38" tires on a 3rd gen?
Discussion in '3rd Gen 4Runners (1996-2002)' started by Skrapz7015, May 2, 2016.
  1. May 2, 2016 at 3:44 PM
    Skrapz7015
    Skrapz7015 [OP] New Member
    Brian
    3rd Gen 4runner
    I bought some 38" tires from craigslist and they seem huge. Has anyone put this size on a 3rd gen?
  2. May 2, 2016 at 6:42 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    usually the biggest people do is 3" and a body lift if you want more height, and that allows for a 33"-35"
  3. May 2, 2016 at 8:38 PM
    v_man
    v_man New Member
    Vincent
    90 4Runner
    so you bought the big tires without lifting the truck first ?
  4. May 3, 2016 at 5:14 AM
    Skrapz7015
    Brian
    3rd Gen 4runner
    It was an impulse purchase. I saw them for a very cheap price and just bought them now I don't know what to do with them.
  5. May 3, 2016 at 5:18 AM
    Erik65
    Erik65 New Member
    Central MA
    1998 4Runner SAS trail rig. 2011 Tacoma TX Pro
    My 98 has had 38s on her. I have a set of them on beadlocks and a set of 35s (currently on her). If your rig is still IFS you've got your work cut out for you squeezing that much tire in the wheel wells
  6. May 3, 2016 at 10:22 AM
    Skrapz7015
    Brian
    3rd Gen 4runner
    Do you have a pic with the 38s on her
  7. May 3, 2016 at 10:25 AM
    BestGen
    BestGen Member #57
    Paul
    Haunted Turnbull Canyon, CA
    May have to install the 'Sawzall' lift. Your CVs are gonna love 38s!
  8. May 3, 2016 at 10:28 AM
    v_man
    v_man New Member
    Vincent
    90 4Runner
    At this point I'd be more concerned with actually turning the 38's, as in having the gearing to move larger and heavier tires ... if you havn't re-geared your diffs , your stock motor and stock diffs are going to struggle constantly ...
  9. May 8, 2016 at 5:51 AM
    Erik65
    Erik65 New Member
    Central MA
    Not currently I'd have to swap them on to snap one--btw this is an SAS rig so not sure if it would be an apple to apple comparo
  10. May 19, 2016 at 2:40 AM
    RussToy
    RussToy New Member
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    If I were you...sell the tires! Unless you plan on spend a good bit of money and a whole lot of work...those 38's will never fit! I'm running 33's...with a 3" lift w/ 1" body lift and taken out my pinch weld. And occasionally my tires still rub.
    35's you break out the sawzall and start cutting the foot-well out! Anything bigger...SAS. That's about the only way you can achieve higher lift to fit the tire.
    Sorry for the bad news...cheers!
  11. May 20, 2016 at 5:15 PM
    Ol'Blue
    Ol'Blue New Member
    "Not all who wander are lost"
    You can buy my ready to drive SAS Rig and just put the tires on it. It has 37's and I'm sure 38's would be no issue at all. That problem would be solved. Just saying.
    Blue
  12. May 22, 2016 at 4:53 AM
    Erik65
    Erik65 New Member
    Central MA
