at 7:23 PM
    Rock-N-Roll
    They are KMC Mesa KM544 17x9 /6.139.7 -12mm offset
  6. Jul 21, 2021 at 8:10 PM
    Roland
    Roland New Member
    ORP Lift: Dobinsons IMS59-50700 shocks - coils C59-302 Front 2.7" lift - Dobinsons shocks IMS59-50705 - Coils C59-505 Rear 1.7" lift. No Upper Control Arms needed, with Bf Goodrich KO2 285/70/17 installed about a 4" lift; No body chop or trimming needed, no rubbing. Works wonders.
  7. Jul 21, 2021 at 9:51 PM
    Pavo
    Pavo New Member
    I have kdss, bilstein 6112 5160s max height, 650lb springs on front shocks 1.5 inch old man emu rear spring and camburg ucas
  8. Jul 21, 2021 at 10:12 PM
    Mtbpsych
    Mtbpsych New Member
    I believe at more than 3” you start to potentially have issues with KDSS not being able to accommodate the extended travel.
    This should provide some useful info while you research what lift to go with:
    https://accutuneoffroad.com/kdss-suspension-tech/
  9. Jul 22, 2021 at 4:25 PM
    Vito Corleone
    Vito Corleone New Member
    Georgia
    2022 4Runner ORP
    Current Mods: 3/2 Lift Kit w/Billstein 5100’s SPC Front Upper Control Arms 285/70/17 Michelin Defender LTX TRD Pro Wheels TRD Pro Grill 20% Tint on Windows & Sunroof Pedal Commander Cold Air Kit LED Front Turn Signals Brite-Box Anytime Foglight Kit “Tail as Turn” Rear Turn Signal Kit LED Reverse Lights LED Tag Lights LED Puddle Light Pods Sequential Turn Signals N-Fab 3” Step Bars Future Mods: In-Car Camera System Rear Molle Panel Storage System Magnuson Supercharger (when available)
    I have a 2020 TRD ORP w/KDSS and I had Toytec 3” front and 2” rear springs, Bilstein 5100s all the way around, and SPC UCAs installed. The tires are Michelin Defender LTX in a 285/70/17 on TRD Pro wheels. No other modifications were necessary as far as tire rub. The ride quality is great.
  10. Jul 22, 2021 at 4:33 PM
    How did you get those brown spots on the tires?
    The last breed and Thatbassguy like this.
  11. Jul 22, 2021 at 6:24 PM
    Burnt Taco
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
    Hey Vito. Love the grey Pro wheels. Matt or glossy? Why not (if not) glossy?
  12. Jul 22, 2021 at 8:53 PM
    Bilstein 6112 front, medium load springs at 2.4"
    5100 rear, heavy load 1.5" springs
    No issues yet with a decent amount of off-road use.
    One thing about KDSS to look out for is dirt collecting in the KDSS accumulator skid on the driver's side frame rail. It's easily removed with 2 bolts and should be cleaned out anytime you get dirty. :)
  13. Jul 22, 2021 at 10:11 PM
    DRH
    DRH TRD Broverlander Extraordinaire
    Dave
    Santa Clarita, Ca
    2020 ORP
    It looks like tire blooming, my KO2 are doing it and I have to use a dressing to prevent it.
    https://www.torquedetail.com/blogs/car-detailing/fix-brown-tires-blooming
    As far as KDSS and lifting height, I was almost at 4" in front with no issues before adding the bumper and winch weight taking it down to 3".
    Pavo likes this.
  14. Jul 23, 2021 at 8:18 AM
    Rock-N-Roll
    Good call on mentioning the KDSS maintenence!
  15. Jul 23, 2021 at 9:20 AM
    Super Green
    Super Green New Member
    2020 Army Green 4Runner
    Looks fantastic!
  16. Jul 23, 2021 at 10:52 AM
    Roland
    Roland New Member
    Nice rig, very well done; i like the flow, looks great.
  17. Jul 24, 2021 at 1:00 PM
    Vito Corleone
    Georgia
    2022 4Runner ORP
    Thanks. They are glossy.
    The last breed likes this.
  18. Jul 28, 2021 at 10:48 PM
    Mr.Franko
    Mr.Franko New Member
    2017 TRD PRO
    The one thing I wish mine had (KDSS)
  19. Aug 29, 2021 at 10:33 PM
    Mdkiswani
    Mdkiswani New Member
    Hi there I’m shopping for one now and I’m curious about KDSS.
    What’s the benefit of having it on a 4runner?
  20. Aug 29, 2021 at 10:33 PM
    Mdkiswani
    Can someone please share why KdSs matters and why I should buy a 21 with kdss vs without ?? Thanks
  21. Aug 30, 2021 at 4:10 AM
    There's plenty of debate about this.
    Buy it if:
    1- you want better suspension articulation for low speed, off camber situations
    2- you want less body roll in normal driving.
    Don't buy it if your plans for the suspension include a sway bar delete.
    There are a ton of informative articles about it. Here is one:
    https://parts.olathetoyota.com/kinetic-dynamic-suspension
  22. Aug 30, 2021 at 4:31 AM
    4wheelforlife
    4wheelforlife New Member
    T
    2021 4Runner
    Thanks for the info. I’m going to have to find the location and check mine.
  23. Sep 3, 2021 at 1:03 AM
    Mr.Franko
    2017 TRD PRO
    Roland, 2Toys and Thatbassguy like this.
  24. Oct 10, 2021 at 2:45 PM
    Burnt Taco
    Tucson, AZ
    Roland, do you have any skids? If so, which?
    Thanks
  25. Oct 11, 2021 at 11:12 AM
    Roland
    Roland New Member
    I'm debating on skids, steel is heavy & aluminum is not that strong, nevertheless, better protection than what comes with the 4R. Looking around.
  26. Oct 11, 2021 at 12:04 PM
    I know you didn't ask me, but, if you have KDSS do not buy SOS skids as they're not compatible. Aside from that, the fitment was not great either.
    FWIW, RCI seems to be the most common and not have issues. When I was shopping, I was really liking Budbuilt until SOS had a sale.
    The nice thing is that you're adding weight down low, so it's not going to hurt stability. I don't think you'll see a bad hit to fuel economy unless you do a lot of stop and go driving.
    Just trying to help you spend money! ;)
    The last breed and Rock-N-Roll like this.
  27. Oct 11, 2021 at 12:09 PM
    Rock-N-Roll
    I'd ask you to help me spend money but I'm all out and my wife isn't impressed.
  28. Oct 11, 2021 at 1:00 PM
    Lol! These forums excel at helping their members get rid of money! The best part is that many of the things we buy will eventually wear out, and then we get to buy them again!
    :yes:
  29. Oct 11, 2021 at 3:03 PM
    Roland
    Roland New Member
    I think I'm going to make my own in Titanium 3mm, doesn't rust ;) and is impervious to salts & most chemicals, reflects heat & is much stronger than Aluminum 2.7 g/cm³ - Steel 8.05 g/cm3 - Titanium 4.5 g/cm3. So, Titanium is 45% less heavy than steel. In fact, Titanium has the highest strength-to-weight ratio of all known metals. Maybe I commercialize Titanium skids for the 4R's, you be the first on my list $$$. Lol. I know, Titanium is expensive, hard to machine etc. Price, like I mentioned before it's all relative, some buy rims $900 & some spending $3000 on it. For sure the properties of Titanium are far beyond Aluminum & Steel.
  30. Oct 11, 2021 at 3:09 PM
    Burnt Taco
    Tucson, AZ
    Sign me up
    Group buy?
    Might be a pain to pound out dents..... Maybe there wouldn't be any dents??
