4runner 2/1 lift with stock 265 tires and negative offset wheels
Discussion in 'New Member Introductions' started by 4rguy, Apr 14, 2025.
  1. Apr 14, 2025 at 9:36 AM
    4rguy
    4rguy [OP] New Member
    2014 4runner trail w/kdss
    Eibach stage2 lift 2/1
    Hello guys,
    Feeling wonderful to be in 4r community. I have a 2014 trail w/kdss and really love my 4R!!. Recently upgraded suspension to eibach stage2 2/1 lift after a lot of research and i really like it. I Dont do much offroading. Next is wheels and tires. Really confused with 265 and 285 tires option. Can you guys share pictures of you 4r with 2/1 lift and running 265 with negative offset wheels.
    Thank you
  2. Apr 14, 2025 at 10:21 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    Hello, l’m not sure I have exactly what you’re looking for, but here’s some fresh pics of my 2022 SR5 Premium 4WD. No KDSS.
    I have stock size 265/70R17s, in the Standard Load (SL) rating. They are SUMITOMO ENCOUNTER AT tires. SUMITOMO Rubber Company owns Falken Tire. My tires were made in Thailand. I really like them. I rarely go off road, but I wanted the AT tire look, and they ride and look great.
    I had the front end lifted some at an off road shop. I bought the Bilstein model 5100 front shocks and the shop set them to the second from highest height position. (I think that raised the front end either 1.75” or 1.85”? Sorry, can’t remember for sure. But I like the way it looks. I didn’t do anything yet to raise the rear end. I like the way it sets as is just fine, but I run empty of any heavy loads in the cargo area the majority of the time anyway.
    The wheels are the Toyota factory alloy wheels. I don’t have any spacers behind them. Sorry, not sure what you’re talking about when you ask about “negative offset”?
    4rguy[OP] and leftyfire like this.
  3. Apr 14, 2025 at 10:32 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    285/70/17
    Stock, 0 offset. No BMC, stock upper control arms. Rubs in reverse, full lock. Dont care. Some do.
    I have a slight lift now, same size tire.
    40449316_10209303190336409_4517046753362444288_n.thumb.jpg.956b5e5fbdd13a51abce812699528cf1.jpg
    EDIT- I dont know what your goal for the rig is, but,. .... Please do your OWN research. Kai is a killer start with IFS/Toyota myths and info.
    https://www.youtube.com/watch?v=LAYGdcKSA3o
    4rguy[OP] likes this.
  4. Apr 14, 2025 at 12:11 PM
    4rguy
    Nice looking 4runners!!.thank you for sharing. I am aiming for an aggressive look with stock size all terrain tires. Just wanted to see guys running 2inch lift 265 tires with negative offset wheels.
  5. Apr 14, 2025 at 12:14 PM
    Not exactly what you asked, but this is mine with a 2.4"/1.5" lift, and 265/70/17 KO2's. Wheels are 17×9, -6mm offset.
    Ironguy and 4rguy[OP] like this.
  6. Apr 14, 2025 at 12:25 PM
    4rguy
    Looking good!. did you had any rub?. Thanks for sharing. This is my 4r now
  7. Apr 14, 2025 at 12:37 PM
    Thatbassguy and 4rguy[OP] like this.
  8. Apr 14, 2025 at 12:53 PM
    Mine would rub slightly usually while braking and turning, like getting ready to back into a parking spot. It was just rubbing on plastic, so I could have fixed it with a little trimming and/or possibly a heat gun on the fender liner.
  9. Apr 14, 2025 at 2:37 PM
  10. Apr 14, 2025 at 3:54 PM
    welcome
