3VZ-E replacement cylinder heads?
Discussion in '2nd Gen 4Runners (1990-1995)' started by Fourtoad, May 8, 2019.
  1. May 8, 2019 at 5:10 AM
    Fourtoad
    Fourtoad [OP] Gatorgrl's Yotas
    Gatorgrl
    SWFL
    1991 V6 5 speed super clean, Black and grey
    Stock with headers and after market wheels.
    Looking at replacing our factory cylinder heads in our 3.0. Any opinions on who's got decent ones?
    Does anyone have any experience with King cylinder heads?
  2. May 17, 2019 at 2:59 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    Looked seriously at DOA but did the clean up and port matching my self to save time and money. The rotary sanding drums on the end of a 10,000 rpm die grinder make short work in getting things sorted out for the port matching and removing as cast roughness in the plenum intake manifold and head ports. I made a valve spring compressor with a big c-clamp and a bit of PVC pipe. I replaced the exhaust valves, valve guide seals, lapped the valve seats in the heads and cleaned the intake valves using my Jacobs 3/8 chucked Milwaukee Power drill in a vise. It takes some time but then you know it is done right! As for the flatness I just lapped the heads as they were not warped. The valve lash after lapping the seats didn't change things and so the shims were still within spec for the clearance. Using Loctite 515 for the CAM bearing caps at the ends of the heads works really well but the jury is still out on how to seal up those blasted black rubber covers at the end of the CAM shafts. Mine are spewing oil after 6 tank fulls of fuel since the break-in/rebuild. I used Halomar and am thinking it was bad choice for this gasket sealing requirement?
    Fourtoad[OP] likes this.
