33s on 17x7 TRD rims???
Discussion in 'Wheels & Tires' started by VentureRunner, Mar 24, 2021.
  1. Mar 24, 2021 at 12:55 PM
    VentureRunner
    VentureRunner [OP] New Member
    CJ
    2020 4Runner Venture
    None... Yet :)
    Hey all,
    I need some help. Current set up: 2020 Venture on Eibach pro lift kit, JBA UCAs, 265/70,17s (stock size), on stock TRD gunmetal rims.
    I want some 33s on there. I'm open to pizza cutters, but exploring all options. I knew there were issues with rubbing fender and body mount at certain sizes, but now I'm hearing there's issues with rubbing the UCAs?
    I'm confused as hell, and not sure how to get bigger tires on there on a path of least resistance (or rub in this case, lol). Anyone with similar set ups that have recommendations?
  2. Mar 24, 2021 at 1:05 PM
    Vito Corleone
    Vito Corleone New Member
    Georgia
    2022 4Runner ORP
    Current Mods: 3/2 Lift Kit w/Billstein 5100’s SPC Front Upper Control Arms 285/70/17 Michelin Defender LTX TRD Pro Wheels TRD Pro Grill 20% Tint on Windows & Sunroof Pedal Commander Cold Air Kit LED Front Turn Signals Brite-Box Anytime Foglight Kit “Tail as Turn” Rear Turn Signal Kit LED Reverse Lights LED Tag Lights LED Puddle Light Pods Sequential Turn Signals N-Fab 3” Step Bars Future Mods: In-Car Camera System Rear Molle Panel Storage System Magnuson Supercharger (when available)
    I went with a Toyotec 3” front and 2” rear lift with Bilstein 5100 shocks all the way around. I also have SPC front UCAs. I have 285/70/17 tires on TRD Pro wheels (17 x 7). I have absolutely no tire rub anywhere and I did not have to modify anything.
  3. Mar 24, 2021 at 1:12 PM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    @VentureRunner , Mind posting some pics of your ride in its current setup? I'd love to see. :)
  4. Mar 24, 2021 at 7:31 PM
    kailuakona04
    kailuakona04 New Member
    2020 MGM Off-Road Premium
    In-Progress.
    I'm running KO2s with 285/70/17s on the stock ORP rim with the ICON Stage 7 kit on all 4 corners. Had a bit, I mean a smidgen of tire rub on the front mud flaps but not worth even bothering with. Now that I have the Spidertrax spacers installed,....well the mud flap does no good anyway so I removed the mud flaps completely.
  5. Mar 24, 2021 at 9:55 PM
    Dealership did my spacer lift when I bought it, along with 285 RG's on TRD Pro rims.
    All they had to modify was the front inner fender nip and tuck.
    Front mud flaps are still installed. Zero rubbing issues and no wheel spacers.
    A friend with a similar lift, 285 BFG's and aftermarket rims had to remove the mud flaps. Her wheels stick out about 1" farther than mine.
    MedicineMan4040, T4R4L and nimby like this.
  6. Apr 10, 2021 at 8:12 AM
    Mariopatalinjug
    Mariopatalinjug New Member
    Mario
    Hi! Can someone help me. I already bought the shocks and little did I know about the rubbing. Do you think it will still rub on my end? and how much lift do I need to do with these lift kits? I appreciate any advice you guys can give.
    Fox 883-02-025 3" Front Factory Race Series 2.5 Coil-Over IFP Shock Pair
    Fox 985-24-124 0-2" Rear 2.0 Performance Series Smooth Body IFP Shock
    Camburg Toyota 4-Runner 03-21 | FJ 07-14 KINETIK Series Billet Upper Arms
    BF Goodrich Tires 285,70,17
    TRD Matte wheels 17"
  7. Apr 10, 2021 at 12:56 PM
    Charlievee
    Charlievee New Member
    Fyi, from the JBA website/product page...
    Please Note: 32.5" and larger diameter tires need aftermarket wheels with less then factory wheel back space.
    • LT285/70R17 (32.7" x 11.2") tire on 17 x 9 wheel, -12mm offset (4.50" backspace)
    • LT285/70R17 (32.7" x 11.2") tire on 17 x 8.5 wheel, -9mm offset (4.30" backspace)
    • LT285/70R17 (32.7" x 11.2") tire on 17 x 8.5 wheel, 0mm offset (4.75" backspace)
    • LT285/75R16 (32.8" x 11") tire on 16 x 9 wheel, -19mm offset (4.25" backspace)
    • LT255/85R16 (33.10" x 10") tire on 16 x 8 wheel, -12mm offset (4" backspace)
    • LT315/70R17 (34.4" x 12.4") tire on 17 x 9 wheel, -25mm offset (4.00" backspace)
    • Any tire that is 32.2" diameter and smaller there is no fitment problem.
    Tire sizes that work well with the JBA UCAs
    • 265/75R16 tire 31.6" x 10.4" on factory wheels
    • 255/75R17 tires 32.1" x 10" on factory wheels
    • 275/65R18 tires 32.1" x 10.8" on factory wheels
    • Any tire that is 32.2" diameter and smaller there is no fitment problem."
    Mtbpsych likes this.
  8. Apr 10, 2021 at 1:50 PM
    Charlievee
    Something else to consider...
    Stock Trail/ORP wheel is 7.5” wide, roughly 32 lbs, and is +15mm offset.
    Stock Pro is 7” wide, ~28 lbs, and +4mm offset
    There is an after market 17x8 Pro rim (don't know the spec). Just do your research and take all recommendations with a grain of salt, people mean well enough (most of the time) but leave out some critical information at times.
    djwantke, EvilBeagle and Thatbassguy like this.
  9. Apr 23, 2021 at 3:15 PM
    Charlievee
    Any updates on this. I run the same setup and also want to go bigger tires, would like to avoid buying rims... For now (not that i can find any to buy at the moment).
  10. Apr 23, 2021 at 3:39 PM
    I have been running 33’s for about 3 yrs. You just have to commit to it, if you need to trim the fenders, or do a bmc, or what ever. I did both with mine, and have had no problems.
    djwantke, 2Toys, nimby and 3 others like this.
  11. Apr 23, 2021 at 4:00 PM
    Charlievee
    There's unique issues with the JBA UCA and back spacing. I appreciate the information, but myself and the OP are asking specifically about the JBA issue.
  12. Apr 23, 2021 at 4:59 PM
    Mtbpsych
    Mtbpsych New Member
    Get different UCA’s:D
    TrailSpecial22 and LandCruiser like this.
  13. Apr 23, 2021 at 5:09 PM
    Charlievee
    Yes, and rims and a real truck to go with them.
    LandCruiser likes this.
  14. Apr 23, 2021 at 5:14 PM
    Mtbpsych
    Mtbpsych New Member
    Like @SlvrSlug, I’ve been running 33’s for a while and you just have to be willing to put in the work and get the right components. Best of luck:mudding:
    brownersd, Thatbassguy and SlvrSlug like this.
  15. Apr 23, 2021 at 5:18 PM
    Charlievee
    Good advice, never thought of it.
  16. Apr 23, 2021 at 5:25 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Nearly all aftermarket UCAs will require new wheels or spacers.
    SPCs have the same problem.
  17. Aug 13, 2023 at 8:28 PM
    kotneo
    kotneo New Member
    Konstantin
    2005 Gray 4Runner
    Hello guys,
    I'm new to all of this and I have a question that I hope you can help me with. I'm wondering if it's possible to install 33-inch tires on 16-inch rims since I've noticed that most people seem to use 17-inch rims instead. I'd appreciate any guidance you can offer. Thank you!
  18. Aug 14, 2023 at 5:56 AM
    TrailSpecial22 New Member
    PA
    why is that. Just curious
  19. Aug 16, 2023 at 2:03 AM
    hvac guy
    hvac guy New Member
    Not sure if 16" wheels would clear the brakes? Probably why Toyota went with 17" wheels
  20. Aug 16, 2023 at 2:44 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    JBA UCA's move the upper ball joint back towards the firewall to gain more caster. Just under 2" of lift, JBA's, 265's on 17x8 -10 wheels and I still rub on the mud flaps a bit. A safer bet would be 275's, but maybe you can find a tire shop that will let you test fit some 285's.
  21. Aug 21, 2023 at 1:26 PM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    The "FN Wheels f(x)Pro" (aftermarket pro) wheels are 17x8, 0mm offset and 24lb (contemplating them myself...in dark metallic blue because it's not black)
    Something else to keep in mind is that most tire manufacturers list 7.5 as the minimum wheel width for 285/70/17's (yeah, I know, people put them on TRD Pro wheels that are 7" wide all the time, been there, done that with my Nissan and while I had no issues, I would always recommend following manufacturer's requirements).
  22. Sep 22, 2023 at 8:41 AM
    BlueberryTRD
    BlueberryTRD New Member
    I'm starting my wheel and tire hunt with these recommendations in mind.
  23. Sep 22, 2023 at 5:09 PM
    Charlievee
    Keep in mind, they require grease every so often... seams to get everywhere. If you dont need to upgrade, stay stock.
  24. Oct 4, 2023 at 9:21 AM
    BlueberryTRD
    The UCA's? Yeah I do every couple thousand KM's. Super easy with the grease ports. I just really struggle on a few of the trails I go on and actually have to bail in some sections. The smallest tires my buddies run are 33's. I'm on 31's.
  25. Oct 4, 2023 at 11:39 AM
    Chillmatic
    Chillmatic New Member
    I have spc uca, eibach stage 1 on second clip, trd pro wheels (17x7) on 285 KO2's and very minimal rub at full lock, not even worth trimming for me.
