4Lo blink, hard to get in gear. Anyone else?
Discussion in '5th Gen 4Runners (2010-2024)' started by Hyper15125, May 22, 2018.
  1. May 22, 2018 at 4:56 AM
    Hyper15125
    Hyper15125 [OP] Headlight Retrofitting Hobbyist
    NJ (609)
    ‘14 SR5 T4R, ‘13 Taco TRD Sport DCLB, ‘02 SC430
    My wife has a ‘14 4x4 SR5 with 53k and complained that the 4Lo light has been blinking intermittently and when it happens she has a hard time getting the shifter into drive.
    Anyone else have this problem and if so have you taken to the dealer and what did they say?
    I could not replicate the problem, however, I found someone posted the same issue on T4R.
    I have extended warranty and want to get it fixed.
  2. May 23, 2018 at 5:21 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    the 4WD knob is on the shift console .. she spill coffee on it or ???? my guess is the switch .
    BassAckwards likes this.
  3. Oct 9, 2018 at 1:19 PM
    DeckerBits2899
    DeckerBits2899 New Member
    What was the resolution of this? I have a 2012 4Runner Limited and I’m having the same problem.
    TIA.
  4. Oct 9, 2018 at 1:21 PM
    Hyper15125
    NJ (609)
    It hasnt happened again as of yet.
  5. Oct 9, 2018 at 1:24 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    jgcaps likes this.
  6. Oct 9, 2018 at 1:27 PM
    Hyper15125
    NJ (609)
    Ha! No kidding.
  7. Oct 9, 2018 at 11:46 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Has it been shifted into 4lo recently? Most never have reason to use it, but It's good to do once in awhile to keep things moving. We had one that seized due to lack of use (that's my guess, anyway). After MANY attempts, we finally got it to engage with a big thump. I don't know if that would be advised, but it worked and is still just fine.
  8. Oct 10, 2018 at 5:11 AM
    Hyper15125
    NJ (609)
    Only used 4Lo once years ago to test it out and nothing was spilled on the switch as someone else postulated.
    She said it only happened a handful of times but A search revealved that it has happened to others also.
    I am sure I will get the “cannot duplicate customers concern” when I take it in but at least it will be on the record. Hopefully if its gonna do it again and break it will be before the expiration of my extended warranty.
  9. Oct 11, 2018 at 9:43 PM
    WallyT4R
    WallyT4R New Member
    Every one should exercise these systems on a fairly regular basis to keep things lubed and functioning like they should. This will also help recognize problems if there should be any. I drive mine in 4x4 at least 10 miles a month like the manual says to and usually put it in 4 low and engage the locker about every two months. It's just good practice.
    jgcaps likes this.
  10. Oct 12, 2018 at 5:54 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    if u dont use it you looze it.
    jgcaps likes this.
