4Runner transmission issues with hard braking.
Discussion in 'General 4Runner Talk' started by collinbrohm, Feb 22, 2020.
  1. Feb 22, 2020 at 8:18 PM
    collinbrohm
    collinbrohm [OP] New Member
    Collin
    2017 SR5 4 runner
    SSO front bumper, 3 inch lift, 17 inch wheels, 33 inch KO2s
    I have a 5th gen 4 runner and sometimes whenever i have to brake hard for whatever reason, the car brakes normally but then the transmission roughly shifts back into gear, sometimes worse than others. Recently, the transmission was acting up for the whole ride after braking for deer, not up shifting or downshift unless i manually did it, and i pushed it to 5k rpms. Anyone else have this issue to the smallest or largest extent? It is now normal after turning the car off, but i don’t know if I’m doing lasting damage to the transmission or any other components
  2. Feb 24, 2020 at 1:13 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    How many miles and have you checked your fluid level lately? If you have the issue again, take it to the dealer. Should still be under warranty.
  3. Feb 25, 2020 at 8:39 AM
    collinbrohm
    Collin
    2017 SR5 4 runner
  4. Mar 5, 2020 at 9:41 PM
    4R4play
    4R4play New Member
    Did you have any luck figuring out the issue? I have had same issue for a while. Assuming it is something with the trans, but definitely no expert. Have 60k miles, and noticed it a while ago. Luckily I don’t do a lot of city driving so don’t have to brake hard a lot.
