4runner Secondary Air injectors
Discussion in '4th Gen 4Runners (2003-2009)' started by Thevault301, Jun 4, 2019.
  1. Jun 4, 2019 at 5:28 PM
    Thevault301
    Thevault301 [OP] New Member
    Joshua
    Appomattox Virginia
    2006 Sr5 All-4WD V8 4Runner
    None all stock
    Okay so i need yalls help! My 4runner has Sent out a code stating that the secondary Air injectors have failed. It Struggles with accelerating over 40. What is this "secondary air injection system" and How do i Fix it. My buddy over at orileys told me that id have to take the whole Top part of the engine off. Is that true? And will this part cause the engine more Damage or am i good to continue to use it as my daily driver
    SonofBert likes this.
  2. Jun 4, 2019 at 6:22 PM
    chassis
    chassis New Member
    Indiana
    Sold: 2005 4Runner SR5 V6 4WD
    Google found this:
  3. Jun 10, 2019 at 3:07 PM
    SonofBert
    SonofBert New Member
    Bert
    '08 T4R LTD 4.7 4WD, '07 T4R LTD 4.7 4WD, '05 Tundra LTD 4.7 4WD, three Tacos
    BOSS lift and airbags
    Absolutely look at that thread Chassis linked. Get the slyfox75 bypass kit, just do it. You're in limp mode already but you may be able to do just the SAIP bypass and don't have to replace valves.
    Anybody with a 2005+ 4.7l V8 has to do the SAIP bypass. It's a no-brainer. Tundra 4.7's, the same. Some Tacoma V6's have the same problem. Just do it.
  4. Aug 10, 2019 at 5:39 PM
    slyfox75
    slyfox75 New Member
    2005 SR5
    Hi guys, I normally frequent "another" 4Runner forum, but I wanted to let ya'll know I supply blockoff plates($40) and AIP bypass($48) for the 05-12 4Runners and other Toyota V8s(Tundra, LX, GX, LC, Seq)
    I rarely frequent the forum, best way to get me is jeffcolemaps at gmail.
    I go by same user name at other sites (slyfox75) if you need to look up other AIP information.
    -Jeff
  5. Aug 12, 2019 at 11:03 AM
    SonofBert
    Bert
    ^^^^ this. I've installed the slyfox75 bypass kit four times, cheap and easy. Just do it and save yourself from a future disaster.
