3VZE hot start issues
Discussion in 'General 4Runner Talk' started by Dark Knight, Mar 20, 2020.
  1. Mar 20, 2020 at 4:35 PM
    Dark Knight
    Dark Knight [OP] Get off my lawn
    My 3.0l is an all new long block. The issue is on hot start. Even with the old engine when starting at operating temp, RPMs would drop from 850(norm) to about 500 after sitting for about 30min.
    I found the BVSV to be broken. This is the vacuum valve on the coolant sensor block that connects the fuel evap canister to the throttle body via the temperature activated BVSV.
    After replacement today I went out for a drive, parked it, let sit for about 30min, and went to start the engine. Well, it was worse than before. I tried to start it 3 times and it would stumble and die.
    I finally removed the gas cap and started it again and the engine did finally start up.
    Who has knowledge with this? Seems I may be getting too much fuel on hot start and it’s flooding out?? Cold start injector leaking?
  2. Mar 20, 2020 at 4:59 PM
    gunsnob
    gunsnob New Member
    Vince
    I would guess your right... flooding... too much fuel/air mix?
  3. Mar 20, 2020 at 5:19 PM
    Dark Knight
    Maybe flooding?? Not exactly sure yet. I’m just disappointed that fixing a component made another factor worse. I point to the cold start injector possibly leaking because this issue is on a hot start after resting for a period.
  4. Mar 20, 2020 at 5:21 PM
    gunsnob
    gunsnob New Member
    Vince
    yup. it's always how it goes... one problem masking another...
  5. Mar 21, 2020 at 6:24 AM
    Dark Knight
    No engine trouble codes when checked this morning.
  6. Mar 25, 2020 at 10:32 AM
    Dark Knight
    New coolant sensor to ecm didn’t produce results.
