34x10.5 tires on 3" lift
Discussion in '5th Gen 4Runners (2010-2024)' started by Elkhuntr, May 15, 2024.
  1. May 17, 2024 at 7:25 PM
    scottiezilla
    scottiezilla New Member
    yup, yup…I’ll fall on that sword
  2. May 17, 2024 at 7:46 PM
    I have held and hard...from going to 34's and even 35's as I just hate the idea of the BMC which I know is totally safe and fine, but the extra trimming that needs to be done around the fenders and inner areas just seems to add more cutting and prep all around. I think if I get into offroading more and more I will probably go for it one day, but for now the occasional light trail and mall crawling is all I got.
    1SilverRunner likes this.
  3. May 24, 2024 at 2:42 PM
    Try Harder
    Try Harder New Member
    Steve
    15 4runner limited
    None yet.... emphasis on yet
    I agree, I kinda like a smaller tire so the suspension shows... dropping my 275/70/17 for 265/70/17 tomorrow morning
  4. Aug 21, 2024 at 6:12 PM
    johnnyg182
    johnnyg182 New Member
    2019 TRD Pro
    2” lift - SPC UCA - 285s - RCI skids - C4 Gas Skid - C4 Sliders
    Do you fit the 34” spare underneath fully inflated? Also, what is your total wheel offset with the spacers you run? Looks good!
  5. Aug 21, 2024 at 8:50 PM
    Mountain_Raider
    Mountain_Raider New Member
    Ben
    2023 TRD ORP Midnight Black
    Send it!
    My understanding is that the fitment cut-off size for the spare tire area (Gen5 4R) is somewhere in the 33" to 34" diameter range. However, since each vehicle is going to be built a little differently as well as each tire size for each tire manufacturer, you just gotta try the tire you have in the spare location on your vehicle.
    For my truck, I have a set of BFG KO2 295/70R17 tires and was able to fit my 5th in the OEM spare spot with maybe 1/16" to 1/8" of play. It does protrude down a bit, though. Thankfully, it's a temporary solution as I'm planning to get a high clearance bumper and swing-out tire carrier later this year.
  6. Aug 21, 2024 at 8:56 PM
    godamn that ugly cut is.. just so noticeable and UGLY!!!
    grizzlypath likes this.
  7. Aug 21, 2024 at 8:59 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Do you have KDSS? My LT285/70 spare is a tight fit, but tested a bit and I don’t believe it will ever make contact with the sway bar, or am I wrong? Lol
  8. Aug 21, 2024 at 9:44 PM
    Mountain_Raider
    Ben
    Send it!
    I do have KDSS. And... just crawled under the truck to check your request and reality-check my confidence.
    The tire has been in the spare spot for about 3000 miles. It appears to have 'settled' against the rear bumper and left at least 1/2" to 1/4" of space between the tire and the KDSS bits and sway bar. I do have the KDSS spacers and BOTCK which may account for some variation in how your situation would be. There does not appear to be any rubbing anywhere on the tire or nearby parts. Although, I haven't taken the truck for any serious off-roading since putting the tire there.
    Here's what it looks like as of tonight...
    grizzlypath and djwantke[QUOTED] like this.
  9. Aug 22, 2024 at 5:34 AM
    johnnyg182
    2019 TRD Pro
    When I offroad I pull the spare and put it in the cargo area. When it’s underneath it’s one more thing that gets hung up when crawling over really rocky stuff. I know some fit the 34” tire underneath and some don’t. I don’t have kdss. I’m going to gamble that it will fit. I do want to get the Outgear solutions rear swing out bumper though :)
  10. Aug 22, 2024 at 6:49 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Yes a 285/75/17 fits underneath just fine IF you don’t have KDSS. It does hang a little low but it fits.
    Here’s the setup with my new rear bumper setup plus the full size 34” spare
  11. Aug 22, 2024 at 6:53 AM
    1SilverRunner
    Tejas
    Im running 285/75/17 falken AT4W’s on RRW 17x8.5 -12 wheels with spidertrax 1.25” spacers. This is equivalent to the more common wheel size of 17x9 -38
    Photos next to a stock 4R^
