285 tires on 7inch wide rim
Discussion in 'Wheels & Tires' started by szuyung3000, Dec 6, 2018.
  1. Dec 6, 2018 at 11:27 AM
    szuyung3000
    szuyung3000 [OP] New Member
    SYH
    2016 4runner SR5 4x4
    We probably all know by now that it is not recommended for 17x7inch TRD PRO or SR5 wheels to run 285/70R17 tires because manufacturer recommend at least 7.5inch minimum in rim width, but thousands and endless people run them and w/o any issues besides from abnormal tire wear.
    Has anyone run 285/75R17 tires (which is also 7.5inch minimum rim width) and w/o issues on factory TRD PRO or SR5 wheels too before?
    Strandskov likes this.
  2. Jan 1, 2019 at 9:12 AM
    I think you'll get a bunch of different opinions on this one. Personally, I think it's fine. I know it's not recommended, but I have numerous friends that offroad pretty hard (fast desert offroading) with 33" and 35" tires on 7" wheels. Not one of them has had a tire unbead. They've gotten flats from hitting stuff pretty hard, but nothing because of a wide tire on a narrow wheel. I know that's just anecdotal evidence, but that's all you're really going to get on this subject anyways.
    Also, I've never had a tire shop turn me down when asking to mount a 33" or a 35" tire on a 7" wheel. I think that says a lot. Others experiences may vary.
    Strandskov, SlvrSlug and 7385 like this.
  3. Jan 1, 2019 at 2:38 PM
    jack bauer1
    jack bauer1 New Member
    Yep..285/70/17 is fine on TRD wheels.
    Also aired down to 15 PSI without issue on Nitto RGs.
    I have yet to hear or see first hand of someone de-beading while running this (or similar) set up. Plenty of people talk about it happening, but have never seen it in practice.
    nimby, Strandskov and SlvrSlug like this.
  4. Jan 2, 2019 at 2:22 PM
    szuyung3000
    SYH
    So you are saying you had friends who run 35" diameter tire on TRD PRO 7" wide wheels? What exact dimension are those 35" tires?
  5. Jan 2, 2019 at 2:26 PM
    szuyung3000
    SYH
    Is there a certain PSI range to keep those 285 tires pressure at to keep it safe and prevent risk of de-beading? I'm guessing it's anywhere from 15psi to 40 psi max...
  6. Jan 2, 2019 at 4:52 PM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    Yes, exactly this question. The diameter of the tire has nothing to do with the lip width. There are pizza cutter 33 tires for sure.
    OP, you probably won't have a problem. If you don't already own the Sema wheels, consider the FN wheels. They're an inch wider, they're lighter, and they come in more colors. I love my six shooters. They're even lighter still, at 21 lbs per wheel. That saves 9 pounds per corner over the stock Trail wheels.
    7385 and SlvrSlug like this.
  7. Jan 2, 2019 at 5:21 PM
    Unless you are running the Baja? I do not think you will break a bead, i have been running mine for awhile now with no problems.4D887ECE-0825-4CDD-A471-3182FDCC11AE.jpg
    Cutesho, Jimbo814 and jgcaps like this.
  8. Jan 2, 2019 at 11:35 PM
    jack bauer1
    I would say it depends on the tires you are running and how you drive.
    I off road solo in very remote places and I don't drive like a dip shit.
    Most of the terrain is very rocky and or hard packed and no issues aired down to 15 PSI. On road I run 34 PSI.
  9. Jan 2, 2019 at 11:37 PM
    jack bauer1
    Nice looking tire.
    How you are getting on with them so far?
  10. Jan 2, 2019 at 11:51 PM
    4runningMan
    4runningMan New Member
    New Mexico
    The wheel manufacturers know exactly the point at which you'd likely blow a bead. It's simple physics. So, they issue their suggested tire sizes. Where it gets dangerous is when unexpected things happen.
    You could have 1000 people have no problem at all. And then all of the sudden you're driving down the interstate, a deer runs out in front of you, you instinctively swerve to miss it, and you blow a bead at 75mph. This puts you and others in a potentially perilous situation.
    Some don't mind taking the risk. Can you run them? Sure. Will you have a problem? Probably not. But you might.
    jgcaps, gdvan01 and 7385 like this.
  11. Jan 3, 2019 at 5:20 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    Exactly. I for one like to follow manufacture recommendations, especially with something that could be life or death to my family members.
    7385 likes this.
  12. Jan 3, 2019 at 7:07 AM
    I like them, but they do hum a little. Mostly when braking, and not much on the freeway. I like a little more aggresive look on the runner. Very durable tire.
    7385 and jack bauer1[QUOTED] like this.
  13. Jan 3, 2019 at 9:34 AM
    They weren't Pro wheels, they were 17" x 7" from a different manufacture. Tire was 35" x 12.5". Same width as your typical 33" tire.
  14. Jan 3, 2019 at 10:55 AM
    jack bauer1
    It's funny the shit people worry about.
    If folks were really concerned with longevity and risk they would stop eating a crap diet and start exercising.
    ItsJustJ and SlvrSlug like this.
  15. Jan 3, 2019 at 11:31 AM
    szuyung3000
    SYH
    If I remember correctly, your shop had put 44psi front and 38psi rear at those tires correct?
  16. Jan 3, 2019 at 11:36 AM
    szuyung3000
    SYH
    So seems to me with everything I heard/read from people's opinion and people's experience.
    The answer is simple:
    To run 285 w/ recommended w/ of 7.5" on 7" wheels are:
    Will there be an issue? Very likely not but still isn't 100% safe. How to keep it safe from debeading? Keep the tires at a certain PSI range I would assume...
  17. Jan 3, 2019 at 11:40 AM
    szuyung3000
    SYH
    I am assuming you had mud, dirt, and other debris stuck between your rim and tires is because you aired down to 15 psi when you had offroaded, therefore increasing more chance of that happening.
    MI-FL off roader likes this.
  18. Jan 3, 2019 at 12:49 PM
    I don't think there's an answer to be 100% safe......even if you are within spec you still have a slim chance the tire could come off the wheel during some extreme maneuver.
    Perhaps your best course of action would be to go to a reputable tire shop and get their opinion on the matter. The shops that regularly install bigger tires for offroad worthy vehicles will be able to give you an opinion based on a larger sample size than we can here.
  19. Jan 3, 2019 at 1:58 PM
    I am currently running 46psi in the front and 35 in the rear. It does not ride rough at all, and the contact patch is great. Keep on keeping on.
  20. Jan 3, 2019 at 3:58 PM
    szuyung3000
    SYH
    I personally had spoke with the people at 4wheelparts and they had told me I will be fine. And that they've installed many many 285 tires on 7inch wide wheel before for their customers on the 4runners. And told me they are liable for their customers.
    nimby[QUOTED] and SlvrSlug like this.
  21. Jan 3, 2019 at 4:06 PM
    Now this will get jumped on because some folks will not like 4Wheel parts lol.:crapstorm:
  22. Aug 23, 2019 at 8:55 AM
    Jimbo814
    Jimbo814 New Member
    PA
    2016 SR5
    3" Toytec BOSS lift, JBA UCAs, Vision Fury 17 x 8.5 0 offset, Cooper STT Pros 285/70/17, Rola Vortex Rack, Profile RGB ditch lighting, 2700 Xenon depot amber fogs w/ lamin-x film, TRD skid plate, Tyger auto Nerf bars, Bushwacker pocket flares
    I just got a killer deal on these same tires and want to mount them on my stock SR5 rims as a spare set... did you need to buy spacers to clear your UCAs?
  23. Aug 23, 2019 at 8:56 AM
    No i did not.
    Jimbo814[QUOTED] likes this.
  24. Aug 23, 2019 at 9:10 AM
    szuyung3000
    SYH
    If rubbing on UCA. It's likely because of aftermarket UCA and need wheel spacer or rims with more negative offset to avoid rubbing on UCA caused by the wider tread width tires.
  25. Aug 23, 2019 at 11:22 AM
    Jimbo814
    Jimbo814 New Member
    PA
    2016 SR5
    • Yea, I am running 285/70/17 Cooper STT pros right now on vision fury 17 x 8.5 with 0 offset and i'm fine (JBA UCAs)... If i've got to get spacers to fit the Wild Peak M/Ts on the stock rims it's no big deal. Glad to hear SlvrSlug didn't need to though
  26. Mar 29, 2021 at 3:13 PM
    Cutesho
    Cutesho New Member
  27. Mar 29, 2021 at 3:14 PM
    Cutesho
    Cutesho New Member
    That looks great, how big are those tires? And are those original TRD’s?
  28. Mar 29, 2021 at 4:54 PM
    They are original wheels with 285/70/17 Falken Wildpeak MT’s
