4Runner = giant rusty bed spring moving through town.
Discussion in '5th Gen 4Runners (2010-2024)' started by whitebessy, Apr 17, 2024.
  1. Apr 17, 2024 at 1:47 PM
    whitebessy
    whitebessy [OP] New Member
    2013 Limited 4Runner
    Have your attention?
    Great - now help save me from the ridiculous embarrassment that is driving my 2013 4Runner Limited, 165K! Please!
    If you live in my town, you can hear me coming because SOMETHING under my car is making the most heinous squeaking noise. I've taken it to the dealership 2x, and while they've been able to replicate the sound, but can't figure out where it is coming from - before they start replacing random parts, or I just accept that this is now my life - White Bessy Jalopy - any ideas? I can hear it after I stop for a few seconds, so would make sense it is something in the suspension? I have approx 165K on it and mostly highway. Temperature changes seems to impact the decibel level of the rusty bed springs creak....but I live in MD, where the seasons change daily, so temperature isn't really the best measure of performance.
    Ideas? Thanks!
  2. Apr 17, 2024 at 3:43 PM
    steelevo
    Utah
    Welcome. If it’s the suspension, you should be able to replicate it by rocking the 4Runner back and forth.
    Harringbr99 likes this.
  3. Apr 17, 2024 at 3:55 PM
    Acesandeights
    Acesandeights Newbie - always learning
    So Oregon
    1938 4Runner
    Sounds like a reason for an upgrade. Time for a mild lift with new tires. You're welcome.
    Ironguy likes this.
  4. Apr 17, 2024 at 4:14 PM
    Ironguy New Member
  5. Apr 17, 2024 at 6:47 PM
    I accidentally sprayed woolwax (greasy spray) on one of the rear coil spring seats, and it started to creak. You might have luck verifying if it’s the coil springs, by spraying water or brake cleaner and driving immediately to see if it stops.
    If a coil is the culprit, you might need to take it off and clean the coil seat, maybe clean any rust off and repaint. You might as well inspect the isolator (spring bump stop (it caps the top of the coil. Maybe it wore through the rubber.
    Rocko9999 and Harringbr99 like this.
  6. Apr 17, 2024 at 10:30 PM
    Just realized you didn’t mention where the noise is coming from. Given the mileage, it also could be any number of suspension bushings (especially any aftermarket bushings), or maybe even ball joints.
  7. Apr 18, 2024 at 8:34 AM
    JET4 New Member
    welcome
  8. Apr 18, 2024 at 9:07 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    This. Use wd-40 or similar not so great lubricant. Start with one bushing or spring at a time each time you drive until the noise goes away-fix last item sprayed.
  9. Apr 18, 2024 at 9:11 AM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Welcome from Denver! Can you take a video & post it. Make sure its not a loose heat shield
