285/70/17 tire pressure
Discussion in 'Wheels & Tires' started by Oobaa47, May 15, 2018.
  1. May 15, 2018 at 8:45 PM
    Oobaa47
    Oobaa47 [OP] New Member
    2018 sr5
    Just curious, for everyday driving, what kind of tire pressure is everyone running with their 285's? Thanks!
  2. May 16, 2018 at 5:55 AM
    ckon
    ckon New Member
    Chuck
    SE Michigan
    2018 Silver TRD ORP w/KDSS
    Tinted front windows | Hard-wired radar detecter | Heritage grille | Bumper, wheelwell and mudflap mod | 285/70 Nitto Grapplers | Plasti-Dipped valances, rack rails and logos | Replace all interior lamps w/LEDs | XenonDepot HIDs | Salex console and glove box organizers | RCI aluminum skid plate | Sprint Booster | Bilstein 5100 Shocks - Leveled @ .85 |
    35 for me so far but still experimenting.
  3. May 16, 2018 at 7:30 AM
    4X4Runner
    The left coast
    36 here
  4. May 17, 2018 at 6:38 AM
    Oobaa47
    2018 sr5
    cool thx...I've been running at 33 psi, but I think I'm going to go up a little and see how it feels..
  5. May 17, 2018 at 9:31 AM
    P226Navy
    P226Navy 2016 T4R
    Vee
    South San Francisco
    2016 Toyota 4Runner
    36 is perfect. This would increase mileage per gallon.
  6. May 17, 2018 at 3:42 PM
    Oobaa47
    2018 sr5
    I have the 285/70/17 falken wildpeak at3 P, 117 load rating
  7. May 17, 2018 at 4:05 PM
    Oobaa47
    2018 sr5
    P related....the lightest ones...I think they're 51 lbs a piece if I remember correctly....
  8. Jun 5, 2018 at 7:20 AM
    Oobaa47
    2018 sr5
    I meant they weigh approx 51lbs a piece..... coincidentally on the sidewall it says max air pressure is 51 psi.....but it definitely says P285 there too so I presume they are P load which is the passenger rated?
  9. Jun 5, 2018 at 8:03 AM
    jgcaps
    jgcaps Lovin the Colorado Life.!
    CO
    2018 MGM TRD ORP KDSS 4Runner
    3" Icon Stage 2, 18x9 Fuel Beast wheels, 285/65/18 BFG KO2's, N-FAB Black Rock Rails w/removable steps.
    trying out 38 front 36 back...
  10. Jun 5, 2018 at 6:02 PM
    I am running the Falken Wildpeak M/Ts, in the 285/70/17 E load at 44 front 38 rear. This may be the sweet spot for me, i have been adjusting the pressure the last couple weeks.
  11. Jul 28, 2018 at 1:26 PM
    eaglescout
    eaglescout 2018 SR5
    Middle Tennessee
    2018 Magnetic Gray Metallic SR5
    FN FX PRo Wheels Matte Dark Bronze. Nitto Ridge Grappler 285/70/17/load C 3" Dobinson Coil Lift Blackout Kit Raptor Style Grill LED C4 Fab Lo Pro Winch Bumper LFD Offroad Skid Plate Shrockworks Sliders Rago Molle Panels Extreme LED Ditch Lights Ecotechne Roof Rack Detours Offroad Swingout Tire Carrier
    I just put 285/70/17 Nitto Ridge Grapplers on, and the tire shop set them at 40 psi. Thanks for the chalk test! I will be trying this this weekend. Oh yeah, they are load range C.
  12. Jul 28, 2018 at 6:33 PM
    ckon
    ckon New Member
    Chuck
    SE Michigan
    I've set mine back down to 32 in hopes of keeping the rear end in place when going around corners and accelerating cuz it can get a bit loose.
  13. Jul 31, 2018 at 2:14 PM
    Pelfreybilt
    Pelfreybilt Pelfreybilt Off-Road, Inc.
    Pelfreybilt
    El Cajon, CA
    2014 4Runner
    ~ Pelfreybilt Front Plate Bumper, Rear Swing out Bumper Powder coated and Rocksliders coated by Line-X San Diego ~ Baja Designs Squadrons and S8 Light bar with 40" Onyx Hi-Power roof rack light bar~ Front Runner Outfitters roof rack, fridge slide & bottle opener ~ CVT Rooftop Tent & Awning ~ Katzkin Leather seat covers ~ Switch-Pro control kit ~ Factor 55 Flatlink ~ WARN Zeon Platinum 10-S Winch ~ 17" Method Wheels ~ 35" Toyo RT's ~ Total Chaos Long Travel Kit with Mathicng King shocks w/adjusters. ~ ARB lockers, skid plates ~ JL Audio custom stereo system ~ Dometic Dual Zone Fridge ~ Kustom 54 Retrofit Headlights ~ McQueen Glass Front Fenders ~ GOBI Ladder ~ Pearl White Wrap with Decals from BeyondWraps ~
    It is very much dependent on the tire brand/type/rating and weight of the vehicle as well. We run many different PSI's here at the shop depending on the rig. Our second Gen Tacoma is running 315/75R16 Falken MT01's and runs at 40F/38R PSI as this has been the best wear PSI we have found for it at its normal weight (when loaded rear goes up a few PSI). This is more than the same truck running the 315/75R16 MTR's with Kevlar and even more still than the truck running 285/75R16 Falken AT's. It will vary from rig to rig unless you weight exactly the same and are running the same tire with the same alignment.
    eaglescout and SlvrSlug like this.
  14. Aug 4, 2018 at 11:00 AM
    szuyung3000
    szuyung3000 New Member
    SYH
    2016 4runner SR5 4x4
    the TRD wheel is 17x7" and 285/70R17 calls for at least rim minimum width of 7.5"
    I know lot of people do that, it is safe correct?
  15. Aug 4, 2018 at 11:02 AM
    szuyung3000
    SYH
    P is Passenger rated. LT means Light Truck, biffier tires and thicker sidewall and deeper treads.
