4hi vibrations need help!
Discussion in '4th Gen 4Runners (2003-2009)' started by 4thgenlyfe, Sep 17, 2022.
  1. Sep 17, 2022 at 6:36 PM
    4thgenlyfe
    4thgenlyfe [OP] New Member
    malick
    2005 4runner 4.0 v6 4x4
    bilstein 5100's, ome coils, freedom offroad upper control arms, hayden 699 trans cooler
    2005 4runner V6 4x4
    I've been obsessively chasing vibrations through the floor that only happen in 4hi(center diff unlocked), the vibration occur in rising speeds between 45-55mph and get worse with heavier acceleration. This only happens in (4hi), when driving in 2hi the truck drives smooth with no issues.
    Diff fluid and tcase fluid are good and trans fluid is red!
    I also retorqued all my suspension components and took the front drive shaft for new u-joints and balancing however the vibration is still there. Any ideas ?
  2. Sep 25, 2022 at 7:44 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    CV shafts? Wheels bearings? tie rod ends? motor mounts? t case mounts?
