285/70R17 fit on a stock 2018?
Discussion in '5th Gen 4Runners (2010-2024)' started by WhoDoiFollow, Mar 10, 2018.
  1. Mar 10, 2018 at 10:37 AM
    WhoDoiFollow
    WhoDoiFollow [OP] New Member
    Wesley
    2018 4Runner TRD Off-Road Premium
    Nothing Yet
    i was wondering if 285/70R17 Goodyear Duratrac w/ White Wall Out would fit on stock 2018 toyota off-road premium wheels, as well as not lifted.
  2. Mar 10, 2018 at 11:15 AM
    zizzy34
    zizzy34 New Member
    17 T4ROR
    No, they will not fit stock without major rubbing issues. Most people put on 2-3 in lifts to accommodate that tire size, and even then, they will most likely have to do CMC and/or wheeloffsets
  3. Mar 10, 2018 at 12:59 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Your rear tires will fit, the fronts will not. You will have to get wheel spacers for the UCA rub, ditch the mud flaps, modify the fender liner and do a cab mount chop as mentioned above.
  4. Mar 10, 2018 at 1:06 PM
    WhoDoiFollow
    Wesley
    Nothing Yet
    What if i was to install a 2.5" lift kit (toytec boss Lift Kit)
  5. Mar 10, 2018 at 1:23 PM
    JBTRD
    Jeremy
    Bryan, Texas
    2016 (The Real) Trail Edition
    You would still have to do what was mentioned above, i run 285/70/17 with a 3in lift, there is no way that tire size will fit stock, with a 3in lift and TRD Pro rims however a spacer is not needed
  6. Mar 10, 2018 at 3:32 PM
    Northern 4runner
    Northern 4runner New Member
    2020 tundra trd sport premium, 2005 Tacoma trd off road, 2022 Tacoma on order
    Ko2’s and bilsteins/OME
    Some People run that size with a 2.5-3" lift workout issues, some have issues, depends on tires I think. The duratracs aren't exactly a squared off tire so you may be alright after some minor mods
    I have a 2.5/1.5 on my 2016 trail and run 275/70/17 ko2 without any issues on stock wheels
  7. Mar 10, 2018 at 3:52 PM
    WhoDoiFollow
    Wesley
    Nothing Yet
  8. Mar 11, 2018 at 12:43 PM
    JBTRD
    Jeremy
    Bryan, Texas
    Your going to want to stick to certain rims that follow specific mesurements, you will notice most people use the same certain brands of rims, more people will have experiance with aftermarket rims, i just went with TRD Pro. Now for tire size i would think one size smaller 275-70-17 would have no issues, but i would wait for someone who runs that tire size to chime in on their experiance i only know about 285-70-17
  9. Mar 12, 2018 at 12:59 PM
    WhoDoiFollow
    Wesley
    Nothing Yet
    What if i grabbed TRD Pro Rims, what tires would i use so that they wouldnt rub.
  10. Mar 12, 2018 at 3:00 PM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    275/70.
    gunsnob, jgcaps and P226Navy like this.
  11. Mar 12, 2018 at 6:13 PM
    JBTRD
    Jeremy
    Bryan, Texas
    275 and if you want FN makes a similar rim to the TRD Pro and other rims made for our trucks.
  12. Mar 12, 2018 at 6:50 PM
    Northern 4runner
    FYI the fn wheels stick out more
  13. Mar 14, 2018 at 11:23 AM
    WhoDoiFollow
    Wesley
    Nothing Yet
    So Fn wheels with size 275 tires would be perfect? Any recommendations on tires?
  14. Mar 14, 2018 at 11:29 AM
    4X4Runner
    The left coast
    Tire recommendations are all personal preference. What are you going to do with them, what do you look for in them, how long do you want them to last, etc?
    I run BFG AT KO2’s and ran KO’s before the KO2’s. I found a good balance of wear, traction in snow, dirt and mud as well as appearance. Some will recommend Toyo’s some will recommend Nitto, some will recommend Michelin, General, etc.
  15. Mar 14, 2018 at 11:39 AM
    WhoDoiFollow
    Wesley
    Nothing Yet
    I'm looking for one that's good for daily pavement driving, as well as the occasional off road. something better than the stock tires? (im assuming the stock tires arent really made for off roading)
  16. Mar 14, 2018 at 11:42 AM
    4X4Runner
    The left coast
    Depends on how aggressive you’re looking to be Offroad.
    I made it to here on the stock tires and without airing down.
    4827150E-F590-4084-8239-CEFD600FEC80.jpg AE2486B5-B1FE-4A7A-AADD-AC6AF97EEF1F.jpg
    gunsnob, arnette64, 7385 and 2 others like this.
  17. Mar 14, 2018 at 12:01 PM
    WhoDoiFollow
    Wesley
    Nothing Yet
    Yeah something like that to get started but i hope to move on to bigge trails
  18. Mar 14, 2018 at 1:02 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    Yeah, what 4X4Runner said. I've been using BFG AT's since the late '70's. Great all around tire for on and off-road. I live in the mountains so the mileage warranty isn't a concern of mine. I have tried Goodyear Wrangler AT, Yokohama, and even some ProComps with not so satisfying results.
    Steve
    jgcaps likes this.
  19. Mar 15, 2018 at 4:08 AM
    Northern 4runner
    I like my ko2, quiet, look and perform great
  20. Mar 21, 2018 at 7:50 PM
    WhoDoiFollow
    Wesley
    Nothing Yet
  21. Mar 22, 2018 at 4:34 PM
    mynameistory
    Tory
    I set mine up my TEP on stock suspension with 275/70 KO2s and the Six Shooters. Dustin specifically advised against the type X due to their more aggressive offset, when I told him I wouldn't be lifting anytime soon. This negative offset pushes the wheel out further, which means your scrub radius increases and you are at more risk of rubbing.
    Even with the more conservative offset, the Six Shooters are lightly rubbing on the flaps during turns (they didn't before with stock Trail wheels). I massaged them a bit with a heat gun, but I need to pull them back since they still rub slightly.
    Six shooters and 275/70s are about as big as you can get on stock suspension without doing major clearance.
    arnette64, TallyGirl and jgcaps like this.
  22. Mar 23, 2018 at 12:22 AM
    WhoDoiFollow
    Wesley
    Nothing Yet
    So if I don’t want any rub I could go 265/70 instead of 275/70?
  23. Mar 23, 2018 at 3:24 PM
    57buick
    57buick New Member
    David
    2018 4runner Off Road premium
    33" Duratracs, TRD Wheels, Addicted Off-Road front Bumper
    I just installed 285\70\17 duratracs today with the TRD wheels with just a 3" front 2" rear spacer kit. Looks great and on occasion get a little pop at full tilt and reversing. Not sure which lip of fender its hitting sometimes? front or rear but I dont care. Ill tweak fender lip a little for now. Just waiting on my addicted offroad front bumper and it won't matter anymore.
    Below is a pic taken today of the wheels and a pic I got off the forum of the bumper im ordering.
    ToyoTaco25, gunsnob and Z-MAN like this.
  24. Mar 23, 2018 at 4:00 PM
    Dark Knight
    Dark Knight Get off my lawn
    That’s not a 4th gen....
  25. Mar 23, 2018 at 4:07 PM
    57buick
    57buick New Member
    David
    yea I realise that now its just an older year model though sorry. still learning the differences just knew the headlights were different
  26. Jun 14, 2018 at 10:04 AM
    CarlEToast
    CarlEToast CarlEToast
    Carl
    Cypress, TX
    Silver 2016 SR5 4Runner
    custom fishing pole rack
    Hey,
    has anybody tried 285/65/17? maintain the same radius as stock, but increase the width. Do you still need to chop pieces off?
  27. Jun 30, 2018 at 1:17 PM
    teknikk7
    teknikk7 New Member
    I know this goes against everything I’ve read but I have had zero rubs on my 2018 TRD Pro with KO2 285/70/17. Stock! I’ve been driving for days and cannot make it rub. Guess It’s an isolated case? Everyone was telling me it’s going to rub, I even ordered suspension risers but looks like I don’t need them.
  28. Jun 30, 2018 at 5:40 PM
    ckon
    ckon New Member
    Chuck
    SE Michigan
    2018 Silver TRD ORP w/KDSS
    Tinted front windows | Hard-wired radar detecter | Heritage grille | Bumper, wheelwell and mudflap mod | 285/70 Nitto Grapplers | Plasti-Dipped valances, rack rails and logos | Replace all interior lamps w/LEDs | XenonDepot HIDs | Salex console and glove box organizers | RCI aluminum skid plate | Sprint Booster | Bilstein 5100 Shocks - Leveled @ .85 |
    This is my second fifth gen 4Runner with 285/70/17 tires installed at stock height. After the typical minor wheel liner, bumper and mudflap mods, both have performed just fine - no rubbing. BTW, the first one was an LE and my current version is a TRDORP. The current one is on stock 7.5 inch rims and the LE had 8.5 inch if I remember right.
    Oldtoyotaguy likes this.
  29. Jul 1, 2018 at 7:51 AM
    tackleberry1145
    tackleberry1145 New Member
    2014 Trail Barcelona Red
    Always saving pennies for more
    Courtesy 1engineer on t4r.org:
  30. Oct 21, 2018 at 9:37 PM
    CalRnr
    CalRnr New Member
    Dustin
    2018 TRD ORP Magnetic Gray
    I have a 2018 TRD ORP with stock wheels. I've been debating to lift, not to lift, what lift, etc. But, at the same time, would love to upgrade my tires. I thought about getting 265's, but am pretty sure I'd regret it in a few months, and not ready to spend $2k to $3k on the lift I want. Seems like minor rubbing if I stick with the stock wheels and go 285/70/17. What does that mean exactly? Can I drive it home from the tire shop / dealership and sort out what adjustments I need to make to fenders, etc? Or, is the rub so bad it will do damage? Any thoughts would be appreciated.
