285/70’s on Pro wheels
Discussion in 'Wheels & Tires' started by muddyix, May 14, 2024.
  1. May 14, 2024 at 12:54 PM
    muddyix
    muddyix [OP] New Member
    AZ & TN
    '22 AG ORP
    I’ve seen countless of people run this setup without issues. My question is where did you get them mounted and balanced?
    Since the pro wheel is only 7” wide and recommended is 8.5” some shops won’t touch it due to that.
    I found a great deal on a new set that I can’t pass up while visiting SoCal and I’m looking for a place that can install them for me.
  2. May 14, 2024 at 1:04 PM
    Find a good off road shop, they will probably accommodate your needs.
    muddyix[OP] likes this.
  3. May 14, 2024 at 1:30 PM
    I think shops don't cause problems when try to mount 285/70R17 on TRD Offroad wheels since they meet minimum width 17x7.5
    I've been going to same Discount Tire shop for many tire needs for the 4Runners. So that shop didn't cause a trouble mounting 285/70R17 on 17x7 TRD Pro Wheels.
    (BTW, this not not mean I approve to mount 285/70R17 on 17x7 TRD Pro wheels. I'm taking a risk going against tire manufacturers spec.)
  4. May 14, 2024 at 2:46 PM
    I am running 285/75/17’s with no problems, The Truck Shop installed mine.
  5. May 14, 2024 at 6:48 PM
    muddyix
    AZ & TN
    '22 AG ORP
    I have the clearance. About 10 years ago I had this exact issue with my jeep but in 35x12.5, no shop would mount it. Given it was just a full size spare to get me off the trail and not for the road, so I mounted it myself and didn’t balance it.
  6. May 15, 2024 at 7:20 AM
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    It all depends on the shop. Some will go by the book of the tire manufacturer’s specifications due to liability issues. Other shops will gladly take your money and put to big of a tire on to small of a wheel. In my opinion, follow the tire manufacturers wheel specifications for the tire.
    kmeeg likes this.
  7. May 15, 2024 at 10:12 AM
    muddyix
    AZ & TN
    '22 AG ORP
    Yeah I was going to wait to do wheels and tires at the same time, but since I’m going to be moving across the nation (again) in the next few weeks, moving costs have eaten away at that possibility. I needed tires anyway since mine are somewhat dry rotted, 50k miles, and all have at least one plug in them. I was going to do 255/85 or stock size but I was able to get a great deal on 5 new Toyo RTT for half off. So this setup is very temporary. Literally just until I get to the new destination and then new wheels will be mounted.
  8. May 15, 2024 at 10:15 AM
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    Great tire i just had a set of them. Only downfall in when they are on wet asphalt they spin like no other
  9. Jul 18, 2024 at 9:13 AM
    503Runner
    503Runner New Member
    Luke
    4 runner
    2015 trd pro- what’s the bigger tires I can fit without getting a lift & rubbing on something? Thank you.
  10. Jul 18, 2024 at 9:50 AM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    I had my original set of 285 KO2's mounted at America's Tire (aka Discount Tire) with no issue or comment. Since then, I exclusively mount & balance at off-road specific shops...just an overall better experience.
    Regardless, I can't recall any visit where the tech measured my wheel before mounting. Particularly at our local America's Tire...they pump out cars as fast as possible, since it's a higher volume location.
    If you're still in SoCal, check RPM Garage or 88 Rotors.
