4.0 Separation Anxiety? This might help…
Discussion in '6th Gen 4Runners (2025+)' started by 4Hopper, Apr 13, 2025.
  1. May 6, 2025 at 10:19 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    don’t forget decreased interior size, and an increased exterior on top of the over-bloated truck era we already live in :p
  2. May 6, 2025 at 11:34 AM
    Wait until you realize that, even with the V6, the 1st gen still had a much worse power to weight ratio than the 6th gen. ;)
    icebear, Mr.DRZ and djwantke like this.
  3. May 6, 2025 at 12:39 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    You are so right, when are you trading in your slow underpowered ancient old outdated 5th gen for the 6th gen?
  4. May 6, 2025 at 12:41 PM
    Toolguy73
    Toolguy73 New Member
    Dom
    South Jersey
    2023 Limited White/Redwood
    I watched an ABC video about China. FoxConn has a multi story factory there that makes IPads. There is netting extending out from the building on all four walls to catch people trying to commit suicide by jumping from the upper floors.
    FourBelugas likes this.
  5. May 6, 2025 at 12:47 PM
    FourBelugas
    23 white ORP
    Surely in Mexico, workers for foreign firms are treated with the upmost respect in regards to their welfare, pay, health care, mental health and work place safety. It's basically turned into France in terms of workers' rights since the beginning of NAFTA, didn't you hear?
  6. May 6, 2025 at 1:30 PM
    Mr.DRZ
    Mr.DRZ Newish member
    2024 ORP
    You're fixated on this concept that saying something positive of the 6th gen means you must be buying it. Why is this?
    icebear, McSpazatron and Thatbassguy like this.
  7. May 6, 2025 at 1:33 PM
    FourBelugas
    23 white ORP
    Or we could ask why is this that people are fixated to praise things they have no vested interest in or first hand experience with.
  8. May 6, 2025 at 2:15 PM
    I know you didn’t actually ask that question, but I can be fairly literal sometimes. If the question wasn’t a rhetorical one, I’d say there are plenty of things in life that can be appreciated and praised without having a desire to buy, own, or do it. For example, I can love a Ferrari F40 for a million different reasons, think about it constantly, yet not want to buy one even if I had the money. I can love and appreciate certain musical styles and have no desire to become a musician.
    In fact, I could even learn to appreciate and praise aspects of things I actually don’t like! But that’s borderline an actual skill to be able to do that. Some people think that’s hypocritical, but it’s not. For example, I appreciate that
    many people in the world eat bugs. I would praise anyone that can collect and cook them to feed themselves and their family. They’re healthy when properly prepared, an abundant food source in many places, a good source of protein and fats, and probably go good with ketchup.
    Would I eat a bowl full of crickets? Hell no!
    Thatbassguy and Mr.DRZ like this.
  9. May 6, 2025 at 2:17 PM
    Mr.DRZ
    2024 ORP
    The burden of both questions falls on you because you invented the contingent condition.
    icebear and Thatbassguy like this.
  10. May 6, 2025 at 2:53 PM
    FourBelugas
    23 white ORP
    Feel free to gather the abundant number of quotes from the 6th gen praisers have made fawning statements without ever owning one. Burden is on you, once again. Have fun sorting through it all, seems like you are good at using the multi-quote. LOL.
  11. May 6, 2025 at 2:58 PM
    FourBelugas
    23 white ORP
    The 6th gen 4R is neither classical music nor an F40, in contrast it is very attainable to anyone who wants one, no need for millions of dollars or a life time of rigorous training to get into one. In fact I have been told here on numerous occasion the price increase from the 5th gen is reasonable and well worth it, given how everyone's 5th gen trade in values are sky high, the jump is minimal, I'm sure.
    Given all the upside and virtually zero downside, the stampede of old timers trading theirs in and showing off their 25 or 26 MY units must be inbound any minute now.
  12. May 6, 2025 at 3:45 PM
    Mr.DRZ
    2024 ORP
    By your own logic and my amazing multi quote skills, you would be selling your 5th gen because your are saying negative things about it calling it slow, a dinosaur and underpowered.
  13. May 6, 2025 at 3:47 PM
    FourBelugas
    23 white ORP
    I'm just quoting the numerous 6th gen experts in deference to their expertise and experience on the matter.
    You would know that if you pay attention to their eloquent, informative, and convincing posts instead of, what was it, on yeah, being fixated on me alone.
    But hey, here we are, in a thread full of people with '24s talking about how great the 25 is. Nothing weird about that.
  14. May 6, 2025 at 3:51 PM
    Mr.DRZ
    2024 ORP
    No you didn't quote them, you said it. If you'd like help learning to quote I'm happy to help.
  15. May 6, 2025 at 3:52 PM
    FourBelugas
    23 white ORP
    LOL.
    Feel free to attach your TED Talk here for everyone's benefit. I can't even read so please post a video.
    Mr.DRZ[QUOTED] likes this.
  16. May 6, 2025 at 4:27 PM
    cuse93
    cuse93 Ice Station Zebra
    5 years ago I could have walked into a Toyota dealership and been very happy to drive home with a new Tacoma, Tundra, 4R, Sequoia, or Land Cruiser. I loved them all and put my money where my mouth was having purchased 4 new Tacomas, 4 new Tundras, and 2 new 4R's over the last 25 years. In retrospect, I really wish I bit the bullet at the time and bought a new '21 Sequoia Pro or LC Heritage as a forever vehicle.
    I wouldn't touch anything new on a Toyota showroom floor right now. IMHO, every component of these new vehicles looks and feels like it was designed first and foremost to cut manufacturing costs. Everything looks and feels lighter, cheaper, and more disposable to me. Did they lower the MSRPs? No. Did performance meaningfully improve? No. Did off-road capabilities improve? No. Did aesthetics improve? No. Did safety or economy improve meaningfully? No. Did overall functionality improve? No.
    I bought my wife a new 6.2l Silverado a few months ago and didn't even consider a new Tundra. It makes me sad. If I was ever going to get back in a brand new mid-size pickup I'd buy a Ranger Raptor. If I was ever going to buy a new SUV again I'd be cross shopping the GX and Ineos.
    RIP Toyota
  17. May 6, 2025 at 7:57 PM
    It’s sad. I don’t think I would trust the GX either.
  18. May 6, 2025 at 10:08 PM
    FourBelugas
    23 white ORP
    Toyota has slowed the flow of the GX550 to a trickle at this point, there are 0 in stock within 150 miles of the SF Bay Area right now, and only 12 in transit. Something tells me they are not confident with it either else they won't be so slow to crank out units that sticker for upwards of 90k in some trims.
  19. May 7, 2025 at 3:37 AM
    #49
    cuse93
    Yep. Here too. My preferred trim level would be a base Overtrail and I still haven't seen one in person and the handful that have hit area dealers over the last year have all been pre-sold. Toyota is definitely throttling production of them........ why? I'm not really sure. But i'd guess that protecting LC and 4R sales has something to do with it.
  20. May 7, 2025 at 5:22 AM
    #50
    NoDak
    NoDak New Member
    JR
    North Dakota
    fed rules in the 80s vs now are completely different for crash worthiness.
    if you didnt have all the crumple zones, deflection zones and what not to keep you safe in a crash, the vehicle would be a lot lighter.
    add on top of that cafe standards, tailpipe emissions, and safety systems, those all add weight to implement those systems.
  21. May 7, 2025 at 6:51 AM
    #51
    They are probably trying to protect Lexus from a big engine recall and taint the brand’s reliability.
  22. May 7, 2025 at 7:19 AM
    #52
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    I appreciate the features the 6th gen offers, power, tech, modern styling but myself being old school my priorities are simplicity. I own one turbocharged vehicle but it is stone age(21yrs old) tech in comparison to the 6th gen. The main reason I bought a 5th gen before they were gone is it is pretty much a known long term quantity. If the 6th gen is attractive to you, go for it, but don’t berate the 5th gen.
    2Toys and TejasRunner like this.
  23. May 7, 2025 at 8:45 AM
    #53
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Yes, but those were the days when vehicles were built and tuned for reliability and longevity. We did not buy a 4Runner for their performance or fuel economy.
    2Toys likes this.
  24. May 7, 2025 at 2:16 PM
    #54
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You can compare, toyota has a 4 cylinder turbo that has the same power/torque and mpg and the dinosaur 4.0. So what are you gaining?. I'd love to own a 6th gen. But the build quality of toyota had been decreasing. And I. Extremely happy with my 5th gen
  25. May 7, 2025 at 2:38 PM
    #55
    FourBelugas
    23 white ORP
    From what I've seen people say here, it feels a lot faster, yet the 465lb/ft I-forceMax LC250 is slower than the 5th gen, and I have not seen actual test data on a gas model 6th gen yet beyond "estimated" like Car and Driver or Motor Trend.
    The other elephant in the room that seems to get lost in the discussion is the transmission. In previous cases I have seen, when vehicles with 3 to 4 liter NA v6 switch from 5 speeds to 8 speeds, there is typically a 15-20% improvement in acceleration to 60, such as in the cases of Dodge Charger/Challenger and Jeep Wrangler, where going from the W5A580 to ZF 8HP in the early 2010s lowered the 0-60 times from mid 7s to mid 6s. So it's hard to say if people's description of faster "feel" is due to the motor or the gearbox.
  26. May 7, 2025 at 2:40 PM
    #56
    You're gaining a lot more usable torque. This might only be really meaningful to those who tow regularly.
    I don't know if it's a lack of build quality, or what the problem is with the newer trucks. But, even if I really wanted one, I'd want to wait a year or two to see if they get everything straightened out.
    Slopemaster likes this.
  27. May 14, 2025 at 1:32 PM
    #57
    gkomo
    gkomo New Member
    San Diego, CA
    2004 4Runner Limited V8
    I own a 1990 Foxbody Mustang 5.0. I also think the S650 is superior to it in every way, looks great, is a great value for a muscle car with a v8 RWD manual. Doesn't mean i'm gonna trade my Foxbody in for it. In fact, ive never even sat in a newer S550 or S650 mustang, but i already know the newer ones are better. Can own one and still appreciate the other. Just in response to the posts above. Same as any 5th gen (or any gen) 4runner owner praising the newer model without needing to go buy it or even having no intention of buying it.
    bancroftdg and icebear like this.
  28. May 19, 2025 at 8:15 PM
    #58
    4.0 separation anxiety when the combustion engine itself might be gone? Lexus just dropped a battery electric version of its mainstream ES model:
