4Runner needs valve job - advice please
Discussion in '3rd Gen 4Runners (1996-2002)' started by Mistercarguy, Oct 27, 2014.
  1. Oct 27, 2014 at 6:22 AM
    Mistercarguy
    Mistercarguy [OP] New Member
    1999 4Runner
    My 170,000 mile 1999 4Runner has 80 psi in the number 1 cylinder. All the rest are at 190 psi. The engine (2.7 liter 4 cyl) has had regular oil changes with synthetic oils. However, the idle is very rough and the check engine light has come on. I had a valve adjustment done 15000 miles ago thinking that might solve the problem but it has not. My car-smart friends say that I should just swap the head and keep driving (it's a great vehicle in otherwise good shape). Any suggestions or a source for a quality replacement head with associated gasket set? Sorry if this has been solved already - asking for newbie dispensation!
  2. Oct 27, 2014 at 2:40 PM
    Utah
    Utah Misanthrope
    Land of Fake Beer
    The Gray Bastard
    3RZ, OME, 5.29s, 4.7, locked/locked
    How do you know it's a bad valve causing the low compression? Could be a head gasket, could be piston rings...
  3. Oct 27, 2014 at 2:53 PM
    Ol'Blue
    Ol'Blue New Member
    "Not all who wander are lost"
    I say your car-smart friends are spot on but that is just my .02 on the matter. BUT if the lower end is shot and you waste the money on a head that is not the problem that will suck. So really either way the engine will need to be tore apart and really looked at. I would almost see if you can find a low mileage engine and just do a swap. Keep the extra block and head and build them when you have the time and funds.
    Blue
    RingSteel likes this.
  4. Oct 28, 2014 at 4:34 AM
    Mistercarguy
    1999 4Runner
    Thanks. Good feedback. Since the engine uses no oil between changes and is quiet, I think the bottom end and rings are probably ok. Any suggestions for a vendor for a replacement head?
  5. Oct 28, 2014 at 2:53 PM
    downpour11
    downpour11 Slag Factory Off-Road Vendor
    Rob
    Chico, CA
    96 4Runner SAS
    http://www.lceperformance.com
  6. Dec 22, 2014 at 9:02 AM
    nj636
    nj636 New Member
    2006 Radiant Red Tacoma Double Cab Short Bed
    OME lift / 285's / Armor
    Late reply but you should do a leak down to narrow down if it's rings, head gasket, valve(s)
