3.0L engine turns over but no start
Discussion in '2nd Gen 4Runners (1990-1995)' started by ridingmike, Aug 13, 2016.
  1. Aug 13, 2016 at 9:39 PM
    ridingmike
    ridingmike [OP] New Member
    Michel
    94 4runner V6 5 speed
    Hi everyone, I am new at this and I need advice. My 94 4runner does not run but it turns over good, it has spark, tested fuel pressure at 44 psi, checked the timing marks of the cam belt OK, changed the fuel injectors for the new 6 holes model, compression is good, I gave a shot of ether and it did not even kick or try to start. And if I pull it it will start! Any advice to what could be wrong here?
  2. Aug 18, 2016 at 7:35 AM
    Kyle11863
    Kyle11863 King of the BS
    Big Bear California
    1990 Toyota 4Runner SR5 V6 5 Speed Manual
    Doug Thorley long tube headers and lots of mud
    Maybe the idle needs to be adjusted a little higher? :notsure:
  3. Aug 23, 2016 at 7:12 AM
    ridingmike
    Michel
    Hi Kyle11863,
    Good idea, but last time I pulled started it, I let it idle to warm up for 45 minutes or so, turned it off then started it warm: turned over well but no start again ? When it turn over it doesn't even try, I am puzzled and getting desperate to find a fix. How do you adjust the idle speed?
  4. Oct 27, 2016 at 9:36 AM
    ridingmike
    Michel
    Hi every one, got the problem fixed, I send it to an electrical shop to find that the ignition coil was weak! Now it start up good.
    Thanks for the advice. Michel
    Bob likes this.
